Old May 23, 2012, 08:39 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by Bauf View Post
I just ordered a Z2 and was wondering about the placement of the rangelink antenna.. would it work if i take a stiff tube to use on the top,so the antenna is straight up,and then let the lower part of the antenna hang loose under the wing?
or will this mess up the signal,if the antenna under the wing bends back under flight?
sorry,im terrible at explaining
You can do it that way, but aditionally also use a drink straw below the wing to also stiffen that part. Since the straw can easily bend back upon landing all you have to do is straigthen it bevor launch.
The turnstyle recommended by Loco is great, but you must be aware that having the tx antenna horizontal also means to have a null to the left and right of your position. This might form a problem with FPV as you are not always fully aware how the plane is positioned in relation to your location.
Markus
markus123456 is offline Find More Posts by markus123456
Old May 23, 2012, 08:43 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Markus
Cheers Markus, I didnt know that. That must be for very long range? .I flown 5kms away with my back to the plane
Locko is offline Find More Posts by Locko
Old May 23, 2012, 08:48 AM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
Markus
cheers, will try a drinking straw Yeah, i saw the turnstyle antenna. Might buy one of those if i get trouble with the RL antenna.
Bauf is offline Find More Posts by Bauf
Old May 23, 2012, 09:02 AM
Registered FPVer :)
Joined Aug 2006
In your back is no problem. The null is to the left and right of you if your tx antenna is horizontal (asuming paralell to your tx as it most likely would have to be based on how RL is constructed). I attached a little "hack" kind of a drawing to ilustrate what I mean.
HTH
Markus
Old May 23, 2012, 06:01 PM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
60cm antenna and radio stand back in stock.
http://www.rcgroups.com/forums/showt...4#post19464076
rangelink set 2 -> 1tx+2rx ($287 shipped+no pp fee)
Sid
sid.huang is offline Find More Posts by sid.huang
Old May 24, 2012, 09:45 PM
pisagor is offline
Find More Posts by pisagor
FPV!
pisagor's Avatar
Joined Feb 2007
hi iam using range link and works well!! Many thanks sid.
I want to ask about binding prothocol. What is the different advange and normal bindig also first i did normal binding today i am trying advange binding. Push the button and waiting second bip and release button and open reciver see the light on the reciver and close transmitter and open transmitter it works well but how can i understand to do advange binding. is it true prothocol for second binding? or rangelink reciver just one time binding and i can't change binding mode?
Sory my english.
pisagor is offline Find More Posts by pisagor
Old May 24, 2012, 10:06 PM
Bill Sanford is offline
Find More Posts by Bill Sanford
Destructive testing expert!
Bill Sanford's Avatar
Bemidji, MN
Joined Dec 2003
Sory my english.
I just ordered a RangeLink with two receivers too. From what I understand, the advanced binding reseeds the frequency hopping table. All units ship with a standard frequency hopping table and advanced binding re-initializes the table with new unique random values. The reason to do this is so that you can fly with a friend who also has a RangeLink and they won't bother each other.
Sid, correct me if I'm wrong.
Bill Sanford is offline Find More Posts by Bill Sanford
Old May 24, 2012, 10:26 PM
Chinglish-funny
Joined Mar 2011
Yes,You are right. and will recalibrate all channels.
Old May 27, 2012, 12:05 AM
Locko is offline
Locko's Avatar
Australia, WA
Joined Oct 2011
Hi guys Ive got 2 Z2, One of them I get 20 meters on micro range test and the other I only get about 10 meters.
The one that I only get 10 meters on, How far range would that be?
Old May 27, 2012, 12:13 AM
Chinglish-funny
Joined Mar 2011
if the same condition, that one got 20m ,sensitivity a little better.
Old Jun 01, 2012, 04:18 PM
nieder2 is offline
Find More Posts by nieder2
Joined Jan 2012
Is anyone using RL with a Turnigy 9X thats powered by 2 X 18650 li-ion batteries? Any issues with usage around the low end of the recommended 7-13VDC input voltage?
nieder2 is offline Find More Posts by nieder2
Old Jun 01, 2012, 04:33 PM
Registered FPVer :)
Joined Aug 2006
I use it with a 9x, but I use one of those dedicated tx 3s lipos available at HK and other places to power it... No problems whatsoever as obvioiusely the voltage there never drops that low.
Markus
Old Jun 01, 2012, 04:46 PM
wmartin is offline
Find More Posts by wmartin
United States, CO
Joined Sep 2011
Ditto... using Turnigy 9x with dedicated 3s 2650mAh Tx battery pack. No issues with low voltage.
wmartin is offline Find More Posts by wmartin
Old Jun 05, 2012, 10:46 AM
Bemidji, MN
Joined Dec 2003
I just received my RangeLink system with TX and two receivers.
Last night I got the TX attached to my old Hitec Eclipse and it works great. Installed an RX in my EasyStar and it was plug and play and all works well on the bench. RSSI works perfect with Skylark Tiny OSD.
I did notice that the RangeLink TX does interfere with my cheap Sunsky 1280 MHz video RX. This is a documented issue with any UHF system. I guess it's time to by two Lawmate video receivers.
Next is to range test and then maiden!
Shipping was fast and Sid delivered as advertised. It looks to be a very nice product.
I'll report back after my first flight.
Old Jun 05, 2012, 08:00 PM
Chinglish-funny
Joined Mar 2011
Maybe you can try this,replace the saw filter:
http://www.rcgroups.com/forums/showthread.php?t=1204316
Sid
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 50884 Today 11:28 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
