United States, FL, West Palm Beach
Joined Jun 2004
Prop
[QUOTE=turbonut;19588369]
"When you"re one step ahead of the crowd you"re a GENIUS.. When you"re two steps ahead,you"re a CRACKPOT..
Still not buying it..the motor makes Power at a set rpm for best performance..it needs a prop that will work at that rpm. yes you need to pic a prop that will fly your plane at the speed you need...Well I guess this just depends on how you say it...So yes your correct but you not giving the full picture to those that need all the info...in reality its a full formula that needs to be used...if one part is not correct it just wont work...I would say you need to pic a motor to fit your application..as the prop is determined by the motor that can swing it as needed...I do understand what you are saying but it is a bit miss leading to the uninformed
if your are desighning airplanes from scratch you will find a prop for the plane then a motor or engine to swing it....but most just buy kits and stick the sugested motor in it...then start stickin props on and dont understand how come it wont fly...I see it all the time at our field.
I see like to say are thinking like a consumer or a designer....sometimes they are the direct opposite of each other.... I recall my comment about your post!....I will say that plane and motor MUST both be figured into the equation....which many people forget/or dont understand |
Joined Nov 2005
Joined Apr 2004
[QUOTE=RAPPTORS;19591922]
But how do you know you are ahead of the crowd that knows better? |
Joined Jun 2004
Prop
Joined Jun 2004
Prop
| Thread Tools | |
| Sold Zurich sun blocking sun-glasses $40 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 7 | Oct 06, 2011 10:47 PM |
| Sold Zurich sun blocking sun-glasses $50 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 05, 2011 09:14 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Video 6 and 12 blade 90mm fan sound test | tom bacsanyi | Electric Plane Talk | 3 | Dec 10, 2009 07:01 PM |
