Old Oct 09, 2011, 10:22 AM
JimHSoars is online now
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Wing Tip Design
NB Formerly titled Droop or Drooped Wing Tip Design
Howdy Folks:
I would like to use the drooped tip design. From what I've found out so far it gives the wing/airplane a lower stall speed. Its use on the A-10 ground support airplane is said to give it very good loiter ability. The drooped tip is mentioned in the Wingtip device Wikipedia article where it is called a "Hoerner Tip", but I believe that is a misnomer. There is a drawing of the drooped tip lower down in this "Anatomy of a STOL Aircraft" article:
Unfortunatly I can not find the design parameters. Would any of you in RCG land know where this information is?
- Jim
JimHSoars is online now Find More Posts by JimHSoars
Old Oct 09, 2011, 02:33 PM
alphamax is offline
Find More Posts by alphamax
netherlands
could this be the original report? http://oai.dtic.mil/oai/oai?verb=get...fier=ADA800374
this might help a little http://www.sigmfg.com/BuildManuals/SIGRC66WonderP1.html
alphamax is offline Find More Posts by alphamax
Old Oct 09, 2011, 02:47 PM
mrittinger is online now
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
I've used them on several designs, and they do haelp a great deal with vortex control and lift at lower speeds.
I've compared my Super Sportwin with Denny Sumners, which used a tapered tip, and it does seem that mine has a good bit longer approach, especially in ground effect.
The A10 uses a similar design....
Tip plates, which are much easier to make and cover, do the same thing , just to a slightly less efficient level.
Mark
mrittinger is online now Find More Posts by mrittinger
Old Oct 09, 2011, 03:31 PM
Lacquerhead is offline
Find More Posts by Lacquerhead
Wood Chucker
Lacquerhead's Avatar
USA, TX, Allen
Joined Nov 2009
As an aside it's literally been decades since I looked at the wingtips of an A-10 so I'm a bit curious about what they've added as far as equipment. Any idea what the equipment bays are used for? I assume they're some kind of AWS or CM pods but I honestly have zero idea.
Lacquerhead is offline Find More Posts by Lacquerhead
Old Oct 09, 2011, 04:13 PM
Joined Jun 2003
alphamax, how on earth did you find the old military document?
Thanks for the post.
Mark those are great pictures of the A10 wing tip. I have been trying to work my way through your Super Sportwin thread and missed the drooped tips. Thanks
- Jim
Old Oct 09, 2011, 07:05 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
I believe the fairings are for Chaff and Flare dispensers
invertmast is offline Find More Posts by invertmast
Old Oct 10, 2011, 12:44 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Hoerner actually recommended a tip where the top surface was flat and the underside curved up to meet it, along with a straight TE with a 90 deg corner formed where the tip intersected. He tested downswept tips and found them to be less efficient than a simple square cut tip.
I'm not sure where the A-10 type tip originated from? I believe they were available as aftermarket fitments for light aircraft and sold under the name 'Hoerner tip' but I'm not sure that Hoerner had any part in their development? Also I'm unaware of any actual scientific testing by anyone that indicates they have any advantage?
As for the A-10's long loiter capability. I think you may find that's mainly due to it's high efficiency turbofan engines, plus it's big wing with it's high lift airfoil, and not least it's good fuel capacity.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Oct 10, 2011, 09:14 AM
Wood Chucker
USA, TX, Allen
Joined Nov 2009
The Wikipedia article on Wingtip Devices says that Dr. Hoerner published a paper in 1952 where he talked about drooped wingtips. Another article I read said he was a principle designer of the Feisler Storch which obviously placed huge emphasis on low speed flight. Yet another article cites him as the originator of the 45 degree bevel we know as Hoerner tips and see on many, many light aircraft such as Piper Senecas, Cherokees, etc. I don't think you'd be remiss in calling either of them a Hoerner design but the Hoerner tip is usually thought of to be the beveled tip we see frequently.
BTW, those drooped tips look absolutely dead sexy on Mark's Super Sporttwin.
Old Oct 10, 2011, 12:39 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Those tips do what the drawing in the original post of this thread shows ie push the tip vortex down and outboard. This doesn't do very much in cruise but i does increase ground effect which is very helpful to an overloaded plane.
--Norm`
nmasters is online now Find More Posts by nmasters
Old Oct 10, 2011, 01:06 PM
Brandano is online now
Find More Posts by Brandano
They must have some form of noticeable effect, I guess. The A10 was designed with the minimum possible amount of complex curves, so that it could be easily repaired on the field using sheet metal. The wingtips are a pretty complex shape when compared to the rest of the plane.
Brandano is online now Find More Posts by Brandano
Old Oct 10, 2011, 01:30 PM
Aberdeen
Joined Mar 2006
The article was linked earlier: http://www.dtic.mil/cgi-bin/GetTRDoc...c=GetTRDoc.pdf
It makes no mention that i can find of drooped tips. The recommendation is tips with a up-swept lower surface, similar to the 45 deg beveled tips you mention.
The only mention I can find of drooped tips is in reference to a lecture given by Eppler in 1987. According to the document i have Epper said that in terms of induced drag drooped tips were 10.2% worse than simple square cut tips and 11.3% worse than up-swept tips... Which makes drooped tips look pretty bad
Old Oct 10, 2011, 02:57 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
As above, I consider a Hoerner wingtip to be one with a curved, upswept lower surface, the idea being, as I understand it, to minimise the tip vortices by reducing the thickness of the tip to virtually nothing.
http://metcoaire.com/technical/tech_...r_design.shtml
I wonder if the notion behind the downward curving tips is to have a similar effect to winglets, but without the dihedral effect?
MCarlton is offline Find More Posts by MCarlton
Old Oct 10, 2011, 03:12 PM
Wood Chucker
USA, TX, Allen
Joined Nov 2009
First let me say I'm not an aerodynamicist though I pretended to play one once in front of the TV. As I understand it, the drooped tips help contain high pressure at high alpha. I believe the idea is to contain high pressure and keep it from spilling over the tips to improve stall behavior.
Old Oct 10, 2011, 04:07 PM
Joined Jun 2003
Mark Rittinger's anecdotal report above supports either lower drag at low speeds or greater ground effect mentioned by Norm. Mark also mentions using droop tips in his Super Sportwin build thread in post #161 and post #765 where he states he once researched them.
In Model Aircraft Aerodynamics by Simons there is a photo of Dr. Eppler launching a little balsa glider with one up and down winglet in a classroom. Because it swerves toward the down winglet he states that proves it has has more drag than the up winglet.
(The balls in your research court now Mark.)
Jim
Old Oct 10, 2011, 04:19 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
If anyone has a reference for Hoerner suggesting to droop the wingtips, I would like to see it. This is what I found with a quick google search for a Hoerner wing tip
http://images.rcuniverse.com/forum/u...90/Us54843.gif
In his 1965 book "Fluid-Dynamic Drag" he talks about how there are two separate vortex sheets that leave the tip, one from the top surface and one from the bottom. They "roll up" and merge as they leave the wing tip. He presents several different wing tip shapes that were experimentally tested, and it seems as though the sharp tips do the best.
DPATE is offline Find More Posts by DPATE
Discussion NASA Safe Wing Droop kevin matthews Free Flight 31 Apr 09, 2016 06:54 PM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 10:24 AM
Discussion Wing tip design THend Sailplane Talk 47 Apr 30, 2007 10:24 AM
Question F-104 Wing Design Twist & Tip Stall? RetroFlight Fuel Jet Talk 3 May 06, 2006 10:52 PM
