Old Jan 04, 2013, 08:51 AM
surf1punk is online now
Find More Posts by surf1punk
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
Originally Posted by m_beeson View Post
contact sid, and send it back for repair.
Yeah I did, he offered to exchange it. I'll report back once I get the new one.
surf1punk is online now Find More Posts by surf1punk
Old Jan 04, 2013, 11:54 AM
Donger512 is offline
Find More Posts by Donger512
Joined Dec 2012
I'm in the same boat. I'm hating myself for not paying a little extra for EMS. I didn't think it would take this long. My shipping date was on 12/14. I can't finish my QAV500 till it comes in.
I made an order for some cables off ebay using China Post as well. It came in a week ago.
Originally Posted by Zafir View Post
I think it's normal!
My shipping date is 12/07
...and I feel my pack is close to me!!
Zoli
Donger512 is offline Find More Posts by Donger512
Old Jan 04, 2013, 12:16 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Regular China Post can take anywhere from a long time, to a very long time.
I always opt for EMS, if available.
Daemon is online now Find More Posts by Daemon
Old Jan 04, 2013, 04:46 PM
rodrigonewton is offline
Find More Posts by rodrigonewton
Joined Dec 2012
Originally Posted by i3dm View Post
I really recommend this method - it has worked PERFECTLY so far and allows enough distance that the UHF module doesnt affect the Turnigy LCD.
also it allows to fine tune the angle of the RL Tx antenna in relation to the ground for different ways of holding the Turnigy Tx, and still maintain the RL Tx antenna vertical !
BTW - yesterday i installed a new Rangelink exactly the same on my buddy's Turnigy 9X with ER9X mods - very impressive system the Rangelink is !
Hello i3dm !
I'm going to order my RL and I need to connect it to my Turnigy 9x. Do you have the schematics, wiring, etc ? Could you please post some photos or send them to my e-mail ? rodrigonewton@gmail.com
Thanks in advance!
Regards,
Rodrigo.
rodrigonewton is offline Find More Posts by rodrigonewton
Old Jan 04, 2013, 11:08 PM
skellator is online now
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
Originally Posted by rodrigonewton View Post
Hello i3dm !
Thanks in advance!
Regards,
Rodrigo.
check the manual, and check turnigy9x pin out that should be enough for you do wire the modules
skellator is online now Find More Posts by skellator
Old Jan 05, 2013, 03:01 PM
guaglione87 is online now
Find More Posts by guaglione87
KG5AWQ
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Did a range check as detailed in the manual. Does 46 feet sound right? I got 41 with my 5.8 running... Note that I had an esc hooked up
guaglione87 is online now Find More Posts by guaglione87
Old Jan 06, 2013, 04:08 AM
9W2DLR
Joined Nov 2011
sound good to me :thumbup:
Old Jan 06, 2013, 08:32 AM
Efti is offline
Find More Posts by Efti
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Hi.
I had an accident and the antenna cable plug was pulled out of the receiver.
How can this be fixed? Solder a new plug on th rx?
I can put it back in, but it will become loose by looking funny at it.
Efti is offline Find More Posts by Efti
Old Jan 06, 2013, 09:26 AM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Press it back on with pliers being careful not to damage threads. Put a couple dabs of solder near separation seam. Same thing happened to my DL
vertcnc is offline Find More Posts by vertcnc
Old Jan 06, 2013, 09:29 AM
9W2DLR
Joined Nov 2011
Originally Posted by Efti View Post
Hi.
if were me i probably solder a new connector just to be on safe side as it might break again
Old Jan 06, 2013, 09:44 AM
Efti is offline
Efti's Avatar
Joined Oct 2011
Thanks. I just did it.
When i pushed with the plier there was coming a click, and it was stuck.
Put some solder on it to secure it
Old Jan 06, 2013, 10:08 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Exactly. Good to go.
Old Jan 06, 2013, 10:09 AM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
It happened on almost all my RL rx.
I did those kind of soldered repair, but when I've tested in range test mode it always have a lower signal than before. If you still have a not broken rx, you can compare easily.
The only way to gain the same range was desoldering the whole connector and put a new one. But it's easy to burn a pad while desoldering them. I've killed one rx like that.
Sid should use new connectors. The ones I replace with can't brake here cause they're made of one piece.
Kipkool is offline Find More Posts by Kipkool
Old Jan 06, 2013, 11:08 AM
Efti is offline
Efti's Avatar
Joined Oct 2011
I have several rx to test. How much is it reduced?
This is on a quad that don't need an extreme distance.
Old Jan 06, 2013, 12:05 PM
Altimat is offline
Find More Posts by Altimat
FPV Recon
Altimat's Avatar
United States, TX, Liberty Hill
Joined Nov 2005
Nice solder job Efti. Did it take a lot of heat? Would it be a good idea to solder these preventatively?
Altimat is offline Find More Posts by Altimat
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 46136 Today 11:06 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 05:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 07:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 06:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 04:55 PM
