Old Jan 07, 2012, 06:52 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Hey Walter, say hi to the guys at the field for me. I actually called them last week and the person on the phone I talked to said that the GEN 2's would be the same as upgrading the GEN 1's...about $200. (GEN 1's plus the board is $200) I will probably just wait until summer when all this is sorted out and make a decision then. The only problem then will be I can either spend $200 on the retracts or $200 on the new PC-21 they have coming out.
On a building note, I got the servos in that I plan on burrying in the elevators so when I start that I will start posting build pictures again.
scatsob is offline Find More Posts by scatsob
Old Jan 08, 2012, 06:51 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Huh, That's not what the youtube video said. I'll see if I can find it tomorrow.
TripleW is offline Find More Posts by TripleW
Old Jan 08, 2012, 09:00 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
If you are talking about the video they did comparing the v1 and v1 with board I have seen it on TBM's website, I just didn't pay attention to what he was saying at the end.
Old Jan 10, 2012, 07:11 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I made some headway with the power system. I finally got the rear rotor to stop rubbing against the stators but it took some persuasion. Weíll see how it runs in the next day or two, and I plan on taking it up to WOT to see that I get. I also got both spinner back plates drilled and mounted. I was going to try to find someone with a lathe to do it properly but that was getting nowhere and I figure Iíll have the time and money to do things properly when I am older. So I just picked the drill bit that was just oversized for the hole in the back plate and stepped up one bit at a time until I got to 12.7mm. Then I used the 12.7mm but to ream out the hole to the 13.2 mm it needed to be. I did the same for the front back plate to get it to 8mm. Here is a picture of todayís efforts. Tomorrow I will cut the blade holes in the front spinner and get that mounted up. Then Iíll put it on the plane and see how she runs ....and looks.
Old Jan 11, 2012, 09:03 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I got everything buttoned up this morning. There is no discernible wobble in the front spinner so well see how it runs. I have it ready to run right now I am just topping off some batteries. I took some pictures with the cowl on to see what the final product will look like and one with the front spinner off for reference. Looks pretty good .
I am a little anxious for the testing. I want the amp draw to be in the 60-70 range but I am worried it is going to be more. I am also worried about the differential between the front and rear motors. I guess if it is substantial then I guess flight time will be driven by the motor that draws the most current.
Old Jan 11, 2012, 10:25 AM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Really exciting and interesting project scatsob. Hope the testing goes the way you want it to.
Chad Veich is offline Find More Posts by Chad Veich
Old Jan 11, 2012, 11:54 AM
MustangAce17 is online now
Find More Posts by MustangAce17
3d and EDF, some scale
MustangAce17's Avatar
United States, FL, Ocala
Joined Sep 2005
so freakin cool!
just love the looks of this bird, can't wait to see and hear it fly
MustangAce17 is online now Find More Posts by MustangAce17
Old Jan 11, 2012, 04:06 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Here is a short video of the full throttle test.
23 volts
65 amps
~3kW total power
CR50 brushless contra-rotating full-throttle trst on 6s (1 min 7 sec)
Old Jan 11, 2012, 04:36 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Cool Scott!
Was the brake on or do those motors stop quick?
You could parallel the batteries so the voltage stays equal.
Old Jan 11, 2012, 04:41 PM
Orvis is offline
Find More Posts by Orvis
Leduc, AB, Canada
Joined Oct 2008
Holy Hanna!! THAT WAS AWESOME!!
Cheers,
Peter
Orvis is offline Find More Posts by Orvis
Old Jan 11, 2012, 04:53 PM
Corsair 29 is offline
Find More Posts by Corsair 29
United States, GA, Newnan
Joined Mar 2008
Cool!!
You know you have plenty of power when eveything in the room starts flying around
Corsair 29 is offline Find More Posts by Corsair 29
Old Jan 11, 2012, 05:11 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Including the Transmitter!!
Old Jan 11, 2012, 05:50 PM
Basingstoke Roy is offline
Find More Posts by Basingstoke Roy
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
No lack of grunt there, looks like your good to go
I do love the sound of a contra, sweet
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Jan 11, 2012, 08:51 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Originally Posted by TripleW View Post
Cool Scott!
I'm actually not sure. The magnets do have a lot of bite. I was thinking about paralleling the batteries for that reason, and the possibility of it being easier on the batteries. Even with the systems being completely separate there did not seem to be much variation in RPM, both optically and harmonically. The sound was truly unique.
I didn't explain much in the last post. The differential in current between the two motors was right around 1 amp, definitely not enough to concern me. When the plane is closer to completion I plan on getting thrust numbers with each prop spinning alone and then both together to see what is going on.
This weekend hopefully I will have time to start the stabs. I marked the location of the CG on the fuselage and the motor and props are so heavy that I should have absolutely no problem getting the CG where it needs to be.
Old Jan 12, 2012, 07:07 AM
Joined Oct 2005
Unless your out to get every last usable Watt out of your set-up, I don't think it matters that much if they are bit out. The important thing is have you enough power / thrust to fly the model the way you want. looking at the video I'd say yes!!
As for the battery pack I always connected mine getter, not only dose it make life easer for the pack, It also helps with keeping both motor together, not having one cut long before the other. Not that I expect you would run the pack down that far.
One big pack driving both motors is the "KISS" approach to my way of thinking. Less to go wrong, with charging & operating.
Discussion 36" spitfire Mk 1X thread build giveitstick Electric Warbirds 4 Oct 24, 2010 05:59 PM
Build Log Spitfire Fr MK XIVe fest 09 build joemach1 Slope 128 May 06, 2009 05:36 AM
Build Log 32" span Mk Vb Spitfire- "Prinses Beatrix" build rcminiman Scale Kit/Scratch Built 19 Nov 23, 2006 10:50 AM
Discussion Plans or kit for the bubble canopy Spitfire mark XVIII or XIX peterpont Fuel Warbirds 5 Sep 14, 2006 06:00 PM
Finished Depron CD-Rom PR MK-XIX Spitfire mtflyr Foamies (Kits) 20 Aug 20, 2004 10:42 AM
