Old May 02, 2012, 07:20 AM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Did you see this one Scott?
http://www.youtube.com/watch?feature...&v=I_Q5jrV7Ja4
Seriously though the XF-11 would be Awesome! Someone built one recently. I think it was in the scale forum.
Nope it was in the Giant section.
http://www.rcgroups.com/forums/showt...ighlight=xf+11
Hughes XF11 (3 min 47 sec)
TripleW is offline Find More Posts by TripleW
Old May 02, 2012, 04:08 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
That’s awesome! Two of these CR50 motors with some 14" 4 blade props would be slick. I swear you can hear the props cutting the grass as he is taxying out.
scatsob is offline Find More Posts by scatsob
Old May 02, 2012, 06:15 PM
Basingstoke Roy is offline
Find More Posts by Basingstoke Roy
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
Going back to the Gannet.
I don't know if you've come across the tread before, from my country man Rick Vale
http://www.rcgroups.com/forums/showt...1274083&page=8
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old May 02, 2012, 06:41 PM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
I knew I'd seen that model before! Thanks for posting that link Roy. He did an amazing job.
That plane weighs 15 pounds, and the motor is specced at 2050 watts. Although I'm sure you could put a lot more through it as it's very close to the CR50 in terms of its size. Thats measly 136 watts/pound. And the owner says it's still overpowered! http://www.rcgroups.com/forums/showp...&postcount=132
aerophilia is offline Find More Posts by aerophilia
Old May 02, 2012, 07:46 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I have not seen that thread...very cool. A true work of art. One day when I have the time I will build like that, but for now I will be in awe of the people that do. The folding wings are awesome. That motor is exactly the same size as the CR50, 5025. I would love to know how manufacturer’s rate motors. It seems like most can be run well above rated specs without destroying them. I guess they have their reasons.
Old May 02, 2012, 08:10 PM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
I'd like to know how they rate motors as well! That Himax motor does seem well under-rated. I should spin mine up and do some testing. I comes supplied with 15x10 props and they recommend 6S. It is an incredibly well made motor. It seems like the fairy gannet is using the stock props on 5S. So I have asked what amps/watts/props etc are.
Anyway, back to spitfires! Scatsob and I were talking about cooling motors. Here is a setup that is working extremely well in a seagull MXS-R. Just some plumbing pipe to push the air straight onto the motor. Then I have an exit hole at the back of the fuse that is around 3-4 times the size of the inlet.
http://www.rcgroups.com/forums/showp...6&postcount=15
I have also seen people using small 12V computer cooling fans to get some air circulating inside the cowl. Or even adding tabs made from tape to the bell of the motor to create some airflow!
Old May 02, 2012, 09:16 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
That is EXACTLY was I plan on doing with the Spitty. I am going to pipe air from the intake scoop under the cowl and blow it directly on the motor. The exhaust will be through the exhaust stacks. Bob P from accross the pond did the same thing with his and he said it worked great. I just wish the plumbing was going to be as easy as your MXS.
Old May 03, 2012, 04:18 PM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
A wise man once told me if you need a Hurricane to cool your power system your doing something wrong. Just saying......
Tommy D is offline Find More Posts by Tommy D
Old May 03, 2012, 05:47 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Point taken, but I disagree. Most people hang their motors out in the wind where cooling is not a problem. I don’t have that luxury with the spitfire. And we are not talking a hurricane....just a slight breeze.
Old May 03, 2012, 08:44 PM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
Full scale planes have all sorts of venues for channeling air to and around the engine compartment. As do cars and motorcycles, snowmobiles and ......
rossaer is offline Find More Posts by rossaer
Old May 04, 2012, 11:43 PM
Tommy D is offline
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
And if you need that ram air to keep the motor from going south your doing something wrong. You have selected the wrong cell count or kv or prop size or....
Old May 05, 2012, 08:35 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
So you are saying you don't actively cool your motors?
Old May 06, 2012, 05:04 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Just as a matter of interest, I have been in contact with Xoar props the last few days. They make a series of 3 bladed props that are designed for electric setups. And, they have said they are available as a pusher prop! Lightweight, and range from 10" to 32" diameter
http://www.xoarintl.com/props/model-airplane/PJI-E.html
Old May 06, 2012, 05:29 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Man, the only problem I have with Xoar is their propellers are so dang expensive. $72 for a 16x10 three blade.
Old May 06, 2012, 05:46 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Ouch! Didn't think they would be that much. Makes buying 4 to test a little bit prohibitive. And I'm willing to bet that being lightweight for electric setups means they are fragile.
Discussion 36" spitfire Mk 1X thread build giveitstick Electric Warbirds 4 Oct 24, 2010 05:59 PM
Build Log Spitfire Fr MK XIVe fest 09 build joemach1 Slope 128 May 06, 2009 05:36 AM
Build Log 32" span Mk Vb Spitfire- "Prinses Beatrix" build rcminiman Scale Kit/Scratch Built 19 Nov 23, 2006 10:50 AM
Discussion Plans or kit for the bubble canopy Spitfire mark XVIII or XIX peterpont Fuel Warbirds 5 Sep 14, 2006 06:00 PM
Finished Depron CD-Rom PR MK-XIX Spitfire mtflyr Foamies (Kits) 20 Aug 20, 2004 10:42 AM
