Old Oct 09, 2011, 04:10 PM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
Build Log
Flexacopter ---The Making Of---
New project for a Heavy-Lifter camera platform.
The objective are,
Multiple system use, such as, Mikrokopter with the V2.0 ESC's / OpenPilot / KKuk / and others.
Hexa setup, + and X mode.
5S setup with one 8000mAh lipo for long efficient flights.
Easy removable 20mm carbon arms with integrated power and led plugs for easy transportation in a custom case with foam padding.
Carbon 180mm frame and carbon supports for the Avroto 2814 short shaft motors.
Compact Wire Rope Isolators (diy) + gel dampers for max vibration damping.
Diy roll/tilt gimbal (AV-200 look alike).
Good looks!!
Dimensions test for the MK V2.0 ESC's mounting holes,
Production of the Avroto supports in 2,5mm carbon,
Flexacopter (1 min 10 sec)
The results,
First test model of a diy Compact Wire Rope Isolator, tests show a vibration reduction of 70% with 500g load,
holco is offline Find More Posts by holco
Old Oct 09, 2011, 10:00 PM
blindflight is offline
Find More Posts by blindflight
blindflight's Avatar
CA
Joined Dec 2003
Very nice job , what are you using on the tubes to connect to the motor mounts?
blindflight is offline Find More Posts by blindflight
Old Oct 09, 2011, 10:07 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
good show.
nice work
witespy is offline Find More Posts by witespy
Old Oct 09, 2011, 10:08 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
very nice work so far, i like that cable isolation idea
they look like heli boom mounts or some other 2 piece clamps for other multi helis.
derk is offline Find More Posts by derk
Old Oct 09, 2011, 10:26 PM
SirFishaLot is offline
Find More Posts by SirFishaLot
SirFishaLot's Avatar
USA, VA, Richmond
Joined Jan 2011
no kidding....I think he was looking for specifics. i.e. Where to get them.
SirFishaLot is offline Find More Posts by SirFishaLot
Old Oct 10, 2011, 01:30 AM
Estiavilla is offline
Find More Posts by Estiavilla
Taka
Joined Dec 2010
Any chance it will be for sale ?
If price is reasonable, pls reserved one set for me.
PM me the price.
Estiavilla is offline Find More Posts by Estiavilla
Old Oct 10, 2011, 02:13 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
Nice, it look like you are using logo tail boom mounts.
I did not understand clearly what is this for "Compact Wire Rope Isolator" where does it used.
keep update your process please.
caotri is offline Find More Posts by caotri
Old Oct 10, 2011, 02:49 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Thanks Guys for the nice responses
This project is in real time, so where it will bring us is like looking in a crystal ball
There is a lot going on in our heads and we can promise you guys that this will be a great looking hexacopter, build with the best materials we can find and diy solutions never seen.
Regards,
Pieter Jan & Mario
Old Oct 10, 2011, 12:27 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
20mm booms, so they must be from a Logo 400. Part number MIK4232
Photoship One is offline Find More Posts by Photoship One
Old Oct 10, 2011, 04:11 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Some pictures.
Old Oct 10, 2011, 08:21 PM
kosins is offline
Find More Posts by kosins
Consistently Inconsistent
United States, OH, Dayton
Joined Feb 2011
Now I'm depressed, and I hate my scroll saw. Thanks a lot.
By the way........Nice work!
kosins is offline Find More Posts by kosins
Old Oct 10, 2011, 08:39 PM
Matt Chester is offline
Find More Posts by Matt Chester
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
Originally Posted by holco View Post
Some pictures.
Wow. That is a great looking hexa. I want a set of these? How much?
Matt Chester is offline Find More Posts by Matt Chester
Old Oct 11, 2011, 04:20 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
To estimate the power and efficiency of the Avroto M2814 motors I did some testing on 5S with an Graupner E-11x5 prop.
The test I did was with an 15x15 square alum tube, so the numbers will be a little negatief because round tubes are more efficient
(less bouncing back from the prop down wash), because of this there will also be less vibrations coming from the booms.
The Flexacopter flying weight without camera bud with an 5S 8000mAh lipo will be +/- 3100g divided by six = 517g for each motor
with an extra payload of 1500g (heavy DSLR) the numbers for each motor will be 767g.
So the numbers we are looking for are, 517g and 767g
From 87 > 98 sec at the time line you can see the 500g test and the red line indicate that we are pulling 3A multiplied by six = 18A total with 3000g flying weight.
From 137 > 145 sec at the time line you can see the 800g test and the red line indicate that we are pulling 5,8A multiplied by six = 34,8A total with 4500g flying weight.
80% from the 8000mAh lipo give 6,4Ah usable energy, this will give a flying time of 6,418=0,35h 0,35x60=21min flying time with 3000g.
6,434,8=0,18h 0,18x60=10,8min flying time with 4500g.
Not important bud nice to know is that the total lift power of the six Avroto's is 13,8Kg (3200W!!), so plenty of headroom.
Avroto M2814 (2 min 39 sec)
Old Oct 11, 2011, 04:55 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Wow!!!
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Oct 11, 2011, 10:48 AM
Newnan, GA
Joined Oct 2002
Can you tell me more about that wire rope isolator? Got any footage or test data like your motor calcs?
Discussion Anyone tried making frame legs from this? NDw Multirotor Talk 0 Sep 08, 2011 06:35 AM
Help! A-10 making funny sounds. Scary! kosmik003 Electric Plane Talk 4 Sep 08, 2011 03:17 AM
Discussion DX8 - making a screaching noise???? jongp Radios 2 Sep 07, 2011 10:13 AM
Discussion Making tires.... spinnetti Scale Kit/Scratch Built 10 Sep 06, 2011 11:27 AM
