Old Jan 11, 2012, 05:39 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Originally Posted by bobbit4447 View Post
Please don't confuse readers with dribble.
.......B
Oh, I don't think long time EDF guys would EVER accuse Klaus/Winmodels of spouting "dribble"
Careful who you cross swords (keyboards) with.
Mike Warren is offline Find More Posts by Mike Warren
Old Jan 11, 2012, 05:55 PM
bobbit4447 is offline
Find More Posts by bobbit4447
Fly it like you stole it !
bobbit4447's Avatar
Australia, QLD, Coolum Beach
Joined Oct 2011
My apologies to Klaus if interpreted that way.
B
bobbit4447 is offline Find More Posts by bobbit4447
Old Jan 11, 2012, 09:51 PM
Rudi3000 is offline
Find More Posts by Rudi3000
Joined Aug 2011
The statement I made is correct. I attach a reference from AMCA (The authority that Certified American Fan Manufacturers use) in order to calculate HP/watts for fans of varying diameters. Please don't confuse readers with dribble.
B
Hi bobbit
Please read my post again. I did say that you were quite correct!!
But even in the pdf you coppied are five (5) equations not just the one quoted initially. But you must consider all of them to get the right picture.
Particularly with EDFs your concern is mainly thrust, and for that you need a bit more than than just the fan laws!
To give you a bit more to read have a look at
http://www.rcgroups.com/forums/showthread.php?t=536911
Have fun with fans
KRS
btw. what do you actually mean by "confuse readers with dribble" ?
Rudi3000 is offline Find More Posts by Rudi3000
Old Jan 12, 2012, 12:52 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Since the difference in area is only ~38% for 80mm fan cut down from a 90mm fan the difference between them is only ~38% of the amp load, If the 80mm is pulling 100 amps the 90mm will be pulling ~138 amps. This is all things equal except fan swept area.
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 12, 2012, 02:07 PM
bobbit4447's Avatar
Joined Oct 2011
Eric
My reference was made to geometrically similar fans.
The discussion on cut down fans is on another thread.
Bob
Old Jan 12, 2012, 02:08 PM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
But that's only applicable if the load on the fan is constant across its radius, which it isn't (twist and speed are different). It's probably a decent enough ballpark assumption though if you err on the side of caution.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Jan 12, 2012, 02:10 PM
egall232 is offline
Find More Posts by egall232
England/uk
Joined Oct 2007
cs 90 mm
Hello,
Well some good news my CS fan will be staying in my L39.I had a re think on how to loose some weight,by changing the rear mounted elevator servo, moving the fan forwards enabling me to shed some nose weight and use a smaller rx batt.
I also had a play around with the motor timing and changed my lipos to some new 45c ones getting me an extra 200 watts.I had two flights today and its a lot better with ample performance and the great sound,
cheers Euan..
ps lads stop all the high brow testing/arguing and actually stick it in an airframe you will love it
egall232 is offline Find More Posts by egall232
Old Jan 12, 2012, 02:59 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by egall232 View Post
...he high brow testing/arguing and actually stick it in an airframe you will love it
lol...everytime I bring out the airframes I want to "stick" it into I ended up flying them...
Damn this hobby is addictive..
erh7771 is offline Find More Posts by erh7771
Old Jan 12, 2012, 04:02 PM
Rudi3000 is offline
Joined Aug 2011
It looks as if the same misconceptions reappear every five years or so, because there is no continuity of knowledge.
Certainly the load on the fan accross it's radius should be constant. It must be the aim of the designer to achieve this as well as possible in his search for efficiency. But then I think that you don't want to design an EDF.
On the other end, how do you want to judge the quality if you don't know the desgn principles?
BTW, I don't agree with the majority here, that the CS90 is a "clone" of Stu's fan, because the characteristics of Stu's "original" have been used long before, i.e a large number of individual blades fitted to a hub and the use of "scimitar" shape blades with a “hook” at the tip.
KRS
Old Jan 12, 2012, 04:29 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
That is because reading is different than understanding.
scatsob is offline Find More Posts by scatsob
Old Jan 12, 2012, 04:37 PM
Rudi3000 is offline
Joined Aug 2011
Do you say that the newer members of RCG are stupider than in the past?
KRS
Old Jan 12, 2012, 04:57 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
KRS
Not at all, just a comment from observations during my education and in my professional life that happens to apply here as well. A generality if you will, reading about a concept is a lot different than understanding the fundamentals behind them. I guess I was not really speaking to timelines of misconceptions.
Old Jan 12, 2012, 06:20 PM
rabone is offline
Find More Posts by rabone
United Kingdom, England, North York
Joined Oct 2010
heres a 12 Blades 90mm EDF sounds good and looks good to me for just $40 lol you have to see the landing thow its brill
heres the link to buy one
http://www.xtremepowersystems.net/pr...?prod=CS90-8mm
L-39.wmv (2 min 59 sec)
rabone is offline Find More Posts by rabone
Old Jan 13, 2012, 01:23 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
Actually, I do understand.
The most efficient fan, much like any aerofoil, will have an elliptic loading, to give the best lift to drag ratio (in this case equivalent to thrust vs shaft power required). This is always the case as the tips cannot carry any load by definition, so you can never achieve a constant load across the fan.
The closer to it you try to get, the more thrust you'll get, but it won't be as efficient by definition as you'll have changed your oswalds efficiency factor (or whatever the equivalent term is in fan design).
Old Jan 13, 2012, 07:17 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
X-Flight now sells just the 8mm adaptor for about $10.
http://www.x-flight.com.hk/index.php...=&lang=en&ev=#
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
