Old Jan 12, 2013, 03:31 AM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Originally Posted by Paquitoc View Post
Hello
Anyone have this problem with the link?
I leave these videos
in case anyone has the same problem or do I have the install the wrong.
thanks
https://www.youtube.com/watch?v=eAf0__hhBNc
https://www.youtube.com/watch?v=pqkqgSDXSH0
https://www.youtube.com/watch?v=lePHz-3NSyM
https://www.youtube.com/watch?v=s_czbJ4RszI
I cannt open the youtube,maybe you can email to us.
Sid
sid.huang is offline Find More Posts by sid.huang
Old Jan 12, 2013, 03:33 AM
Chinglish-funny
Joined Mar 2011
Originally Posted by guaglione87 View Post
My rangelink was working fine the other day, now I it seems completely dead... Here's the situation:
I added a couple of servo extensions to get the rx unit in the back of my super sky surfer, plugged up everything else, and the motor twitched, as did other servos, so i powered it off. Ever since then, it will not move anything. I rebound, and still have the solid LED on the rx, but i get no movement when i power the servos, and I dont hear the ESC startup. That all makes me think it is not making any connection. Funny thing is that everything seemed to work ok until i added servo wire extensions to the mix.
Any ideas?
It looks fault rx, maybe over voltage input or reverse input. send it back for repair/replace.
Sid
Old Jan 12, 2013, 03:58 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Sid
The videos will show that he's juggling dozens of variables. He's got
the ppm signal from the transmitter running through a several meter long
cable to the RL Tx module.
Videos 1-2 show it first not linking, then not binding while the Rx is installed
on the plane where it appears every channel is in use, and the Rx is
crammed under about 4-5 different OSDs, and APs, but it will
bind and link when RL Rx powered by itself with nothing else connected.
3rd video shows it back on the plane, sometimes seeming to link ok, and sometimes
linking very badly (Rx light blinks on and off randomly and servos move in fits
and spurts). End of 4th video shows that same behavior even when RL Rx
is powered by itself with nothing else plugged in. That leads me to believe that
the problem is with that extremely long extension on the PPM wire to the Tx module,
which he never eliminates in all the testing through 4 vids. Guessing the Tx
module is getting a weak or corrupted PPM signal.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 12, 2013, 08:32 AM
Dr.Tom is offline
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
2 sid.huang:
is it possible to separate 2 boards of your RX?
asking because I am in need for placing RL RX on one wingtip, and FPV TX on other,
for long range FPV
FPV in the clouds (7 min 16 sec)
to avoid routing like 14 cables through wing to fuselage, I am using PPM SUM from it.
then decoding it to PWM for servo usage and OSD (Storm OSD doesn't have PPM in)
I made wings click-in with MPX 6 pin connector, all works quick and neat
right now I'm fiddling with an arduino that decodes PPM to PWM...
http://www.multiwii.com/forum/viewto...=2832&start=10
but in case ppm line is broken it doesn't have failsafe to turn plane back (RTH OSD)
and to circle above me until ESC LVC shuts it down and lands in stable mode(OSD autopilot).
it works,
but I would like this way better, to place second half of your RX in fuselage, and bring only those 3 pins to other half that has RF piece on wingtip.
less electronics onboard and original failsafe functions
and optical inspection with bright light, showed me that upper plate of RX
seems to be connected only with 3 pins in one corner (+,-,digital? ) with lower plate that has servo pins, hope I am right
can it work on 120-130cm distance between boards
-longer antenna is not an option as it causes signal loss
-and I've already had a plane with servo extensions from fuselage to wingtip where RX was, and it wasn't very practical
http://www.flyfreak.net/fpv-i-ap/nov...5425/#msg95425
Dr.Tom is offline Find More Posts by Dr.Tom
Old Jan 12, 2013, 11:01 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
Hi, I have received my RL and made a micro test and get 15m on my quad so how far can I expect for flying?
flye is offline Find More Posts by flye
Old Jan 12, 2013, 12:53 PM
ron-sand is offline
Find More Posts by ron-sand
ron-sand's Avatar
Norway, Troms, Tromsų
Joined Sep 2002
Sid.
Can yo look into how this affects us Rangelink / 8fg users? I heard Sander (lmmersion) is working on a firmware update for their system, as getting Futaba to sort this cuickly is most likly not going to happen.
http://vimeo.com/m/57169465
ron-sand is offline Find More Posts by ron-sand
Old Jan 12, 2013, 04:27 PM
Paquitoc is offline
Find More Posts by Paquitoc
Paquitoc's Avatar
Joined Jun 2009
ian
files are too large to send by e-Sid
Correctly described the problem Daemon.muchas thanks.
If I wear a wire that I do now shorter and longer tell them the result.
Paquitoc is offline Find More Posts by Paquitoc
Old Jan 12, 2013, 08:54 PM
Chinglish-funny
Joined Mar 2011
Originally Posted by ron-sand View Post
Sid.
just 0.4ms, Dont worry about this. but cannt works at 12ch ppm mode
Sid
Old Jan 12, 2013, 08:59 PM
Chinglish-funny
Joined Mar 2011
So the tx led blink fast ?
Sid
Old Jan 12, 2013, 09:24 PM
Chinglish-funny
Joined Mar 2011
Originally Posted by Dr.Tom View Post
2 sid.huang:
for long range FPV
http://www.youtube.com/watch?v=D_kiIUaahac
it works,
I still recommand you try to use the longer rx antenna, Just upload the rx pins layout.
>> rebind will cancel the fs out. so you need reset the fs.
Sid
Old Jan 13, 2013, 02:31 AM
Dr.Tom is offline
Youtube: TomRi25
Dr.Tom's Avatar
Joined Aug 2010
I was talking about arduino failsafe
RL has great failsafe for every channel, it works OK.
But, question was, with how many pins does 2 pieces communicate with each other,
and can your RX then be separated with wires, distance around 100cm
will it work?
Old Jan 13, 2013, 03:20 AM
Paquitoc is offline
Paquitoc's Avatar
Joined Jun 2009
LRS link failure rangelink
Hello
2 test. with the shortest wire, according Daemon said it was the possible error, link failure continues, I have changed my plane and another installation still does not work.
Sid private message command him to see what solution we give to my team, no evidence of malfunction.
thanks
here the video of the second test
PICT0005 (1 min 12 sec)
PICT0006 (1 min 10 sec)
Old Jan 13, 2013, 05:53 AM
Chinglish-funny
Joined Mar 2011
Hello
thanks
https://www.youtube.com/watch?v=lw_BfvBVbW0
https://www.youtube.com/watch?v=vq0lpGvytuA
Ok ,Email to us,and i will show you the shippping info,Just send it back for checking...
BTW, so did you confirmed that RX power supply do NOT has any issue?
Sid
Old Jan 13, 2013, 06:10 AM
Chinglish-funny
Joined Mar 2011
will it work?
10pins.
can your RX then be separated with wires, distance around 100cm [/B]
will it work
>>yes, no problem.
Sid
Old Jan 13, 2013, 07:28 AM
Paquitoc is offline
Paquitoc's Avatar
Joined Jun 2009
Sid
Hello Sid, I've been beta tester in industrial electronics and do hesitate to make the decision to give rangelink failure, I have taken many steps, I just want to have a good LRS and be proud of it.
thanks
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 53335 Today 09:31 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
