Old Nov 23, 2012, 10:13 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Except he could have it today dirt cheap. I do get a stronger signal, in English
Do have to watch the nulls but angle doesn't change fast at LR.
Hey Elliott I noticed you have 100% RSSI at 20km, How you do that?
picard10th is offline Find More Posts by picard10th
Old Nov 24, 2012, 03:57 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
What do you guys prefer with your RSSI selection?
1.packet loss indicator or 2. Rf signal strength indicator
Locko is offline Find More Posts by Locko
Old Nov 24, 2012, 01:38 PM
martyester is offline
Find More Posts by martyester
Joined Jun 2012
As for the IBCrazy Turnstile, I prefer it for my flying wing because I don't have it sticking below the plane. I just bury it in the wing.
martyester is offline Find More Posts by martyester
Old Nov 24, 2012, 01:49 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Packet loss indicator is sort of like the dummy temperature gauge in your car.
It'll indicate 100% most of the time, and when it starts to change at all,
you should probably go home. The Rf RSSI gives you a much more
progressive indication of range, but it's non-linear and varies greatly with
antenna orientations, multipathing, and so forth, so it can be a bit distracting to
see it bouncing around. Have to accept that it's not going to just sit
at 98-100% all the time, even when you're relatively close. For
detecting antenna problems it's invaluable though.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 25, 2012, 06:01 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
A valid applicatioin for the Turnstyle as long as you keep the mentioned limitation in mind.
I use self made dipole antennas which I made out of relatively stiff 0.6mm silver coated copper wire. Before flight I straighten the lower wire which then will be in perfect position but obviousely gets bent back during the landing. That wire can be bent many many times without problems and at the point it breaks, I simply replace the antenna with spare one I have on the field. Since making such an antenn is extremly cheap and since such an antenna does not really use up space that's easy enough to do. I then repair the "broken" antenna by simply replacing that part of the wire.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 26, 2012, 09:52 AM
boony99 is offline
Find More Posts by boony99
Joined Nov 2011
When will this be back in stock?
boony99 is offline Find More Posts by boony99
Old Nov 26, 2012, 10:02 AM
_ELLIOT_ is offline
Find More Posts by _ELLIOT_
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
i can't explain it better:
ian
_ELLIOT_ is offline Find More Posts by _ELLIOT_
Old Nov 26, 2012, 10:56 AM
skellator is online now
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
you just miss it by a day, yesterday i saw it was on stock now checked again it go out of stock again, need to be fast to get one apparently
skellator is online now Find More Posts by skellator
Old Nov 26, 2012, 11:20 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
where can i buy the combo for 100bucks?
timtimtim is offline Find More Posts by timtimtim
Old Nov 26, 2012, 01:37 PM
picard10th's Avatar
Joined Jan 2007
Got it Why would anyone use packet?
Old Nov 26, 2012, 02:05 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Same reason that the temp gauge in your car does not show you true temperature
(which actually changes constantly between about 160-200 degrees F). It can be
distracting, even when nothing is wrong. From a control perspective, you
may only want to know that you're receiving 100% of the packets and when
you start losing packets, you've hit the edge of the range and it's time to turn around.
ian
Old Nov 28, 2012, 12:14 AM
9W2DLR
Joined Nov 2011
dam this thing sold out really fast I just saw it in stock few min later it gone! missed out again, Sid seem your website don't really sent any notification on stock update
Old Nov 28, 2012, 12:20 AM
sutan is offline
Find More Posts by sutan
Australia, NSW, Randwick
Joined Aug 2004
Luckily I got two receivers ordered. You can email Sid and do a preorder.
sutan is offline Find More Posts by sutan
Old Nov 28, 2012, 01:59 AM
9W2DLR
Joined Nov 2011
thanks i emailed sid and manage to get 1 set with 2 tx
Old Nov 28, 2012, 05:24 AM
acky is offline
Find More Posts by acky
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
Interesting - I flew out to 2ks and was at 49% rssi still had full control and when I tried the high power mode there was no change?
I'm using 1.2 (1080) video and the vrx was directly between my radio aerial and the plane, as soon as I flew out further to my left the rssi jumped up to 100%
It's great having the rvosd return to home - it installs great confidence!
acky is offline Find More Posts by acky
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 50162 Yesterday 10:12 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
