Old Nov 06, 2011, 08:33 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Nope, won't be flying this one without retracts. I'm trying to get away from that but its expensive I'm also not so sure that it would be easy to plumb them in later on, thats the main reason. I'm in no rush, and it's been fun playing around with the motor.
So I couldn't resist and got the motor mounted up. It looks good. I will calll Zinger tomorrow for the 4.5" spinner and once I get that I can finalize the location. Here are some pics.
scatsob is offline Find More Posts by scatsob
Old Nov 06, 2011, 08:56 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Delta
Joined Oct 2006
Looking good!
Randy
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Nov 07, 2011, 05:44 PM
TripleW is online now
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Cool Scott! Thanks for the pics! Walter
TripleW is online now Find More Posts by TripleW
Old Nov 07, 2011, 07:38 PM
Onward and upward.
Joined Oct 2006
Wow Scott,
if this keeps up, I'm going to have to build one! I think it will be the Seafang though as I love the Navy birds. Although, the Mk 47 Seafire looks pretty good also. Tough choices.
Randy
Old Nov 07, 2011, 09:05 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I got the bearings today and installed them. They are MUCH smoother than the stock bearings. The install is pretty easy. You just pop out the old ones and pop in the new ones. The relatively hard part is getting the new ones in without damaging them. On my Turnigy 5065 I dented one of the covers but it doesnít seem to affect bearing function so I am going to leave it. On this motor I was nobodyís fool and found something that covered the whole bearing while I tapped it in. Finally, I ordered a thrust bearing for the front bell to push against instead of just a collar and two bushings. Canít wait to run it up.
Old Nov 07, 2011, 09:08 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Originally Posted by Pilatuspc12 View Post
Wow Scott,
Randy
I love the Mk47 also, beautiful plane. Seagull has one I think that would be a good size for this motor, however I donít think anyone in the US carries it. And it does not have the Griffon blisters on the cowl, MAJOR party foul.
Old Nov 08, 2011, 10:35 AM
Bloodhound is offline
Find More Posts by Bloodhound
Joined Apr 2008
Do you have any links for the new bearings? I recently ordered the same motor from HK and i plan to replace the bearings too.
Thanks.
Bloodhound is offline Find More Posts by Bloodhound
Old Nov 08, 2011, 11:13 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I purchased the bearings from BOCA, great people to do business with and offer reasonably priced quality bearings. The two shaft bearings are 6mmx13mmx5mm I believe and the thrust bearing is 6mmx12mm. I will double check this evening.
Old Nov 08, 2011, 02:47 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Thanks.
BTW, let me know if you have any questions on the motor. I have ripped it apart quite a few times and if you run into a problem chances are I have probably delt with it already.
Old Nov 10, 2011, 12:19 AM
Orvis is offline
Find More Posts by Orvis
Leduc, AB, Canada
Joined Oct 2008
Scott,
This is why I'm very interested in your build; I have the Seagull Seafire.
The Griffon blisters shouldn't be a big deal; some vacuformed parts will solve that.
Cheers,
Peter
Orvis is offline Find More Posts by Orvis
Old Nov 10, 2011, 12:43 AM
Joined Apr 2008
I'm still waiting for the package, but i'm sure i'll have quite a few questions once i start working on the motor.
I'm very interested to see some test data. I plan to use the motor in a 5kg pattern model, aiming at 3000W input power. Will try 8s/motor on 16x10 MA props, but ideally i'd like to use 5s/motor with 20x13 APC propellers.
Old Nov 10, 2011, 05:12 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Peter- I know the blisters wouldnt be a huge deal, unfortunately for me I'm not at the point in my life where I have the time or resources to do much custom work. Once my four kids are a little more grown up that should change.
BH-I am hoping that with the MA props on 6 cells Ill get 3Kw input power. On 8s im pretty sure it will be closer to 4Kw.
Im trying to get a PC power supply to convert and once I do Ill get some batteries charged and see what she can do. Luckily I also have two wattmeters so I can actually get input power to both motors at the same time.
Old Nov 10, 2011, 09:06 PM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
I have been reading this thread subscribed.
doc993 is offline Find More Posts by doc993
Old Nov 13, 2011, 06:18 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Sorry for the slow progress guys, it will probably continue for the rest of the build. My holdup right now is the power supply. I have not had good luck with the computer units I have converted so I am going to buy the 350 wattt one from Hobbypartz. Once I get a supply I will run the motor up as soon as humanly possible and try my best to post a video.
I also found a servo that I think will work. Itís a Tyrnigy digital that gets good reviews and is good for 75 oz-in at 6 volts. Itís also tiny so balance shouldnít be an issue.
Old Nov 13, 2011, 08:39 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Scott have you seen these?
http://www.wingspanretracts.com/LGM695
Discussion 36" spitfire Mk 1X thread build giveitstick Electric Warbirds 4 Oct 24, 2010 05:59 PM
Build Log Spitfire Fr MK XIVe fest 09 build joemach1 Slope 128 May 06, 2009 05:36 AM
Build Log 32" span Mk Vb Spitfire- "Prinses Beatrix" build rcminiman Scale Kit/Scratch Built 19 Nov 23, 2006 10:50 AM
Discussion Plans or kit for the bubble canopy Spitfire mark XVIII or XIX peterpont Fuel Warbirds 5 Sep 14, 2006 06:00 PM
Finished Depron CD-Rom PR MK-XIX Spitfire mtflyr Foamies (Kits) 20 Aug 20, 2004 10:42 AM
