Old Jun 19, 2012, 12:33 PM
Gravity Dodger is offline
Find More Posts by Gravity Dodger
White stuffs here time 2 build
Gravity Dodger's Avatar
Minneapolis Minnesnowtah
Joined Nov 2007
Thanks Darrell, Rebel Squadron looks like a nice place to fly, my girlfriend is a newly board certified Veterinarian so were waiting on hearing back from one of the clinics down there on a job opportunity... so are fingers are crossed!
Gravity Dodger is offline Find More Posts by Gravity Dodger
Old Jun 19, 2012, 05:17 PM
Sugarbear36 is offline
Find More Posts by Sugarbear36
Nam AV8TR
Las Vegas, NV
Joined Nov 2005
MNMadman
got our fingers crossed with you.
Sugarbear36 is offline Find More Posts by Sugarbear36
Old Jun 19, 2012, 05:56 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Stators should affect sound... and also the output too.
Imagine stators made for a certain rotor and its RPM design... they have to be angled, even curved, at a certain optimal. And even then, they are only truly 'perfectly' suited to that RPM aimed for main operation - though they should be in good region across a fialry wide range anyway.
Then throw in a different rotor... especially when you compare the CS12/10 to lower blade count rotors. The stator difference would become more important.
Less RPM, higher flow.... I expect would need lesser stator angle/curve.
So throw the rotor of a fan with lower angle's for its lower RPM, into the shroud designed fo rhigher RPM, and the airflow would hit more angled stators.... it would have to be more like hitting something, than flowing over/past. Even if a small perentage difference.. it would be different.
Hitting a larger angle would also increase load, to 'fight' past the stators that bit more.
So I am sure different housings (material thickness aspects also etc) would alter the sound and output. Even if very small in some cases.
PeterVRC is online now Find More Posts by PeterVRC
Old Jun 19, 2012, 06:14 PM
Joined Nov 2006
Also, it is extremely high speed airflow, so ANYTHING in its path is going to cause turbulence and 'noise' of some form and level. The stators would be a big item.
Even the airflow over the motor.... inrunner or outrunner - different. Wiring shape/path.
Then all the other commonly mentioned, duct flex, shape, area etc.
You could probably put in some form of vane, or even 'tube' (eg like short pipe held mid duct by vanes) to create sound effect results. And depending on the size/shape - still made aerodymanically of course - it could add just certain 'noise', and even at no thrust cost - but probably a bit of efflux speed cost.
Or imagine an item made with 'loose' trailing edges so it can vibrate..... (just a small or micro amount of course)
The possibilities are endless really.... but therefore would need a lot of testing to see what did what.
For the CS12 rotor more typical 'just as it is fitted' cases you have: Shroud, motor, ducting (covers flex, diameters, area/volume, shapes) that are involved. Then add your own.....
You could mount a Kazoo in there.......
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Thanks a mill Pete! Explains it perfectly! I more than likely won't change the shroud on my existing airframes to the CS shroud, but I will definitely compare the two shrouds for future installs.
v8truckin is online now Find More Posts by v8truckin
Old Jun 19, 2012, 06:59 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Good overview of stator function or in some cases, malfunction. One biggie to consider IMO is that CS most likely did zero testing before deciding on their stator design. In some cases fan sound and performance both improve by adding more stators or more aggressively curved stators. Tam's 100HP is a good example. He added two stators and both sound and thrust improved in the 3kw to 4kw power range.
Point is that mixing and matching rotor /shroud combinations can produce good results sometimes.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 19, 2012, 07:54 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Not only that..at low power is also improvement the thrust and efflux by 7%.
Bob Park do his homework very well in the computer model design the stators to be work effecient any RPM rotor.
Tamjets is offline Find More Posts by Tamjets
Old Jun 19, 2012, 08:10 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by SkylineFlyer View Post
Has anyone cut the shroud down to a standard 90mm edf size? They're obviously longer than the typical shroud size. The flyfly bae hawk is what I'm trying to fit it in, but if need be, I'd like to be able to remove it. Or should I skip the CS shroud and use the flyfly shroud with the CS fan?
I cut my CS shroud down to the Freewing size (all off the back end). I posted some pictures somewhere on this thread. Easy with a hacksaw then sand flat. Makes swapping noisy fans out a snap!
I didn't like using the FW shroud as the CS blades have too much gap at the leading edge and it can only handle a 36mm motor when I'm using a 40mm (sanded down to fit the CS shroud tightly).
4stripes is offline Find More Posts by 4stripes
Old Jun 19, 2012, 08:17 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Originally Posted by viperviper View Post
hi Eric, may i know which ESC are u using for your HET 700-68 1400kv setup? And any external BEC? Pls kindly advise. tks!
http://www.hobbyking.com/hobbyking/s...dProduct=20696
HK changed the branding on this since I bought mine (Helidrive I think) but it is the same.
Separate BEC
http://www.hobbyking.com/hobbyking/s...dProduct=18521
This was soldered to the battery leads running to the ESC.
I have about a dozen flights with this setup running 9 and 10S. No issues.
Cheers
Old Jun 20, 2012, 05:01 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Separate BEC
Cheers
Thanks for your detail info and recommendation.
viperviper is offline Find More Posts by viperviper
Old Jun 20, 2012, 11:37 AM
gal is offline
gal
Find More Posts by gal
gal
Joined Sep 2009
Alloy DPS-2 Series 90mm + cs12
http://www.hobbyking.com/hobbyking/s...dproduct=21145
can i fit the cs12 blade fan into this one on 8s looks like a high power setup did any one try
gal is offline Find More Posts by gal
Old Jun 20, 2012, 12:28 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Nope, try one of the older 6s lander shrouds
erh7771 is online now Find More Posts by erh7771
Old Jun 20, 2012, 01:34 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Thanks guys for the stator knowledge! I'll definitely think about using the CS shroud next time for a comparison of the two with the same motors.
Old Jun 20, 2012, 02:40 PM
gal is offline
gal
gal
Joined Sep 2009
maby this one
and this one
Old Jun 20, 2012, 04:57 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
The CS shroud is thicker then most other shrouds too. Had I been using another shroud with mine when the rotor blew I'm sure there would have been damage to the fuse too. I'm even considering wrapping some thin sheet metal around the shroud in the rotor area.
davecrash is offline Find More Posts by davecrash
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
