Old Aug 09, 2012, 07:05 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Jut got this rare kit last weekend,so not build thread yet. But, there will be one!
The Model Merchant MB5 was a nominal .60 size glow model...sure wish there was something a little smaller than the main motor subject of this thread, but I might still go with it and adjust the prop choice, if possible, to get the model to have around 120-150 watts per pound, or perhaps around 900-1200 watts total.
Would prefer a 6S option, or even some setup with two 3S packs, but we will work with what we have to work with.
Didn't someone do something set up a bit like the old Byro drive where you could use one outrunner, with a power takeoff off the back of the outrunner using a belt and off the front using a gear and concentric shafts? Using a belt at the rear makes that shaft turn the same as the case of the outrunner and using a spur and pinon gear at the front makes that shaft turn the opposite direction.
Not as elegant as two outrunners, but might be easier going this route to get the exact power system and power levels I need.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Aug 09, 2012, 07:11 PM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Check out the himax contra rotating motors, I think there are 4 in their range. I have a funny feeling they are missing something around the size you are looking for though.
The other option us to just have a prop spinning in a bearing, not connected to the drive.
aerophilia is offline Find More Posts by aerophilia
Old Aug 09, 2012, 08:09 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Already checked out the Himax series...the big one is too big and the next one down is still around 2000 watts, which is more than I need. The middle one of the five is 800 watts and a little too small for what I need. I need one that is at least 1200-1500 watts.
But, the second largest one might well serve propped down to draw around 1200-1500 watts. I got such a steal on the old MB5 kit (50 bucks, missing a couple of minor parts), I could go for a $350 motor if I had to.
I would rather fly it on one prop and skip the freewheeler than have a freewheeler.
Old Aug 09, 2012, 10:43 PM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
I had the same problem. They need that motor in the middle! I erred on the side of caution and got the bigger one
Old Aug 12, 2012, 05:53 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Originally Posted by Thomas B View Post
Some very nice work in this thread!
I recently scored a long sought after kit that this info might be quite useful in.
Many years back, around 1979, Model Merchant produced a .60 glow power almost ready to cover kit of the Martin Baker 5, from the Dan Parsons design.
I actually got to fly Ted White's very nice MB 5 from this kit in the early 1980s. He used to campaign one in the local scale competitions. A superb flying model.
Built up balsa fuse, assembed and mostly sanded out...call it 90-95% done. Balsa covered foam wings and tail surfaces.
This motor might do the trick, although it is a little large and heavy for this particular model.
Oh man, it would be blasphemy not to contra an MB5 . I agree that it is too bad that no one makes something in between the motor mentioned already. Depending on the wing loading desired you could try one of the larger motors as you mentioned. I think the CR50 with 14" props would give you 1200 watts or so on 4-5 cells. How big is the spinner on the MB5?
scatsob is offline Find More Posts by scatsob
Old Aug 13, 2012, 06:53 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I was unfamiliar with the MB-5.
So here is a link for dummies like me!
http://en.wikipedia.org/wiki/Martin-Baker_MB_5
TripleW is offline Find More Posts by TripleW
Old Aug 13, 2012, 11:37 PM
mackone is offline
Find More Posts by mackone
"the bouncer"
mackone's Avatar
Australia, VIC, Vermont
Joined Nov 2006
It very similar in profile to the CAC CA-15
http://en.wikipedia.org/wiki/CAC_CA-15
mackone is offline Find More Posts by mackone
Old Aug 17, 2012, 06:36 PM
Basingstoke Roy is offline
Find More Posts by Basingstoke Roy
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
Hi all
If you want to know a bit more about the MB5 I've added some more links below.
http://www.martin-baker.com/about/mb1-mb5
unfortunately they seem to have removed the link to Mr Martin’s Memorable M.B.5" – A Reprinted from Air International, 02/79. A very good piece on the history of the MB5, I may still have the file some ware, if I can find it I will PM it to you (but it wont be for a couple of weeks).
Also look out for the book, "Sir James Martin: The Authorised Biography of the Martin-Baker Ejection Seat Pioneer"
Here's my take on the MB5 & a how to build your own 1400W 4cell motor
My TCM3.1 contra motor
My1/8th scale MB 5
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Dec 15, 2012, 04:32 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Any news Scatsob? I see ESM have brought out Generation 3 of their retracts......
Old Dec 15, 2012, 05:23 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
This project was for sale awhile back.
Here it is.
http://www.rcgroups.com/forums/showt...ht=esm+spitfir
Old Dec 15, 2012, 06:49 PM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Bummer! Thanks for the link TripleW.
Discussion 36" spitfire Mk 1X thread build giveitstick Electric Warbirds 4 Oct 24, 2010 06:59 PM
Build Log Spitfire Fr MK XIVe fest 09 build joemach1 Slope 128 May 06, 2009 06:36 AM
Build Log 32" span Mk Vb Spitfire- "Prinses Beatrix" build rcminiman Scale Kit/Scratch Built 19 Nov 23, 2006 11:50 AM
Discussion Plans or kit for the bubble canopy Spitfire mark XVIII or XIX peterpont Fuel Warbirds 5 Sep 14, 2006 07:00 PM
Finished Depron CD-Rom PR MK-XIX Spitfire mtflyr Foamies (Kits) 20 Aug 20, 2004 11:42 AM
