Old Jan 06, 2013, 12:27 PM
Efti is offline
Find More Posts by Efti
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Originally Posted by Altimat View Post
Nice solder job Efti. Did it take a lot of heat? Would it be a good idea to solder these preventatively?
Thanks.
It was very easy to solder actually. Put the iron to about 400 Celsius, but did NOT heat for long time. Finished in a minute.
For preventatively, I would think it will be better to secure it like this if it is soldered properly.
Efti is offline Find More Posts by Efti
Old Jan 06, 2013, 02:05 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I've done that on all my RL Rxs as well. DL had the same problem, and I believe they
now come soldered. Do have to be careful not to overheat it.
Haven't noticed any range reduction, as suggested above. My micro-power range
checks are usually 20-30 paces which seems to be on the upper end of what
a lot of people are reporting.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 06, 2013, 04:05 PM
guaglione87 is online now
Find More Posts by guaglione87
Team Armattan
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Well it looks like my hk 5.8g 200mw video link is failing me, or it doesnt like nova osd. The nice thing is that it didnt effect my rangelink range. I have a feeling that it is not the best band to go with for long range anyways.
In any case, can any one suggest a good video tx rx that will not reduce my range with rangelink?
Something from hobbywireless.com would be good, because they are not too far away.
Thanks for any suggestions!
guaglione87 is online now Find More Posts by guaglione87
Old Jan 06, 2013, 04:23 PM
Altimat is offline
Find More Posts by Altimat
FPV Recon
Altimat's Avatar
United States, TX, Liberty Hill
Joined Nov 2005
Anything in 1.2G should work, but RMRC scared me away from Lawmate: http://hobbywireless.com/index.php?m...ex&cPath=88_90
I'm probably going with these:
http://www.readymaderc.com/store/ind...oducts_id=1020
http://www.readymaderc.com/store/ind...roducts_id=922
Haven't pulled the trigger yet and almost everyone here should know more than I do...
Altimat is offline Find More Posts by Altimat
Old Jan 06, 2013, 06:06 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You don't need a 1000mW Vtx. The RMRC 800 Tx (actually puts out about 600mW
on 12V at 1280Mhz) will give you 2-3 miles on CP omnis and easy 6-7 miles with 8-10db
Of gain on the Rx, and much much further with other higher gain antennas. 1000mW and
up is just asking for more trouble onboard the plane, and spews its signal miles
around interfering with other FPV pilots.
ian
Old Jan 06, 2013, 06:38 PM
Altimat is offline
FPV Recon
Altimat's Avatar
Joined Nov 2005
Thanks Ian I'll go with the 800mW.
Old Jan 11, 2013, 03:12 AM
Paquitoc is offline
Find More Posts by Paquitoc
Paquitoc's Avatar
Joined Jun 2009
rangelink link failure
Hello
Anyone have this problem with the link?
I leave these videos
in case anyone has the same problem or do I have the install the wrong.
thanks
rangelink link failure 1 (2 min 41 sec)
rangelink link failure 2 (4 min 11 sec)
rangelink link failure 3 (3 min 11 sec)
rangelink link failure 4 (5 min 58 sec)
Paquitoc is offline Find More Posts by Paquitoc
Old Jan 11, 2013, 04:28 AM
Zafir is offline
Find More Posts by Zafir
Zafir's Avatar
Hungary, Budapest
Joined Apr 2012
Originally Posted by Paquitoc View Post
Hello
thanks
Yees, same as with my old chainlink!
I sent it to Sid and he said:..."chainlink tx fault rf module, rf module fixed. but control borad still has some issue."
Now I'm waiting for the rangelink set....well..
Zoli
Zafir is offline Find More Posts by Zafir
Old Jan 11, 2013, 05:10 AM
theailer is online now
Find More Posts by theailer
Joined Apr 2006
Hi all!
I have a wierd issue with my rangelink. I have a readymaderc 1.3GHz vtx on my airplane and if I put my hand between the vtx's antenna and the rangelink rx antenna my servos start to jitter. The jitter is exaggerated when choosing certain channels on the vtx and other channels it completely dissapears. Why is it like this? Escecially since I shield the two antennas with my hand, and I'm not touching the antenna either. And it only happens when I have my hand close to the vtx antenna. Thanks in advance.
theailer is online now Find More Posts by theailer
Old Jan 11, 2013, 11:13 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It's probably the servos themselves. Try twisting the servo leads (pull the pins
from their plugs, peel the three wire apart, twist back together, and and reinsert
the pins into their plugs). Otherwise, replace with better servos.
ian
Old Jan 11, 2013, 03:30 PM
Joined Apr 2006
Thanks. Yeah it's probably the servos. I'm relocating my vtx to the tail to see if that helps. And check the servos ofcourse
Old Jan 11, 2013, 08:03 PM
firedawg1998 is offline
Find More Posts by firedawg1998
Canada, ON, Greater Sudbury
Joined Nov 2011
Boy oh boy I can't wait to hook this puppy up. I ordered the rangelink 10 days ago with some extras, then realized that I might prefer the longer antenna on the bixler, so I placed an additional order and paid the shipping twice. My fault but was contacted after I messaged that the orders could just been boxed together and was responded to in this email. "I see you have paid for shipping twice, I will package them togehter and upgrade the shipping to ems... Arrived quickly and safely, items packaged very well, 1/2 way hooked up, taking my time not to leave any T's uncrossed. Awesome service and product so far... Cheers
firedawg1998 is offline Find More Posts by firedawg1998
Old Jan 12, 2013, 01:17 AM
Team Armattan
Joined Apr 2012
My rangelink was working fine the other day, now I it seems completely dead... Here's the situation:
I added a couple of servo extensions to get the rx unit in the back of my super sky surfer, plugged up everything else, and the motor twitched, as did other servos, so i powered it off. Ever since then, it will not move anything. I rebound, and still have the solid LED on the rx, but i get no movement when i power the servos, and I dont hear the ESC startup. That all makes me think it is not making any connection. Funny thing is that everything seemed to work ok until i added servo wire extensions to the mix.
Any ideas?
Old Jan 12, 2013, 03:23 AM
speedmasta is offline
Find More Posts by speedmasta
France, IdF, Paris
Joined Mar 2012
Anyone about this announcement by immersionRC?
http://vimeo.com/m/57169465
Could be a problem for RL too...
8FG users, any problem to report?
speedmasta is offline Find More Posts by speedmasta
Old Jan 12, 2013, 03:28 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, I'm sure it affects RL and all other UHF systems. They generally all allow
for different length PPM frames, but whatever that length is, must not change.
It's a fairly common glitch on 12ch PPM frame when you try to cram them
into the same length as an 8ch frame, but zero excuse for it to happen on the 8ch frame
itself.
ian
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 51835 Today 01:50 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
