Old Nov 28, 2012, 01:37 PM
Joined Dec 2006
Do both RSSI options give a voltage reading? What is best option?
doonunder is online now Find More Posts by doonunder
Old Nov 28, 2012, 01:43 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes RSSI pin always outputs an analog voltage.
There's no "best" option. There's only your preference.
Daemon is offline Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Nov 28, 2012, 01:52 PM
Joined Dec 2006
Thanks, rf = 0-3.2v and what is voltage range for signal quality?
Which did you choose?
Old Nov 28, 2012, 01:56 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Probably same voltage range for both. I prefer Rf RSSI.
Old Nov 28, 2012, 02:26 PM
Joined Dec 2006
Cool thanks, thought I saw a vid somewhere showing 10v for rssi on rangelink. must have been mistaken.
Old Nov 28, 2012, 02:44 PM
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
Originally Posted by picard10th View Post
Got it Why would anyone use packet?
a reason could be that you don't want to become paranoid looking at the rssi moves all the time. however i used it because i didn't install the new firmware.
by the way, does the new fw improve the performance (in terms of range)?
_ELLIOT_ is offline Find More Posts by _ELLIOT_
Old Nov 28, 2012, 02:47 PM
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
or the power battery was connected to the osd's rssi input
Old Dec 06, 2012, 04:53 AM
Expert Crasher
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
finally i received mine! the rx and antenna was small than i expected it to be which just nice as gonna put 1 rx on my quad and 1 on my skysurfer
skellator is online now Find More Posts by skellator
Old Dec 06, 2012, 09:05 PM
Australia, QLD, Brisbane
Joined Aug 2012
Rssi
I have the rangelink setup in my skywalker. The rssi feeds into and displays on my cyclops storm osd. I set the two parameters, max rssi which appears to be 2.9v and minimum with the transmitter off and its value is 0.9v. So it has about 2V range to show the rssi in percentage.
Does this sound correct? Is .9v too high for no signal? I ask as I am getting some instances of 30% rssi showing at around 1.6km line of sight.
Integratedneck is online now Find More Posts by Integratedneck
Old Dec 06, 2012, 10:38 PM
Expert Crasher
Joined Nov 2011
Gonna test this thing tomorrow, I use balsa wood for plate and wrap it with fiber tape, punch a hole into the balsa and my hbk plastic stand fit perfectly!
Old Dec 07, 2012, 11:08 PM
Expert Crasher
Joined Nov 2011
ugh accidentally plugin bec in reverse to my rx and as expected white magic smoke csme out, anyone know how the value of the yellow capacitor seem that the only thing that burn beside the small voltage regulator
dam good thing i bought 2 i really dont want to waste a 79 dolar rx here if posible i want to fix this
Old Dec 08, 2012, 05:26 AM
Joined Apr 2006
I accidentally powered on my tx without the antenna on and at full power and now it won't bind with the rx. I guess it's the amp that blew. Is that something that can be easily replaced ? And where would I get a new amp ?
theailer is offline Find More Posts by theailer
Old Dec 08, 2012, 05:41 AM
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
this is not the right way to set the rssi!
set 100% value looking at the voltage when the transmitter is 1 m from the rx.
set 0% value like the voltage with the transmitter switched off.
Old Dec 08, 2012, 08:54 AM
Expert Crasher
Joined Nov 2011
I'm getting same value for max but 1.09v for min (tx off), will try to reset the min max again
Old Dec 08, 2012, 02:06 PM
Just another FPV addict..
Orange County Ca.
Joined Feb 2009
Lost FPV plane in San Clements Ca.
Anyone lose an FPV plane in San Clemente Ca.??
Go to this thread.
http://www.rcgroups.com/forums/showt...8#post23475714
Someone found your plane.. In the Ocean..!!
ecworks.. Is it you??.. You fly San Clemente don't you??
Mykro is offline Find More Posts by Mykro
Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! JettPilot Video Piloting (FPV/RPV) 21886 Yesterday 10:56 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC Video Piloting (FPV/RPV) 878 Jun 08, 2013 06:53 PM
New Product ChainLink UHF Long Range System siim227 Video Piloting (FPV/RPV) 2852 May 27, 2013 12:14 AM
New Product UHF Long range JR / Futaba module Hooks Video Piloting (FPV/RPV) 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV/RPV - Equipment and Vehicles (FS/W) 8 Jul 22, 2011 03:55 PM
