Old Jan 10, 2012, 08:48 AM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Originally Posted by pyrojets View Post
Hey sid, love the rangelink, managed to do 3.1km LOS today in populated areas and it was between 99%-100% throughout.
thanks mate.
Sid
sid.huang is offline Find More Posts by sid.huang
Old Jan 10, 2012, 09:00 AM
Chinglish-funny
Joined Mar 2011
Originally Posted by NDw View Post
Hi Sid if I was making an extra antenna what lenght do you recommend for the elements?
recommend to use the RG178 Coaxial Cable, less 1m. as short as possible. at 433MHZ, Attenuation about 1dB (lenght = 1m).
Sid
Old Jan 10, 2012, 09:14 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
If by "elements" you refer to the radiating two parts of the dipole, then their lenght should be 16.4cm to be reasonate at around 433Mhz.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 10, 2012, 09:18 AM
Chinglish-funny
Joined Mar 2011
HTH
Markus
thanks markus, i think i misread.
Old Jan 10, 2012, 10:25 AM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Antenna Refresher
Some antenna refresher stuff
http://flitetest.com/forum/showthrea...4-FPV-Antennas
Antennas 101 - Polarization, Diversity & Gain Patterns (27 min 56 sec)
CN I Dawg is offline Find More Posts by CN I Dawg
Old Jan 11, 2012, 01:40 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Is anyone here using rangelink and Foxtech goggle head tracker?
I usually use the ppm out on my DX8 but now it will be taken up by the rangelink so I have no idea how I'm going to use it again.
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 11, 2012, 02:32 AM
Chinglish-funny
Joined Mar 2011
An idea to find out the signal:
foxtech goggle header tracker ,it support futaba radio,right?
the pin6 is a ppm signal out from goggle header tracker.... connect it to the rangelink HTPPM pin, would be ok. also you can powered header tracker from the rangelink HT Port.
u need to do some solder.
Sid
Old Jan 11, 2012, 03:48 AM
Chinglish-funny
Joined Mar 2011
Originally Posted by CN I Dawg View Post
a good resource,,,, thanks for your share the link...
Sid
Old Jan 11, 2012, 03:50 AM
Member #1
Joined Aug 2011
So do I need a ground from the headtracker to the rangelink unit? The goggles are already ground via the battery it runs off, and the rangelink will be ground by its own battery too.
Old Jan 11, 2012, 06:57 AM
Member #1
Joined Aug 2011
Also does the rx have failsafe settings?
Old Jan 11, 2012, 08:11 AM
Chinglish-funny
Joined Mar 2011
yes,it has. check the rangelink manual.pls
Sid
Old Jan 11, 2012, 08:18 AM
Chinglish-funny
Joined Mar 2011
> the goggles can works with DX8? how ?
not clearly, maybe you can show me the connecting diagram.
Sid
Old Jan 11, 2012, 06:46 PM
Member #1
Joined Aug 2011
Sid, I am just unclear of the ppm signal from the goggles to the RL TX. Is it just the single wire of ppm or does it need a ground also coming from the goggle to the RL?
The DX8 uses the ppm port and channels 5 and 6 for headtrack.
Old Jan 11, 2012, 06:57 PM
Member #1
Joined Aug 2011
And where can I find the manual? I didn't receive one with my RL.
Old Jan 11, 2012, 07:12 PM
Chinglish-funny
Joined Mar 2011
sorry, it on my blog: rangelink manual
http://www.rcgroups.com/forums/member.php?u=352541
Sid
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 46118 Yesterday 08:27 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 05:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 07:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 06:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 04:55 PM
