Old Dec 27, 2012, 09:06 PM
guaglione87 is online now
Find More Posts by guaglione87
Team Armattan
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
I just ordered my rangelink a couple of days ago - still didnt ship, but trying to be patient. In any case, I am trying to prep my bixler for the install, and wanted advise on my components set up.
After some reading here, it looks that my best bet is to mount the rl antenna on the vertical stabilizer so that the two ends of the antenna are 180 degrees apart and vertical in configuration, correct me if I am wrong. I would have thought a 90 degree separation is best.
In any case, I have CEOSD, and a 200mw video tx/rx with bluebeam antenna's, and a homemade 4 turn helical to mess with (which is besides the point).
As of now, my video cl antenna is on my fpv pod, 3 inchs above the fuselage, the nova is underneath the fpv pod and gps location can be either on the fpv pod, or maybe on the wing. Infrared is behind the motor on the fuselage. I have a security2000 cam on the way too.
How is it sounding so far? I saw a couple of you have RL and Nova, so I wanna make sure my video and RC links are optimally placed.
Thanks!
guaglione87 is online now Find More Posts by guaglione87
Old Dec 27, 2012, 09:19 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, both RL Rx antenna ends should be roughly vertical. Just make sure the feeder coax
antenna turns away from the RL Rx ground fairly quickly. Placement of the various
antennas is up to you. Many put VTX antenna on the tail, and UHF antenna on the wing.
Some on opposite wings.. etc..
ian
Daemon is online now Find More Posts by Daemon
Old Dec 27, 2012, 10:15 PM
doonunder is online now
Find More Posts by doonunder
New Zealand, Auckland, Waiau Pa
Joined Dec 2006
Thanks!
Here's how I attached mine, if yours hasn't already shipped ask for the longer antenna to be sent, or make one up using spare sma connectors as i did.
Cable runs through the tail boom to a hatch cut into the side of the Bixler.
doonunder is online now Find More Posts by doonunder
Old Dec 27, 2012, 10:45 PM
wmartin is offline
Find More Posts by wmartin
United States, CO
Joined Sep 2011
Originally Posted by i3dm View Post
i have connected the RSSI ground and signal well, and did the servo analysis well.
ill look into the PCM option, but i dont think thats the case. as visible in my video my RL Rx would sometimes drop to 20% RSSI, and in my bixler it was usually always on 100%...
If I'm following you correctly, then one issue might be the way you've connected RL RSSI output to ET OSD input. Specifically, you should not run all three wires (-,+,sig) between the two. Rather, you should run only the sig wire from RL RSSI output to the center pin of the eLogger Temp1/A input. This is an important detail, as it requires you to change the position of the sig (white) wire on the eLogger end of the connection to the center pin of the servo plug. If you are running all three wires (-,+,sig) into the eLogger, it could well produce unexpected results.
wmartin is offline Find More Posts by wmartin
Old Dec 27, 2012, 10:58 PM
Team Armattan
Joined Apr 2012
Cool, looks to be just along the line of what I planned on doing. Too late on the longer antenna. I do have some longer servo wire extensions, so I may try to run everything back further rather then mess with the sma connectors, which I understand can be fragile, or not make the best connections.
In any case, Ill give it a go...
Old Dec 27, 2012, 11:10 PM
RxFPV is offline
Find More Posts by RxFPV
RxFPV's Avatar
Joined Dec 2012
delete this post
RxFPV is offline Find More Posts by RxFPV
Old Dec 28, 2012, 04:40 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Originally Posted by sid.huang View Post
thanks for your report.
To Mykro and i3dm just try this as wmartin said.
Sid
Already did that.
so the next step is to do a high power mode ground range test ?
i3dm is offline Find More Posts by i3dm
Old Dec 28, 2012, 04:43 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
im not running all 3 wires !
im running the Rx ground to temp 1 ground.
and Rx RSSI (3rd pin) to Temp 1 voltage detect (center pin).
this should be perfectly fine.
i will remove the ground wire just in case, but i really dont think its got anything to do with any of my problems.
Old Dec 28, 2012, 06:11 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
sander style UHF antenna
Description:
gonna do range test first in a moment
skellator is offline Find More Posts by skellator
Old Dec 28, 2012, 06:55 AM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
skellator,
thats interesting, I use two of those on my older EzUHF diversity Rx.
rclab1 is online now Find More Posts by rclab1
Old Dec 28, 2012, 07:39 AM
9W2DLR
Joined Nov 2011
Originally Posted by rclab1 View Post
skellator,
yeap because ezuhf have 2 shoukd work fine with RL too just RL only need 1 instead of 2 as RL do t have diversity
Old Dec 28, 2012, 10:05 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Ok so i flew today with the following different setup:
1. replaced Rx
2. removed ground wire from ET RSSI conenction
3, moved VTx to top of tail
4. moved GPS module on the tail boom
so the result is 3Km easily but with much jumping RSSI values sometimes close to 100 and sometimes close to 10%...
Its better. but Im still nto convinced this is 100% right.
Old Dec 28, 2012, 06:54 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Sid
I had PCM glitch detection already disabled...!
Mykro is offline Find More Posts by Mykro
Old Dec 28, 2012, 07:06 PM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Just connect the servos to the rangelink rx directly,if all channels work fine,I think the ET OSD still has some issues.
Sid
sid.huang is offline Find More Posts by sid.huang
Old Dec 28, 2012, 07:16 PM
Mykro is offline
Joined Feb 2009
Sid
Sid,
I will try what you suggest..
There people on this tread who are using ET OSD successfully who have no glitches..?
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 49065 Today 12:37 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
