Old Oct 10, 2011, 06:59 PM
Flip Flop is online now
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
New Product
Change Sun 12 blade 90mm
Hey guys, just thought I would share this. The guys a X-flight sent me the new Change Sun 12 blade 90mm edf thats going to be coming soon. I tested it with the HET 700-60-1485 motor on 4000mah 8s. It pulls about 105 amps and is alittle over 3000 watts with the thrust at 7lbs installed in my Sniper 90. Before I had the HET 90mm unit with the arc 36-75-1 motor in my Sniper and it put out a little more thrust but I think the top speed with this CS unit was a little better. Here are some pics. Oh and the sound is great, I think im gunna leave this one in.
Flip Flop is online now Find More Posts by Flip Flop
Old Oct 10, 2011, 07:02 PM
Flip Flop's Avatar
Joined Oct 2009
HET sniper 90 (3 min 14 sec)
Change Sun 12 blade 90mm (2 min 38 sec)
Here is some video. Sorry about the poor quality, is was my first attempt at posting a video, and my wifes first at filming a jet video.
Old Oct 10, 2011, 07:27 PM
lightningmcnul is offline
Find More Posts by lightningmcnul
USA, CA, Marina del Rey
Joined Jul 2010
That looks great, when and how much?
lightningmcnul is offline Find More Posts by lightningmcnul
Old Oct 10, 2011, 07:29 PM
eaticus is offline
Find More Posts by eaticus
eaticus's Avatar
Everett, WA
Joined Aug 2002
What he said...
Also, Did the 10 blade 70mm ever materialize?
Dave
eaticus is offline Find More Posts by eaticus
Old Oct 10, 2011, 07:34 PM
Flip Flop's Avatar
Joined Oct 2009
Originally Posted by eaticus View Post
What he said...
Dave
supposedly the 70mm is in production, and the 90mm is also. They also have a 120mm that is still in the testing phase. I will send another e-mail to Rocky at X-flight because I am needing to get two 70mm for a A-10 and possibly two more 90mm's for a F-14. They take a few days to get back, but always return e-mails. I will let you know if I hear anything.
Old Oct 10, 2011, 08:33 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
the rotor bares a striking resemblance to a world known high end edf producer......
sounds great...
sadly, looks like a rip off rotor.
id be interested in a 120 for sure though.
corsair nut is offline Find More Posts by corsair nut
Old Oct 10, 2011, 08:57 PM
Flip Flop's Avatar
Joined Oct 2009
sounds great...
I know it does look alot like a new high end 90mm edf, but it is slightly different with a whole extra blade and slightly different shape. People that can afford that one will still buy it and be very happy, and people who cant that want a similar sound will be able to buy this one. So I think in the end everybody will win, the new trend nowadays is more blades with better noise so with more competition we get better products.
Old Oct 10, 2011, 09:02 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
looks like the shaft adapter is different, is it a better design than the 5 blade 90mm. did you have to balance the fan or did it come to you balanced
jcdfrd is offline Find More Posts by jcdfrd
Old Oct 10, 2011, 09:08 PM
Flip Flop's Avatar
Joined Oct 2009
It did come balanced, and the shaft adapter does look better. I had a lot of problems with my CS 120mm shaft adapter, it ended up ruining the bearings in my motor. I just got back my replacement and it seems they have fixed the problem.....I hope.
Old Oct 10, 2011, 09:19 PM
Flip Flop's Avatar
Joined Oct 2009
here's another pick of the 90 and 120mm.
Old Oct 10, 2011, 09:21 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
7pds installed is not bad, looks like it is pulling more than the Wemo or Haoye 6 blade rotors and about the same as a Sickle (rcmart) DF90.
I loved the sound of the 70 and 90mm Sickle DF90s when spun up using heli mode on my esc, sounded EXACTLY like a turbine starting up. Had to stop using them cause they through blades like you wouldn't believe due to blades not be Fiber enforced and the clubs strip having dirt on the sides.
Can you tell if these blades are fiber enforced?
That would be great if they are, putting 9 - 10pds of thrust through them wouldn't be such an ordeal.
erh7771 is offline Find More Posts by erh7771
Flip Flop's Avatar
Joined Oct 2009
Here is the first flight with the new fan unit. Again sorry about the quality.http://www.youtube.com/watch?feature...&v=YIPz2L2_Arg
Old Oct 10, 2011, 09:25 PM
tehachapi, CA
Joined Jan 2006
that 120 unit sure has alot of pitch! :O
Old Oct 10, 2011, 09:27 PM
Flip Flop's Avatar
Joined Oct 2009
From what I am told they are fiber reinforced, the blades and shroud are very stiff and solid. I would like to try the HET 700-83-1080 on 12s, with a blast shield of course.
Old Oct 10, 2011, 09:29 PM
Flip Flop's Avatar
Joined Oct 2009
I agree. I am curious on what it will do though.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
