Old May 19, 2012, 05:36 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by PeterVRC View Post
That "Use less blades" idea might even be a better idea than expected.....
If the system (blades/count etc) is not optimised as it is - due to supposedly being a mad/scaled down clone of a Stu? - then this fan itself might even perform better at 11, 10, or 9 blades. With one of those being the true optimal. With required KV etc to suit that too.
You could just remove how many baldes you want and space it out with bubble-gum or something.....
Bubble-gum.....LOL
10, 9, and 8 blade combo are very easy to do by just putting a blank (hub part but with no blade) in the place where a full blade would be.
11 blades would be more work. You`d need to make 10 "shims" that would have the shape of the hub part of the blade and be the right thickness (1/10th of a standard blade hub) to take up the slack. I know the stock blades have a tapered hub section, but the shims would only be about .030" each, so I don`t think taper would be an issue.
But if it was a very good fan with 11 blades, the shims could be lazer cut from the right material and thickness, and would be very cheap if large quantities were made.
Also shim shims could be made from lots of very thin sizes so that they could be used to fine tune any unwanted space.
Man, that`s a great idea! Does anyone have cheap access to a lazer cutter? Evenly spaced blades would look, and probably perform better than just leaving out blades.
Knife Liddle is online now Find More Posts by Knife Liddle
Old May 19, 2012, 05:41 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Here`s my new CS-90-10. Runs smooth as silk. Didn`t need any ballancing 1200kv, does 80a on 8s, about 2.3kw.
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Jeez.... "Leaving out blades and putting in a blank" is worse than using bubble-gum!!! LOL
Try and balance that !
Oh I see.... 10, 9 and 8... ok.... of course works out balanced fine.
Airflow???? Hard to know if it would have some weirdo 'vortex'/turbulence thing going on.
It might even make some amazingly great new sound too!!
"Flat shims"... as far as I can think they should work fine anyway.
Icy-pole sticks....... (They're free AND you got to have an icy-pole too!)
PeterVRC is online now Find More Posts by PeterVRC
Old May 19, 2012, 05:44 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Maybe we should put in a blank and also add the bubble-gum just for extra insurance.
Old May 19, 2012, 05:48 AM
Joined Nov 2006
I think Mark/ExtremeRC are 'bonding' CS12 blades with that top secret bubblegum idea! But we need to work out the brand and the flavour used!
Old May 19, 2012, 05:52 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
How many chews is probably a key factor too.
Old May 19, 2012, 05:56 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I guess I`ll look into making up some shim kits that would have the sizes needed for the various blade counts. Liability won`t be a factor, because I`ll just sell them as "wind chime kits" or something like that. If some fool wants to put them in a rotor hub, that`s his problem.
Old May 19, 2012, 06:37 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by Goody63 View Post
OMG. Talk about dejavu!!
I was just over at the F-100 site
But I was going to ask what capacity packs you are using?
Cheers
I am running the Zippy 5800mah 6S 30C + a Zippy 1S 30C 6200mah to make 7S. The little 4mm bullet connectors built into the 1S pack were soldered to give better contact and the standard connector replaced with 5.5mm bullet connectors like all my 6S packs. Having the 5.5mm connectors makes it easy to run batteries in series. The balance is better without the extra battery but it is manageable with a little extra elevator throw.
Cheers Eric
4stripes is online now Find More Posts by 4stripes
Old May 19, 2012, 07:39 AM
4stripes's Avatar
Joined Jan 2009
Nice!
Great way to fine tune the AMP draw for motors that are pushed too far with all 12 blades.
Keep the new ideas coming!
Cheers Eric
Old May 19, 2012, 09:02 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
I was thinking of doing the same thing with the 120mm fan taking it down to 6 blades for higher KV motors. I have some busted blade roots I was going to sand down smooth. Did you really run that Lee?
scatsob is offline Find More Posts by scatsob
Old May 19, 2012, 10:22 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Check X flight for some shims or spaces without blades
erh7771 is online now Find More Posts by erh7771
Old May 19, 2012, 10:23 AM
Joined Nov 2005
Hey Knife, how did you make the standoff again?
Regards
Old May 19, 2012, 11:53 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Im at work I'll get you some information when I get home. I just found out that's my phone has voice recognition this is too cool. now I can talk you guys to death lol. I need this on my pc.
oh yes I really ran the fan. it ran perfectly as smooth as any fan I've ever had
Old May 19, 2012, 01:14 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
How about this motor on 6s guys?
http://www.hobbypartz.com/96m812-3674-1700kv.html
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old May 19, 2012, 01:21 PM
Graham d is offline
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Here is a vid of the MB339.
Thank you Jaco for helping with the video
FLYFLY MB339-1/1 (2 min 25 sec)
Graham d is offline Find More Posts by Graham d
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
