Old Feb 09, 2012, 04:42 AM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
No only changed rx antenna first. then tested tx antenna's once stock rx antenna was fitted.
Cir2kuk is offline Find More Posts by Cir2kuk
Old Feb 09, 2012, 12:47 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ok. So changing Rx antennas seemed to be the greater of the two improvements if you went from having full failsafes at 2km to none.. while changing Tx antenna seems to have a small effect on RSSI that still seems to be a bit hard to explain.
ian
Daemon is offline Find More Posts by Daemon
Old Feb 16, 2012, 06:39 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Measured numbers:
at 11.24V
0.14A 1.5W
0.23A 2.5W
hefest is offline Find More Posts by hefest
Old Feb 17, 2012, 12:43 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hey Sid,
Can rangelink work with the Hitec Aurora 9?
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 17, 2012, 12:50 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Flew my Rangelink system yesterday and today, and both days experienced fairly significant
video interference at times. If I turned to put my body between the UHF Tx antenna
and the 1.3Ghz video antenna, the noise would go away or at least be reduced.
The visible noise *looks* like packet based external interference, consistent with
a UHF control signal. It was my understanding that RL Tx was supposed to have a low
pass filter already installed. It does not appear to be sufficient.
ian
Old Feb 17, 2012, 01:53 AM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Originally Posted by Teamsherman View Post
Hey Sid,
yes, and you can use the same pnp cable 2( for your dx8)
sid.huang is offline Find More Posts by sid.huang
Old Feb 17, 2012, 02:01 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Sid, how long before you have stock in again. Sorry if you have stated it earlier.
Bx
Boxhead is offline Find More Posts by Boxhead
Old Feb 17, 2012, 02:05 AM
Chinglish-funny
Joined Mar 2011
ian
Inside a LPF,It will reduce the noise,Even with this, it is highly recommended to separate the A/V RX, and UHF TX antennas physically as much as possible. and try use the HPF on vrx. of course uhf system will reduce the range, use the LPF/HPF just improve this. like 1.3GHZ(vrx/vtx) with 2.4GHZ (control),it also reduce the range.
RL TX comply with all applicable FCC requirements 2-3 harmonics less than tx power -40dBm.
Sid
Old Feb 17, 2012, 02:18 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
All I can say is my TLRS Tx does not produce interference like this, at same separation,
from same video Rx and antenna... even at higher power levels (1-2W).
Using Comtech based video Rx with SAW filter mod. It generally has excellent selectivity.
If the noise is from the 3rd order harmonic then HPF on video Rx won't have any effect.
ian
Old Feb 17, 2012, 03:43 AM
Member #1
Joined Aug 2011
Awesome!
Old Feb 17, 2012, 03:48 AM
jhoexp is offline
Find More Posts by jhoexp
Italy
Joined Jun 2010
ian
Are you using linear polarized antenna on Vrx?
Exact same experience here, very noisy video when RL tx is within 1-1.5 meters with LP antenna..
With Vrx on the tracker, at least 5-6 meters way from the RL TX, no problem.
With CP antennas, no problem even if RL is next to it.
Sid, any news on the Futaba 12ch PPM compatibility? Looking forward to test it, even with reduced resolution and latency for the last channels, won't be a problem.
jhoexp is offline Find More Posts by jhoexp
Old Feb 17, 2012, 05:27 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Using CP antennas on both ends of video link. Have used this exact combo with TLRS without significant video noise for about a year. Have other issues with TLRS though, which is why I'm testing RL. I think RL Rx may have better input filtering thus more reliable in my high Rf environment, but what I'm seeing in the video could be a show stopper, if I can't find a filter to fix it.
ian
Old Feb 17, 2012, 05:54 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Ian, are you talking about this type of video problem:
Videoproblem (2 min 33 sec)
Locko is offline Find More Posts by Locko
Old Feb 17, 2012, 10:54 AM
h0tr0d is offline
Find More Posts by h0tr0d
FPV FTW
h0tr0d's Avatar
United States, TX, Brenham
Joined Jul 2011
You guys are running into some of the same issues I've had with 1280 Video. When I first got the RangeLink and tried to use an omni antenna sitting 3 feet from the vrx....this happened:
1280 Mhz Interference (1 min 34 sec)
(Note: this happened to be a particularly noisy RL that Sid took care of for me)
That being said, I set out on a mission to figure out how to use this. I threw the 600mhz crystek lpf from digikey on the RangeLink and that helped quite a bit. If I want to go far, I have to sit a good ways away from my directional 8dbi patch. My best results have been sitting ~25ft behind the patch and have been 4.25 miles without any trouble. The further you can get away the better it seems. I just ordered the improved SAW filter for my VRX to see if I can improve things on that end some. I have yet to try 2.4ghz video with it.
4.25 Mile flight with digikey lpf sitting 25ft behind 8dbi patch. 4 mile mark is ~2:00 so you can see there aren't problems with the video.
Bixler FPV 4.25 Mile Flight (4 min 44 sec)
h0tr0d is offline Find More Posts by h0tr0d
Old Feb 17, 2012, 11:03 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yep, both videos are representative of what I'm seeing.
I can't fly standing 25ft from my ground station, and never have had to before.
There is a way to fix this.
ian
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 50141 Today 09:15 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
