No, don't pull it to ground. RSSI is not meant to carry a load.
It is normal for RSSI voltage to not go to zero. Depends on your noise floor. Try measuring it some place further from civilization. ian |
Latest blog entry: My 2012 FPV year in Review
You don't use it to calculate range. You use it to compare your range before and
after the introduction of other FPV equipment. In other words, first do a micro-power range test with just the Rx powered and nothing else. A "normal" micro power range might be anywhere from 25-40 paces. Then power up rest of FPV equipment (or individual components) and repeat the test. If the range drops significantly then you know you've got an issue to fix. I typically am not comfortable with anything more than about a 20% reduction in range with FPV equipment powered. ian |
Camera is the most likely suspect.
Could be anything (camera, voltage regulators, current sensor, etc), but
many cameras are known to spew noise in the UHF band. Start by unplugging the camera, and then repeat the micro-power range test. If that doesn't improve range, unplug something else, and keep repeating test until you know what is causing the range reduction. ian |
Joined Apr 2005
Guys,
whats a reasonable distance in range check mode (micro mode) with the Rangelink ? i just setup a skywalker with FPV and Eagletree system and noticed my camera (420TVL CCD) was killing the range completely so without it im getting about 10-12 good 1 meter paces (probably about 30ft). VTx (1.2Ghz 800mW) on or off doesnt make a difference. is this too low ? |
It sounds low. I usually get 30-40 paces.
You need to do a test with *just* the RL Rx powered (preferably with a NiMH battery to rule out noise from ESC/BEC) and use that as your baseline. Note that if it persists in being very short range, it could be indicating some other problem, like a damaged Tx or Rx antenna or SMA connector. ian |
| Thread Tools | |
| Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! | JettPilot | Video Piloting (FPV/RPV) | 21866 | Today 01:37 AM |
| New Product ChainLink--The new UHF narrow band long range system | BEVRC | Video Piloting (FPV/RPV) | 878 | Jun 08, 2013 06:53 PM |
| New Product ChainLink UHF Long Range System | siim227 | Video Piloting (FPV/RPV) | 2852 | May 27, 2013 12:14 AM |
| New Product UHF Long range JR / Futaba module | Hooks | Video Piloting (FPV/RPV) | 18 | Aug 13, 2012 05:46 AM |
| Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range | LTS49 | FPV/RPV - Equipment and Vehicles (FS/W) | 8 | Jul 22, 2011 03:55 PM |
