Espritmodel.com Heli Air
Old Mar 22, 2012, 07:22 AM
Joined Apr 2011
Originally Posted by _ELLIOT_ View Post
... i used a standard dipole on rx and homemade yagi on tx. the yaghi only because we attempt 40km and at that distance the rssi during our test was at the limit with 3db onmni.
so you can consider 30km a attendible range with standard antennas but @ 500mw.
with the yaghi i used 200mw all the time.
skywalker 1900
Great video! What antenna are you using for your video tx and rx?
pyrojets is offline Find More Posts by pyrojets
Old Mar 22, 2012, 09:09 AM
Joined Dec 2010
Do you have any plan for a small 4ch receiver?(maybe like the frsky tfr4: ppm+rssi+ 2 standard pwm channel).
Also interested in future rx versions...
Any chance of having side facing pins? (for in-wing mounting) Or can the existing rx be modded to take right angle connectors?
mich75 is offline Find More Posts by mich75
Old Mar 22, 2012, 07:19 PM
Chinglish-funny
Joined Mar 2011
Sorry, I think the rx is so small, just 40×26×12mm.
LRS just for FPV uplink control. for plane, 9bit resolution is a good solution,(for the range, 10bit need increate tx rate, and will reduce the range). as i know some LRS, Just 8bit resolution some channel or all channel. so i dont wanna to change this, for LOS fly like helicoptor, use 2.4GHZ may good idea, most radio up to 10-12bit resolution. so LRS Just recommand for fpv long range fly...
Sid
sid.huang is offline Find More Posts by sid.huang
Old Mar 23, 2012, 02:39 AM
Italy
Joined Jun 2010
Well, actually it's 48x 32 x 16 mm! What caliper are you using??
And it' not small....this is small:
I am flying "long" range FPV (at least longer than what you can with other systems) with helicopters and multirotors. 433Mhz systems are very good to fly also not so far away, but very close to the ground,or to fly behind light obstacles (tree, foliage) or in difficult situation (indoor, tunnels, in the woods, etc), etc..
With this machine and this way of fly, a shorter range is not a problem (you don't need 30km, just 5 max) , but an incresed resolution (10bit is enought, not many servo/radio are >10bit) will help.
jhoexp is offline Find More Posts by jhoexp
Old Mar 23, 2012, 02:53 AM
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hi folks,
Can someone here using ER9X and rangelink, email or pm me your TX .hex file please?
If you are using an OSD PRO and have the 3 way switch for menu selection and a knob for guardian overall gain I'd love to copy your template!
Teamsherman is offline Find More Posts by Teamsherman
Old Mar 23, 2012, 07:31 PM
KK4CCD
United States, NC, Gastonia
Joined Apr 2011
Sent....using eepe but can send .hex if you want that?
avi8tor0 is offline Find More Posts by avi8tor0
Old Mar 24, 2012, 12:40 AM
Member #1
Joined Aug 2011
Hahaha, thanks for the reply! But didnt we just spend 20 minutes talking it through via skype??
Old Mar 25, 2012, 07:35 AM
Joined Oct 2011
I did my maiden flight today with rangelink and skywalker. The flight was great exept few failsafes (hundreds meters away from base). Something is wrong with my setup. I forgot to recalibrate RSSI meter after FW updating so keep in my mind that 65% is 100%
Skywoker FPV Lotnisko Kazimierz Biskupi 24 Mar 2012 (10 min 32 sec)
first failsafe - 1:44, second -2:30, third -3:05, fourth - 4:42, fifth which almost made me crash - 5:45, 8:34 another one ...
I haven't experianced any failsafes while flying (my second flight) with all video equipment off. At 10:10 when i detach cocpit cover (with camera) and turn right faceing it to RX antenna (which is right behind camera) RSSI meter shows -33% (on my fifth failsafe I had exact the same indication). It looks that the camera can noise RX (antenna too close). Is it possible ? or propably something else is noising or TX, RX is fault (I don't think so). I have sony 600TVL osd super had camera from securitycamera2000.
Exept of that I'm really happy with Rangelink and Sid's customer support.
Greetings
Hubert
Hipek is offline Find More Posts by Hipek
Old Mar 25, 2012, 09:55 AM
Norway
Joined Aug 2011
Just did a rangetest in micromode on my X8, got about 16-18m, tried to move around stuff but didnt get more than 18m at most. Is that a bad thing? And when doing the micromode test, does the plane need to be 1-2m off the ground? I just placed my plane on a short concrete wall about 1m high.
Bauf is offline Find More Posts by Bauf
Old Mar 25, 2012, 11:55 AM
FPV FTW
h0tr0d's Avatar
United States, TX, Brenham
Joined Jul 2011
I think the PZ0420 has noise at 443Mhz. It shouldn't really effect your RL, but you can stop the noise from getting into the rest of the system by wrapping the camera's wires through a torroid 5 times.
Can you post a picture of the layout of your plane showing gear placement?
Also, what were the other flyers at the field using? Are they on different UHF systems? Just curious.
h0tr0d is offline Find More Posts by h0tr0d
Old Mar 25, 2012, 12:02 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
16-18m is fine, but not really the point. The way to use micro power mode is for before/after
tests as you add more gear. You set a baseline range by just powering the Rx alone.
Then start adding FPV gear and testing again. If you suddenly see the range drop significantly,
you know you've got some noisy component on the plane that needs to be filtered, or eliminated.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Mar 25, 2012, 12:12 PM
Norway
Joined Aug 2011
ian
oh, i see.. thanks,Ian
Old Mar 25, 2012, 01:20 PM
Joined Oct 2011
Thnks h0tr0d. Sure i will upload a photo tomorrow. I was the only pilot who used uhf that day. I forgot to say that during failsafes switching to hi mode didn't help at all. It looked like the rx was totally blocked by noise (-33% like in the video). Failsafes disactivated totally randomly (as you can see in the video sometimes 0,5 sec sometimes few seconds. The endings of antena aren't fitted (only middle part is attach with ducktape) and they have could touch the camera somehow. It has to be camera because i didn't have any failsafes when i turned off the video gear.
Old Mar 25, 2012, 01:45 PM
Joined Dec 2010
Don't know about UHF but the PZ040 absolutely trashes my FM link. Noise is from the board itself, rather than the wires.
Interestingly, encasing it (SC2000 sell empty cases) seems to channel the noise into the ground wire, which I fixed by wrapping it 15 times around a small torroid (close to the cam). No noise now but a bit heavier
/off topic
Old Mar 25, 2012, 03:35 PM
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
C'mon guy, it is common knowledge (or should be) that the 600tvl cam is noisy on uhf, doesnt it make sense that if your rx antenna is probably touching it that it might be the problem?
Move rc rx and antenna AWAY from any noise sources....
bingo17 is offline Find More Posts by bingo17
Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! JettPilot Video Piloting (FPV/RPV) 20964 Today 10:15 AM
New Product ChainLink UHF Long Range System siim227 Video Piloting (FPV/RPV) 2827 May 09, 2013 04:13 AM
New Product ChainLink--The new UHF narrow band long range system BEVRC Video Piloting (FPV/RPV) 877 Jan 16, 2013 07:22 AM
New Product UHF Long range JR / Futaba module Hooks Video Piloting (FPV/RPV) 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV/RPV - Equipment and Vehicles (FS/W) 8 Jul 22, 2011 03:55 PM
