I'd say it's likely your Tx antenna connector is damaged, as described earlier in this
thread. Your signal strength dropped every time you moved your body (as indicated by various bumping and scraping noises early in the vid). No kind of external interference will cause the RSSI to suddenly drop to 50% only 1000ft away. ian |
Latest blog entry: My 2012 FPV year in Review
Well the Antenna connection appears fine, I can unscrew and wiggle it until the end. Still get about 50m on micro. I did notice my minimum setting on the RVOSD was at 780 when I didn'y really Fail Safe until around 450 effectively shortining the % scale so I lowered the min to 550 which gives me a 0% RSSI about 3m before failsafe. It's obviously easier to get closer to the nulls with a horizontal antenna position so I'll have to pay attention. I'll see what this adjustment does to the readings next time i can fly.
Do you have the Tx antenna horizontal to match the orientation on the plane?
I've never had a range problem with the stock Rx dipole oriented vertically as long as it's not near some Rf noisy component on the plane. ian |
It's probably the most critical aspect of using any UHF system. A single Rf nasty
component can cut the range to virtually nothing. That's why it's critical to do proper micro-power range checks, first with just the UHF Tx/Rx powered, and then again with everything on the plane powered up and operating as it normally would (including GoPro actually recording etc.. ) I had a really nice solid setup on my X8 with the RL Rx antenna pretty close to the center of the plane. Then installed a very popular OSD and my range dropped dramatically. Chased my tail for a while and finally figured it out. I had made the mistake of not doing a micro-power range test because I assumed the OSD was Rf clean because nobody else had ever reported an issue with it. Discovered that the current sensor was spewing a lot of noise (maybe it's just mine.. maybe not). Ended up having to move the RL Rx to the other end of the fuse, and the RL Rx antenna all the way out in the middle of the wing, to get away from it. Now my range is back to normal. Note that Rf noise doesn't always cause the RSSI to drop. Because it's noise picked up by the Rx, it can actually hold the Rf RSSI value higher while the Rx simply stops receiving packets. That's why for micro power range tests, I usually set a failsafe position that'll move one of the servos and I watch both the blinking light on the Rx (blinking slows as it starts dropping packets) and for the servo to jump to failsafe as I walk away from the Tx. ian |
Hi Guys, Just had my Plug and play cable break on the plug that goes to my dx8 ( not fixable) Ive found a plug I could use , but it has 2 rings instead of 1 ring on the plug. I ve open the cable up and the only difference is it has unshielded wire that wraps around the white and red wire.
Would it be ok and safe to use this plug? |
main body to main body of plug. The second ring is not used... |
the IB Crazy turnstile gives a 25-30% stronger RSSI on micro power tests but it is horizontal |
Joined Jul 2009
Jose Hi, have you made some more tests with your Channel Wizard 12ch setup? I looking for the same solution (needed all 12ch's for my glider). |
| Thread Tools | |
| Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! | JettPilot | Video Piloting (FPV/RPV) | 21086 | Today 11:35 AM |
| New Product ChainLink UHF Long Range System | siim227 | Video Piloting (FPV/RPV) | 2827 | May 09, 2013 04:13 AM |
| New Product ChainLink--The new UHF narrow band long range system | BEVRC | Video Piloting (FPV/RPV) | 877 | Jan 16, 2013 07:22 AM |
| New Product UHF Long range JR / Futaba module | Hooks | Video Piloting (FPV/RPV) | 18 | Aug 13, 2012 05:46 AM |
| Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range | LTS49 | FPV/RPV - Equipment and Vehicles (FS/W) | 8 | Jul 22, 2011 03:55 PM |
