So I finally got around to starting the build. It’s going to be a slow one; in 48 hours all I managed to do was get one wing half's control surfaces installed and servos installed with the linkages.
The first thing I did was to install the servos in the provided hatches. This is only the second time I have done this and the first time I used epoxy for the servo mounts and that was a little overkill. This time I set servo in place with the mounting blocks on the hatch and used thin CA to tack the blocks in place. After they were tacked I took the servo out and used thin CA to seal the deal. I then hooked the servos up to a receiver to make sure they were centered and mounted the control horns. After that I screwed the servo onto the blocks and they were ready to go.
Like most ARF's similar to this one (CMP, et. al.) the hinges are the CA type, which does not come close to cutting it I’m my opinion. I just don’t want to have to worry about something like a control surface letting loose in flight, so ever since I started this hobby I have been using DuBro pin hinges and epoxy. The aileron is pretty small so I used three hinges, easy day. The flaps were kind of interesting. They come pre-hinged with large flat pin type hinge but they are soft and not very high quality. Again I replaced them with three of the pin hinges. The flap itself is one solid piece of wood so I was just extra careful of the bit orientation and depth as I drilled the holes for the hinges. It actually made for a clean install for a split flap, I am happy with the results.
The hardware that came with this kit is actually decent. The control horns are 3mm screws with washers on each end. For the flaps they have you using one of the raised washers but if you use that you would have to dig a hole in the wing for the flap to close all the way. What I did was use a regular washer and countersink it into the flap and it closes without a problem.
The last thing I did was to hook everything up and center the ailerons and set the endpoints on the flap. The picture shows the max deflection, and it looks like plenty for now.
With Thanksgiving coming up and some leave I am taking I’ll have five days off so maybe I can get the other wing done
. I really wish TBM would get the electric retracts for this bird in so I could finish off the wings. The rear spinner is on its way from Zinger so when that get in I can finish up the motor and do a full power run-up. I also have the servos for the elevators on their way from HK so I can start on the tail when they arrive. It’s going to be a slow but fun build, stay tuned.
