Brasil, SC, Jaraguá do Sul
Joined Sep 2011
Battery for SH-8829 - help needed
Hello
I am new here, also new to rc world, and need a little help. i have a RC Helicopter SH-8829 , wich uses a 7.4V Lipo battery. The Original Battery is part number 8829-12 available at 600mah or 800mah, 600mah comes with green package, 800mah comes with blue package. I received the 800mah blue package. Size is 60mm x 30mm x 12mm , Weight is 45g Printed info over the battery says: - TY - 553060 + 7.4V 800mah 1AA ![]() Will the Rhino 2s 7.4v 610mah Battery from Hobbyking fit for it? Looks like the size is perfect and weight is less also. Not sure about the discharge rate, since i dont have this info from original battery. ![]() http://www.hobbyking.com/hobbyking/s...idProduct=7305 Someone said me that Rhino batteries are good, and it will be probably better to get the Rhinos instead of the original ones. Thanks in advance, and sorry if my english is not perfect.
what is more important is the "C" rating. the Rhino is 20C, meaning with 610, it can put out approxiamately 12amps... your original is 800mah, but it does not list a "C" rating. Most likely those cheap generic original lipos are 10-15 C rating...probably 10-12 amps... I'd say you'll be fine with that Rhino. BTW - most of the original stock lipos are cheap and overstate their capacity, so that 800mah is probably really more like 650-700mah anyhow. |
| Thread Tools | |
| New Product SH 8829 4 Channel 2.4GHz | Il Ferro | Coaxial Helicopters | 26 | Apr 15, 2012 10:01 AM |
| Wanted PLEASE GUYS HELP ME-NEEDED Retracts for my Pattern Plane, PLEASE HELP | mechengineer03 | Aircraft - Electric - Miscellaneous (FS/W) | 9 | Apr 14, 2011 08:53 AM |
| Discussion Help needed regarding battery charging? | hicks451 | Electric Power Cars | 2 | Mar 08, 2011 02:17 PM |
| Discussion SET UP ADVICE NEEDED...ESC and battery for my Hotliner....HELP???? | imaslob | Power Systems | 3 | Apr 02, 2009 10:46 AM |
| Help! What battery pack design needed for Twinstar? | JohnSoPA | Foamies (Kits) | 4 | Jul 11, 2004 05:47 AM |
