Old Jan 31, 2013, 02:31 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Originally Posted by blackjackr View Post
Ok When paycheck Friday comes going to order my range-link just have 2 questions.
1. Already have to stuff to mod my dx7 with a switching 3.5 jack for the ppm stream. http://www.fpvmanuals.com/2011/03/17...ezuhf-or-tlrs/ From what I have read here it may not be needed with range-link, but would it be better anyways with the higher ppm stream than the trainer port?
2. Since i fly the epp-fpv and want to mount the dipole on the tail can i get a antenna with a longer cord? need about 36 inches and hate to use couplers due to insertion loss.
Jack
With a Normal Dx7 , rangelink doesnt work, you need to do the mod you are talking about.
Im not sure about the Dx7s , but Ive tryed the dx7 and it desnt work. Dx6 and dx8 do work, just PNP.
Locko is offline Find More Posts by Locko
Old Jan 31, 2013, 03:33 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
have anyone using APM+MimimOSD here with rangelink? trying to get the RSSI to show up properly in MimimOSD can't seem to get it to work
skellator is offline Find More Posts by skellator
Old Jan 31, 2013, 07:06 AM
blackjackr is offline
Find More Posts by blackjackr
blackjackr's Avatar
United States, AZ, Lake Havasu City
Joined Apr 2011
Kind of what I thought, Good thing the mod is super easy
blackjackr is offline Find More Posts by blackjackr
Old Jan 31, 2013, 10:40 PM
blackjackr's Avatar
Joined Apr 2011
Originally Posted by sid.huang View Post
Add 60cm antenna to your cart and put a notice with your order that you want a 39'' RX Antenna.
Sid
Found this back a couple dozen pages, I guess I will just do that too and hope I get a 39" antenna too
Old Feb 02, 2013, 04:27 AM
9W2DLR
Joined Nov 2011
i noticed something wierd i did advance binding, now my rx need to be powered first before tx if i powered my tx first it wont see the rx i need to power cycle my tx then it will be binded,
is this normal behavior or something else? I kindda dangerous as my apm think the link is loss and when straight into failsafe
Old Feb 02, 2013, 11:29 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You do a regular bind after advanced bind? If not, you should. That behavior is not normal.
Daemon is online now Find More Posts by Daemon
Old Feb 02, 2013, 07:49 PM
9W2DLR
Joined Nov 2011
i did not as was following the manual i will try that first
thanks
Old Feb 04, 2013, 09:23 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
So I'm going to put this on my TBS disco quad and I'm kinda confused on antennas.
Do I just use a single whip antenna?
stgdz is offline Find More Posts by stgdz
Old Feb 04, 2013, 11:20 PM
9W2DLR
Joined Nov 2011
you can use he stock dipole or make yourself a sander antenna, if dipole i put car rc tube on the active elements poking up and leave the ground element dangling just make sure it out of your prop
here my sander style antenna easy to make
Description:
Old Feb 05, 2013, 11:45 AM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
I got this one http://www.readymaderc.com/store/ind...oducts_id=1032
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Feb 05, 2013, 03:03 PM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
Do you get less range with a monopole,than the one that comes with the RL? Have you done a comparison in micromode? if you dont lose range, i would buy 2-3 in a heartbeat. The stock antenna is ok to mount on my bixler, but on my Z2,it's alittle bit worse.
Bauf is offline Find More Posts by Bauf
Old Feb 05, 2013, 03:40 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, you get less range with a monopole. Or put another way, you don't
get something for nothing.
http://www.rcgroups.com/forums/showt...1820142&page=2
My own testing matches his results.
ian
Old Feb 05, 2013, 07:36 PM
guaglione87 is online now
Find More Posts by guaglione87
Chi va piano, va lontano
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Question - I have an external sbec, can I plug it in on any old port, or must it be a specific port to be powered up with? I dont want to use the first, because i need it for throttle.
Thanks!
Michael
guaglione87 is online now Find More Posts by guaglione87
Old Feb 05, 2013, 08:21 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Can put power on any channel but probably best to stay away from the last 3 (RSSI, PPM, TTL).
Old Feb 05, 2013, 08:56 PM
9W2DLR
Joined Nov 2011
any reason why? as im powering my rx via ppm port as that the only cable connected to my rx from my apm2.0
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 53322 Today 03:35 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
