Old Feb 05, 2013, 08:56 PM
guaglione87 is online now
Find More Posts by guaglione87
Chi va piano, va lontano
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Originally Posted by Daemon View Post
Can put power on any channel but probably best to stay away from the last 3 (RSSI, PPM, TTL).
thank you sir!
guaglione87 is online now Find More Posts by guaglione87
Old Feb 05, 2013, 08:57 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by skellator View Post
any reason why? as im powering my rx via ppm port as that the only cable connected to my rx from my apm2.0
Occurs to me, I'm doing the same on my tricopter, but it's Rx only, with no servos.
It's just not uncommon for special data ports to have limited power handling capacity.
ian
Daemon is offline Find More Posts by Daemon
Old Feb 05, 2013, 08:58 PM
Integratedneck is offline
Find More Posts by Integratedneck
Australia, QLD, Brisbane
Joined Aug 2012
have anyone using APM+MimimOSD here with rangelink? trying to get the RSSI to show up properly in MimimOSD can't seem to get it to work
Yes, you need to configure the analog input on the APM then enable rssi on the OSD. You then need to scale the output given the 8 bit adc ranges 0 to 5v.
Integratedneck is offline Find More Posts by Integratedneck
Old Feb 05, 2013, 10:16 PM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
ian
ah noted thanks!
Integratedneck
analog port enabled OSD set to raw value but the value is jumping around, how one do actually scale the data?
skellator is offline Find More Posts by skellator
Old Feb 05, 2013, 11:25 PM
Joined Apr 2012
Brand new rangelink tx in the mail to replace the first one that did not function - so i sent it back. This time, when i hooked it up with my 5v source (external sbec) the light flickered on one time, and then nothing. Not a thing.
Anyone have this experience?
Old Feb 05, 2013, 11:27 PM
Joined Apr 2012
By the way, i hooked up another servo extension on another port, and measured the 5v at it's end, so the voltage is getting through, just not lighting the LED up, and the rx is not responding... frustrated.
Old Feb 05, 2013, 11:28 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Note, the LED won't light up before you bind it and re-power both Tx and Rx.
Old Feb 05, 2013, 11:58 PM
Joined Apr 2012
Well... that was embarrassing...
Daemon - thanks a bunch! I was freaking out there for a second. Works like a charm now.
Thanks again.
Old Feb 06, 2013, 07:47 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Yes, you get less range with a monopole. Or put another way, you don't
get something for nothing.
http://www.rcgroups.com/forums/showt...1820142&page=2
My own testing matches his results.
ian
Well its on a disco quad, I'm going to run 1.3ghz on VTX in order to punch through trees and shrubs. Not looking to set distance records but I don't want to lose link and have it fall out of the sky.
stgdz is offline Find More Posts by stgdz
Old Feb 06, 2013, 08:35 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That's not what the person I was responding to, asked.
Old Feb 07, 2013, 02:31 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hi Guys,
Is anyone here using rangelink with Skylark TinyII OSD? I'm trying to get RSSI on screen but it keeps saying rssi not detected. I have the cable running from the rssi port on the RL rx and at the other end on the OSD rssi in port.
Do I need to turn the rssi function on in the software of the OSD on my PC? I haven't yet plugged it into my computer.
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 07, 2013, 01:03 PM
Kd4Kw is offline
Find More Posts by Kd4Kw
KD4KW
Kd4Kw's Avatar
United States, FL, Tallahassee
Joined Jul 2009
I don't know about the range link but my buddies older chain link worked fine. He just ran wire from rssi on rx to rssi in on the tiny.....your mileage may vary.
Kd4Kw is offline Find More Posts by Kd4Kw
Old Feb 07, 2013, 03:24 PM
flye is offline
Find More Posts by flye
Joined Sep 2010
what is the difference between v1 and v2 receiver?Need to buy a new one and saw 2 versions so...
flye is offline Find More Posts by flye
Old Feb 07, 2013, 03:28 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Re-read the titles/descriptions of each closely. There is only one version of Rangelink Rx.
Old Feb 07, 2013, 08:47 PM
Joined Aug 2012
ah noted thanks!
Integratedneck
Need to see the min and max values. It wil be in the range 0-255 corresponding to the 8 bit ADC scaled to 5v. So 255 = 5V. For me my rangelink does .9 - 3.1v so my range is something like 50 to 150. With the upper and lower limit set for the minimosd remove the show raw values and you get a percentage.
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 53333 Today 09:03 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
