Old Oct 08, 2011, 03:16 PM
N2RYD is offline
Find More Posts by N2RYD
Joined Mar 2005
Converting a Sig Senior Kadet
Hi everyone,
I am starting to convert over to electric after playing with some of my club members planes. I am in the process of restoring my sig senior which is 26 years old at least the wing is.
The plane was powered with a Saito 50, I don't know pick the correct motor leaning toward a rimfire 55, or e-flight power 60. I am I going in the correct direction with these examples?
Also how does on chose the correct lipo battery(5s -7s).
I know I opening a big can of worms but sugestions would be great.
N2RYD(BOB)
N2RYD is offline Find More Posts by N2RYD
Old Oct 10, 2011, 01:09 AM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
You might want to post in the Electric Power Systems thread. Usually, the correct battery will be posted on the motor; the actual number of cells may vary, as it's watts (volts * amps), not just voltage, that determines power.
Cheesehead is offline Find More Posts by Cheesehead
Old Oct 10, 2011, 08:27 AM
Strizzo is offline
Find More Posts by Strizzo
United States, TX, Houston
Joined Jun 2011
there is also a section here dedicated to glow or gas to electric conversions. check out the thread pittspecial has going where he converted a SIG pt-40 he found on the free table at his local club.
Strizzo is offline Find More Posts by Strizzo
Old Oct 10, 2011, 04:48 PM
Brandon M is offline
Find More Posts by Brandon M
Joined Nov 2010
Have a gander at this thread .
And these...
http://www.rcgroups.com/forums/showthread.php?t=700376
http://www.rcgroups.com/forums/showthread.php?t=330307
http://www.rcgroups.com/forums/showthread.php?t=376759
http://www.rcgroups.com/forums/showthread.php?t=233468
http://www.rcgroups.com/forums/showthread.php?t=248081
Or, just try the search function. There are a bunch of threads addressing this conversion.
Good luck on it. Electric conversions are rad!
Brandon M is offline Find More Posts by Brandon M
Sold NIB Sig Kadet Senior Kit tpopweb Aircraft - Fuel - Airplanes (FS/W) 6 Jul 13, 2011 08:05 AM
Sold Sig Kadet Senior NIB Factory Sealed $75.00 stevster Aircraft - Fuel - Airplanes (FS/W) 5 Mar 23, 2011 09:29 AM
Discussion Converting the SIG Kadet Senior Kit to electric? the man Glow to Electric Conversions 7 May 25, 2010 05:32 PM
Need Help Converting Sig Senior Kadet to Electric bobandfrances Power Systems 13 Sep 03, 2004 06:59 PM
Need Help Converting Sig Senior Kadet to Electric bobandfrances Electric Plane Talk 15 Sep 01, 2004 05:16 PM
