Old Nov 21, 2012, 08:40 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Finally got to the bottom of my TX problem. I had one bad rx which would cause binding problem for all the other RX's.Originally I thought it was a faulty tx,and was using 3 rx's for testing but after removing one RX out of the testing, all my problems have gone. Back to brand new.
Yay I can go flying again
Locko is offline Find More Posts by Locko
Old Nov 22, 2012, 06:56 AM
tupelo is offline
Find More Posts by tupelo
tupelo's Avatar
Finland, Uusimaa, HKI
Joined Feb 2008
Can the Rangeling antenna be used with Chainlink? I would need a longer antenna than the standard one and only Rangelink system has longer antennas in the rangepiloting shop.
tupelo is offline Find More Posts by tupelo
Old Nov 22, 2012, 08:00 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by tupelo View Post
Can the Rangeling antenna be used with Chainlink? I would need a longer antenna than the standard one and only Rangelink system has longner antennas in the rangepiloting shop.
Yes, that should work.
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 22, 2012, 09:14 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Why don't you build IBCrazy's Turnstile. Super easy, Cheap and superior to the stock dipoles IMHO. You probaly have the parts lying around, Piece of wire I used #18 and sma connector you can be in business today. Order the upgrade whip if you don't beleive me and when it arrives compare it to your $2 turnstile.
picard10th is offline Find More Posts by picard10th
Old Nov 22, 2012, 09:29 AM
Registered FPVer :)
Joined Aug 2006
I asumed the poster queried for the transmitter antenna albeit in theory one could build a turnstyle for this too. The turnstile is great, but there is one thing one should be aware off. It's horizontally polarized, meaning that one must have the transmitter antenna horizontally too, and here is the all important thing. If you fly out all to your side, you fly into the null of the transmitter antenna when holding it horizontally. If one is aware of this and turns arround apropriately, then the turnstyle is a great solution.
HTH
Markus
Old Nov 22, 2012, 12:09 PM
tupelo is offline
tupelo's Avatar
Joined Feb 2008
I ment the receiver antenna. So should I build the Turnstile or buy the Rangelink antenna, this one:
http://www.rangepiloting.com/dipole-...01e40bab674b1c
Can someone link me the Turnstile antenna building instructions?
Markus: Do you mean the horizontal polarisation is an issue when one uses the Turnstile as a transmitter antenna? If I use it as a receiver antenna with the stock Chainlink transmitter and antenna, should I be worried about the polarisation issue?
Another question: I have 2.4GHz video system at the moment, but I have understood Chainlink may have a problem with 1.2/1.3GHz video systems noise wise? I am planning to by that system as well and I have understood there is less noise problems with Rangelink and 1.2/1.3GHz video systems.
Am I right and is Chainlink usable with 1.2/1.3GHz video systems at all?
Old Nov 22, 2012, 12:22 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
He means that if you use turnstile, you have to orient your Tx antenna horizontally
and that makes it easier to accidentally fly into the nulls off the ends of the Tx antenna
if you don't turn to face the plane.
The stock Tx antenna and stock RL dipole is just fine for 99% of FPV flying. I see little
extra value in the turnstyle.
ian
Daemon is offline Find More Posts by Daemon
Old Nov 22, 2012, 01:20 PM
_ELLIOT_ is offline
Find More Posts by _ELLIOT_
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
20 km reached using low power and stock antennas!
this is the old firmware, i will upgrade my rangelink soon.
i have also ezuhf and apart some feature that rangelink don't has, i'm sure that this is the best value lrs
thank you sid! your kindness and your support are fantastic
20 km rangelink (8 min 46 sec)
_ELLIOT_ is offline Find More Posts by _ELLIOT_
Old Nov 22, 2012, 03:43 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
http://www.youtube.com/watch?v=zG6sR7lTELM
EMI blocked video
hefest is offline Find More Posts by hefest
Old Nov 22, 2012, 04:11 PM
_ELLIOT_ is offline
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
Originally Posted by hefest View Post
EMI blocked video
you can't see the video? try again!
however i think this was the limit in low power.
Old Nov 22, 2012, 04:31 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Still no go. Blocked in Germany.
What plane?
Old Nov 22, 2012, 04:36 PM
_ELLIOT_ is offline
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
What plane?
skywalker... strange things. i'm in italy..
however 20km are 20km.. and 200mw are 200mw...
Old Nov 22, 2012, 04:44 PM
_ELLIOT_ is offline
Team Flying Pirates
_ELLIOT_'s Avatar
Joined Nov 2011
i found the problem, try in an hour, i changed the music
Old Nov 22, 2012, 04:56 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Oh, I thought you got it from EMI comment. Yeah, it was blocked because of Music.
I can tell you that YouTube in Germany is filtering *alot*
Old Nov 23, 2012, 03:25 AM
Registered FPVer :)
Joined Aug 2006
ian
Thanks Ian, I could not have expressed that so well. Sometimes it's an advantage if one is natively english speaking.... :-)
Markus
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 50883 Today 08:12 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
