United States, NJ
Joined Apr 2012
Please fix your website so I can purchase this. When I hit confirm order (before I enter payment info) I get this
Bad Request Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit. Cookie: Apache=10.73.8.43.1336750763884735; Nevermind internet exploder worked. Why no love for google chrome? edit: +1 for rocking a TH9X. It worked with my dragonlink perfect I'm sure it will be the same with this. |
PS TH9X, with er9X firmware blows away all but the most expensive big brands. I never use my Hitec or Futaba anymore. |
Canada, QC, Vaudreuil-Dorion
Joined Jul 2011
Hey guy's,
I received my Rangelink yesterday and did a quick flight. I only did 2.5km and the failsafe kicked in. On ground test I got 20 meters. I moved the uhf antenna to the back of the plane and moved the gps antenna away from the uhf. I then did a ground test and got 70 meters. How much range should I get from my rangelink? I also ordered a Nagoya na-771 uhf antenna for the TX. Will this make a difference in my range? You can see my uhf setup on my Youtube channel....awenzl Thanks for you help, Alex |
ITALY
Joined Aug 2006
With mine i am doing only 1.5 km! Waiting for a reply from Sid...
ITALY
Joined Aug 2006
Again the same problem like last time (it's the third time in 8 monthes):
ALL STUFF are the same, i didn't change anything on the plane and this morning at 1 - 1,4 km the RTL was engaged... several time and at various altitude i recorded all and you can see part of this flight on this link as you can see after few meters and at different altitude the plane comes back in rtl mode (you can see easily it is in rtl because the camera has a fast move when rtl is auto-engaged since the pan servo is in another position when in auto RTL) Last time, when i sent it back to the producer, Sid told me all was right... but i don't think so. This time i recorded all to show the problem i have....
Could be an antenna or antenna connector problem (check that the Rx antenna
connector hasn't separated from the right angle mount). Could be some onboard source of interference. Could be an external source of interference like a DTV broadcast tower. What's your micro-power range with everything else on the plane powered up normally? ian |
Latest blog entry: My 2012 FPV year in Review
ITALY
Joined Aug 2006
Ian
i replaced both rx and tx antenna. About onboard interference.. it is impossible i flew it for 14 km... same stuff and in the same area! Quote:
Markus |
Again, double check the actual antenna connector on the Rx. The barrel that the mail SMA connector
screws onto, can pull loose on the RL Rx. (I've started adding solder to prevent it). Quote:
Micro-power range test with the Rx powered by itself outside the plane. (Just walk until the light stops blinking and goes out). Then do it again with it installed in the plane and everything powered up. If there's no difference and the MP range is very short, then you've proved that it's an issue with the RL Tx/Rx or their antennas. If there's no difference and the MP range is quite good (40+ paces) then may be external interference. If there's a difference, then it's something on the plane. Just today I discovered why I've been having range issues with my X8. I stupidly assumed that the ezOSD (only new thing on this plane versus all my others) was not itself a UHF Rfi emitter. Turns out the ezOSD current sensor (maybe just mine, I dunno) is a pretty powerful noise source (more than my GoPro and 1.3Ghz Tx put together) and cuts my range severely. Going to have to move Rx to opposite end of the plane, and use the longest coax antenna way out on the wing to fix it, which is a real pain with removable wings. ian |
Routed my longest UHF antenna out to the middle of the wing on my X8,
and my RL micro-power range has increased by about 3x. Still kinda hard to believe the exOSD current sensor is such a powerful UHF Rfi emitter, but I tested with and without, and it's definitely the strongest source of noise. Looking forward to testing in the air. ian |
Joined Jan 2012
dx7s -> rangelink -> sk-720 channel assignments
I'm using the PPM output from the rangelink receiver to control a Skookum SK-720 flybarless controller but somehow the elevator, aileron, and throttle channels are all swapped. The throttle channel is connected to the aileron, aileron is connected to the elevator, and the elevator is connected to the throttle. Anyone have any idea what's going on? I'm connected to the Rangelink Tx through the trainer port on my DX7s. As far as I can tell, I can't change the channel assignments on the DX7s or the SK-720.
My previous setup was using a Spektrum satellite direct into the SK-720 and everything was mapped correctly. |
Italy
Joined Jun 2010
Can you please post a pic of the rx sma plug and what kind of problem it may have? (I looked at it carefully and can't really undestand what can go wrong...) |
ezOSD current sensor is the one I'm having an issue with.
I have not tried any other. Problem is, ezOSD current sensor has the connections for RSSI and the mode switch so can't really use any other. The barrel of the SMA female connector on the Rx is simply pressed into the square block that solders to the board (friction fit). It is possible for it to just pop out, if you overtighten, or in a rough landing.. etc. I found it loose on two of my Rxs, so I've started heating it up and adding a little solder spanning the seam between barrel and square block. ian |
| Thread Tools | |
| Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! | JettPilot | Video Piloting (FPV/RPV) | 21029 | Today 09:46 AM |
| New Product ChainLink UHF Long Range System | siim227 | Video Piloting (FPV/RPV) | 2827 | May 09, 2013 04:13 AM |
| New Product ChainLink--The new UHF narrow band long range system | BEVRC | Video Piloting (FPV/RPV) | 877 | Jan 16, 2013 07:22 AM |
| New Product UHF Long range JR / Futaba module | Hooks | Video Piloting (FPV/RPV) | 18 | Aug 13, 2012 05:46 AM |
| Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range | LTS49 | FPV/RPV - Equipment and Vehicles (FS/W) | 8 | Jul 22, 2011 03:55 PM |
