Old Dec 20, 2012, 05:15 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No. Why?
Daemon is offline Find More Posts by Daemon
Old Dec 20, 2012, 05:30 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Originally Posted by Daemon View Post
It sounds low. I usually get 30-40 paces.
You need to do a test with *just* the RL Rx powered (preferably with a NiMH battery to
rule out noise from ESC/BEC) and use that as your baseline.
Note that if it persists in being very short range, it could be indicating some
other problem, like a damaged Tx or Rx antenna or SMA connector.
ian
just grabbed a new Rx from my lot with a new antenna, one micro servo and a lipo / Assan 3A UBEC (dont have a nicd in hand) - i get only slightly more than 10 paces.
opened the Tx - SMA coax is intact and soldered well.
i think i will test this in flight, but does it sound not right to you ?
i3dm is offline Find More Posts by i3dm
Old Dec 20, 2012, 05:31 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
No. Why?
could make a potentially much cleaner transmitter setup.
Old Dec 20, 2012, 05:50 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, 10 paces still sounds low to me. I just ran a quick micro-power test, and got
a pretty solid 20 paces, and could extend it to about 30 if I held the Rx antenna in optimal
orientation. However, I did just discover that a couple of my Rx antennas are broken.
The problem is, these thin coax multi-strand cores aren't very strong. The center conductor
can break off underneath the shrink wrap.
Strip back a tiny bit of the tip of your Rx antenna (just enough to see the conductor)
and check continuity between the tip of the active element and the center pin on the Rx
SMA connector.
ian
Old Dec 21, 2012, 06:40 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
RL Connection Question:
Using a Futaba 9C Super,...connecting to rear module Pins,
(and using the 3s Lipo inside my Futaba 9C Tx).
Is this the proper connection using only the 3 wires?
Thanks fellas'....
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Dec 21, 2012, 06:49 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
yes
Old Dec 21, 2012, 06:58 PM
rclab1 is offline
USA
Joined May 2010
Daemon,
do I need that 10uf resistor inbtw the PPM & V+ ?
Thanks for the respose.
Old Dec 22, 2012, 01:12 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Nope
Old Dec 22, 2012, 05:43 PM
gaahrdner is offline
Find More Posts by gaahrdner
United States, TX, Austin
Joined Jul 2012
Hi guys, I have a Turnigy 9x transmitter; can I plug the head tracking cable from my Fat Sharks into the Turnigy 9x's trainer port, or does it have to go into the Rangelink transmitter's head tracker port? I don't want to have to butcher a cable unless I have to. Thanks!
gaahrdner is offline Find More Posts by gaahrdner
Old Dec 23, 2012, 09:52 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
anyone know the basic measurement for the rx antenna? and what type of coaxial cable need to be used? i was thinking making my own antenna
skellator is offline Find More Posts by skellator
Old Dec 23, 2012, 01:25 PM
mich75 is offline
Find More Posts by mich75
Joined Dec 2010
Original antenna uses RG178 coax (but RG316 should be ok from what I've read), and each leg of the dipole is 164mm.
Tutorial here
mich75 is offline Find More Posts by mich75
Old Dec 23, 2012, 07:38 PM
9W2DLR
Joined Nov 2011
Tutorial here
thanks i have a lot of rg316 for my Cloverleaf if can be ise would be great
Old Dec 24, 2012, 07:35 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Anyone know where Sid went ? im trying to consult him with my low RSSI problem but no response by email for days ??
Old Dec 24, 2012, 07:39 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
SMA connector.
ian
Thanks Ian. i checked continuity between the groudn wire of the antenna and it was fine, i will check the other side too, but i tried another antenna and didnt quite see a difference.
this model has a camera (which was off and didnt make a difference), 1.2ghz VTx (which was off and didnt make a difference) and an Eagle tree OSD auto pilot full system + 2 UBECs - one 6V for Rx and one 12V for video and lights.
lights are also controlled by a turnigy brushed ESC.
What do you think could be causing this ? i think the 433mhz system is pretty immune to all of the above ?
Old Dec 24, 2012, 08:18 AM
rclab1 is offline
USA
Joined May 2010
i3dm
Probably on Xmas Vacation:-)
Hope he responds soon, because I'm placing an order soon:-)
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 53297 Today 05:31 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
