Old Oct 15, 2011, 05:07 PM
QueeQueg is offline
Find More Posts by QueeQueg
Joined Apr 2009
It's those dilithium crystals and the warp drive
I just want to get the sound and see what a differnce I get out of the fan. I fly at 5,000 ASL and in the summer sometimes the density altitude is above 10,000. Like my planes I've got to add size and pitch to my props to get the same performance from a given power system as I would near sea level.
All I can do with an EDF is add volts or amps or both. Adding several blades will be an interesting experiment for me regardless of how it's sounds. That and it won't cost me 350 bucks to find out if it was worth it too.
Q
QueeQueg is offline Find More Posts by QueeQueg
Old Oct 15, 2011, 06:08 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by Zimm View Post
Whoever thinks that pulling over 100 Amps on 8S to produce a measly 7lbs (3.17kg) of thrust deserves to buy this, put it in their jets, get short flight times, destroy their batteries, possibly burn up their ESC and planes in the process
These people should then get out of the electric hobby and go into petrol because they simply don't get what is meant by Efficiency
It my opinion this is not a copy but a bad attempt. If it was a copy it should perform the same as the original.
So go ahead...buy it then post a video
I understand the new multiblade designs pull more amps but my old 4 blade Schubuler DS51 on 8S pulls 52A and produces more thrust....think about that...should having more blades pull DOUBLE the AMPS ??...
Yeah, Im gonna have to call BS on that too. Everything I could find on the DS-51 says it needs well over 2000 watts to get over 7 lbs of thrust.
Bring on the high blade count inefficient fans.
scatsob is offline Find More Posts by scatsob
Old Oct 15, 2011, 08:53 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
+1 on the bs call, a 90mm fan would need to have an efficiency of ~100% to get near 7lbs installed with only 1600 watts. My midi gets a little more than 7lbs installed on ~2500 watts. The motor is well matched to the fan drawing ~70-80amps.
Eric B.
AirX is offline Find More Posts by AirX
Old Oct 15, 2011, 09:06 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Whoever thinks that pulling over 100 Amps on 8S to produce a measly 7lbs (3.17kg) of thrust deserves to buy this, put it in their jets, get short flight times, destroy their batteries, possibly burn up their ESC and planes in the process...
That's typical for installed thrust, it's not a bench run...a thrust tub and intakes can take away static thrust while installed in an aircraft.
...I understand the new multiblade designs pull more amps but my old 4 blade Schubuler DS51 on 8S pulls 52A and produces more thrust....think about that...should having more blades pull DOUBLE the AMPS ??...
I'd like to see a vid of this with amps and oz of thrust INSTALLED, hell...I'd like to see it benched.
Schub would make a good case for buying their fans if I can take a 60 amp SUPPP 8s esc and 2 45c 2200mah 4s in series, push more than 7pds and safely have a 3min WOT flight.
There's not a fan out there pushing more than 7lbs settled on the bunch using around 1500 watts.
erh7771 is online now Find More Posts by erh7771
Old Oct 15, 2011, 10:55 PM
Zimm is offline
Find More Posts by Zimm
Joined Jul 2004
My Mistake!!! I thought that was static thrust not installed, thrust.
i read the data only, and was a bull out of the gates, I guess that will teach me a lesson, for reading short
Sorry!!!! about that Flip Flop
this is what i found for the 90mm setup.
Zimm is offline Find More Posts by Zimm
Old Oct 15, 2011, 11:41 PM
Flip Flop is online now
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
Its all good.
Flip Flop is online now Find More Posts by Flip Flop
Old Oct 15, 2011, 11:43 PM
Flip Flop's Avatar
Joined Oct 2009
I will try to get another video on MON.
Old Oct 16, 2011, 07:36 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Are these avaliable yet and if so where can i buy one?
lipoflyer is offline Find More Posts by lipoflyer
Old Oct 17, 2011, 05:41 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
^^^^ What he said
kahloq is offline Find More Posts by kahloq
Old Oct 17, 2011, 05:56 PM
QueeQueg is offline
Joined Apr 2009
No they're not available yet. Keep up with this thread and you should get info on when and where here. should be soon!
Q
Old Oct 17, 2011, 05:57 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Here you go boys..the video on post #78 in the link below should put the foamy ain't worthy of a high end fan debate to rest for good. The red Hawk and both T-33 are "foamys" The Thunderbird T-33 and the red Hawk are mine.. Can I do an 8 point roll or what!!! and it was done with cheap not glassed foam airframe and a kick butt Stu fan.
http://www.rcgroups.com/forums/showt...1500528&page=6
falcon5 is offline Find More Posts by falcon5
Old Oct 17, 2011, 07:16 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
ps andy....i really hate you after seeing that 8 point on film!
corsair nut is online now Find More Posts by corsair nut
Old Oct 17, 2011, 08:00 PM
Flip Flop's Avatar
Joined Oct 2009
Thats a good video! and a nice 8 point roll.....I hate you to.
P.S How did you get that foamy to fly like a composite?
Old Oct 17, 2011, 09:50 PM
Joined Nov 2005
VERY nice flying!!! One of the best event vids I've seen in a second or two.
Do you know if the Hawk was glassed or sheeted any? Its a Fly Fly model, I have their F4 and that hawk looks pristine...my F4 doesn't look anywhere near that finish after 2 years of flying it.
I was thinking about building a FF Hawk and sheeting it to get a gloss finish on it.
Is the Draken a kit or a scratch build... wish I was there.
Old Oct 17, 2011, 09:52 PM
tehachapi, CA
Joined Jan 2006
the hawk isnt glassed. draken is a scratch build
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
