Old Dec 28, 2012, 07:41 PM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Originally Posted by Mykro View Post
Sid,
I will try what you suggest..
There people on this tread who are using ET OSD successfully who have no glitches..?
maybe you need to servo analysis wizard for the new rx.
Sid
sid.huang is offline Find More Posts by sid.huang
Old Dec 28, 2012, 07:50 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Sid
Yes... I ran the "Servo Analysis Wizard"
Mykro is offline Find More Posts by Mykro
Old Dec 29, 2012, 09:13 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by skellator View Post
sander style UHF antenna
Attachment 5401225
gonna do range test first in a moment
Remember, the "Sander style" antenna is a quarter wave monopole antenna. It will not perform as well as the stock dipole. It's ok for closer proximity. With EzUHF this is a bit different as there they use diversity, but even there dipoles would be superior.
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 29, 2012, 10:34 AM
surf1punk is offline
Find More Posts by surf1punk
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
Two questions, I have a Low Pass Filter from my old Tx, should I use that on the RL, I'm using 1280 as my video feed still. I also already have a 1.3 LPF on my video Tx on the plane.
And I have a Nagoya NA-771 antenna, any reason to use that over the stock antenna?
surf1punk is offline Find More Posts by surf1punk
Old Dec 29, 2012, 10:42 AM
Registered FPVer :)
Joined Aug 2006
RL has built in filters, so IMHO you don't need it. Regarding the antenna, that's a two band antenna for 2m and 70cm. In the 70cm band which is relevant here, the gain the antenna has is only 2,15dBi. I'm not sure what kind of gain the stock antenna has but it does not take much to get there. In other words, there would be better antennas to replace the stock one. The stock one is good though and i.e. I only have a 70cm yagi which I use in situations where I think the stock one could come to it's limits.
HTH
Markus
Old Dec 29, 2012, 11:19 AM
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
HTH
Markus
Ok thanks for the info Markus
Old Dec 29, 2012, 11:24 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Will this interferance with the guys who have ham licens?
timtimtim is offline Find More Posts by timtimtim
Old Dec 29, 2012, 12:05 PM
Registered FPVer :)
Joined Aug 2006
A bit of a delicate question. In fact it runs in the 70cm band and as such it could interfere, but it's frequency hopping, thus it does not interfere that much compared to a regular user of this band.
The best thing you can do is to get a HAM license yourself. Depending on where you life this is actually quite easy (as it seems in the US) or very hard (i.e. Switzerland). Should you be intersted, contact a local HAM radio club.
HTH
Markus
Old Dec 29, 2012, 09:44 PM
skellator is online now
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
Markus
ah ok thanks i take note on that, i guess might better of buying the small antenna from flytron? but for start sander antenna should be enough for my quad as i dont plan to go beyond 1km with the quad anyway,will do a ground range test first before flying with it
skellator is online now Find More Posts by skellator
Old Dec 30, 2012, 06:43 AM
Registered FPVer :)
Joined Aug 2006
Unless you fly in a very harsh envireonement, your sander style antennas should be ok to ~5km. So no worries here. If you intend to go beond this, choose the stock dipoles. The flytron ones are worse than the sander style ones as they are shorter. With antennas, you generally want as much wire in the air as high above the ground as possible. You can think of it like this, the more wire in the air, the more of the signal is catched. Of course that wire should follow certain rules (in terms of lenght and shape and diameter, material) but as a genreal rule of thumb, you really want as much wire as possible. From the antennas we talked about here, the stock dipol is obviousely the best in this regard.
HTH
Markus
Old Dec 30, 2012, 07:54 AM
9W2DLR
Joined Nov 2011
HTH
Markus
great!! i guess i'm gonna stick with sander for my quad,i dont even think my quad can go beyond 1km without running out of battery on the way back, but will still use dipole for my plane,
so if my understanding are correct the coax cable can be any lenght as i desire but the important thing is the wire that connected to the active element and ground of the coax
thanks
Old Dec 30, 2012, 11:17 AM
Registered FPVer :)
Joined Aug 2006
thanks
Regarding your "coax being any lenght " statement, and in the context of your 70cm RC link - virtually yes, as the loss at this frequency is small enough to not play a great rule. It would be very different though if we would talk about a 5.8Ghz video link where the loss becomes an issue and also the type of cable used becomes extremly important.
Markus
Old Dec 30, 2012, 01:08 PM
Joined Apr 2012
still 1-2 months shippinh?
Old Dec 30, 2012, 02:30 PM
Registered FPVer :)
Joined Aug 2006
??? How do you come to this conclusion? I quickly visited www.rangepiloting.com and it seems to be in stock.
Markus
Old Dec 30, 2012, 03:08 PM
Joined Apr 2012
Markus
At checkout
"Warning: Now Close to the Christmas,all parcel the delivery time may up to 1-2 months,even you select the EMS shipping method;maybe the DHL is good choice,just email to us if you like to use it."
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 48797 Today 11:22 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
