Old Oct 26, 2012, 04:30 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Anyone using lawmate 1.2ghz rx and can confirm that it works with this?also What Vtx are you using?
timtimtim is offline Find More Posts by timtimtim
Old Oct 26, 2012, 05:25 PM
doonunder is offline
Find More Posts by doonunder
New Zealand, Auckland, Waiau Pa
Joined Dec 2006
Any issues with rangelink antenna in close proximately to folded sideways 2.4g tx antenna?
doonunder is offline Find More Posts by doonunder
Old Oct 27, 2012, 08:54 AM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
I use it, with no problems 1 inch away from Lawmate antenna and RL on high power. That said, these are mass produced systems that vary in tolerance and often component manufacturers. Two other things to note; It has been asserted that recent vintage Lawmates Rx's have had quality problems. And, be sure to use the latest RL firmware as Sid made some mods to improve VRx compatibility.
I use the 1W Lawmate VTx.
One last consideration, if you use a hand built/tuned antenna, such as a SPW or CL, you will get a filtering effect for out of band frequencies. Thus your SNR will be much better than with the "duck" antenna. Do a search and check out spectrum analyzer wave form shots to understand more clearly.
Hope this helps,
Steven
CN I Dawg is offline Find More Posts by CN I Dawg
Old Oct 29, 2012, 05:35 PM
Opt is offline
Opt
Find More Posts by Opt
Opt
Joined Oct 2010
Originally Posted by Daemon View Post
If you have a 4, 5, 6 ch Tx, it will add two channels that didn't exist before.
If you have 8-12ch Tx it will replace the last two channels with the p&t signal
ian
I'd like to suggest/request a feature.
I have an 8 channel transmitter and dont want to tie up channels 7 and 8 with a headtracker input. Can the firmware be modified to instead add the headtracker input as channels 9, 10 instead?
This would make better use of unused channels...
Opt is offline Find More Posts by Opt
Old Oct 29, 2012, 05:54 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Is there a way to map the HT to channels past 8 I have a x1000 HT and it looks like 8 is the limit
picard10th is offline Find More Posts by picard10th
Old Oct 29, 2012, 06:32 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I don't think RL Tx cares what channels the HT is using. It just looks for any two PWM pulses
and injects them into the end of the PPM stream without changing any of the other channels.
Problem with the feature above is it would have to completely rewrite the PPM frame
(compressing each PWM pulse) for all channels, in order to add two new ones. A 10-12
channels won't fit in a normal PPM frame length unless you make all pulses narrower.
If you're going to mess with rewriting the PPM stream, I'd use something like
Channel Wizard, which is designed for that purpose.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 29, 2012, 08:04 PM
picard10th's Avatar
Joined Jan 2007
multi Rx FS setting
I want to use another Rx on a separate plane. I'm confused how to handle binding for different planes.
Plane #1
RVOSD requires FS throttle to be set above normal operating range to trigger RTH.
Plane #2
Nova OSD requires 3position switch to FS on 3rd position to trigger RTH
So it would seem to change planes it would require rebinding and reset of FS each time. Easier on the Nova but the RVOSD requires prop removal and throttle trim adjust set FS etc.
Any other way? Ideas?
Old Oct 29, 2012, 08:25 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The Rx stores the failsafe. Just set it for the Rx in each plane. Done.
ian
Old Oct 29, 2012, 09:15 PM
picard10th's Avatar
Joined Jan 2007
Great! I thought binding resets failsafes. Do I bind each receiver separate and it doesn't cancel the other bind so both receivers will work at same time?
Old Oct 29, 2012, 09:26 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Binding does reset failsafes, but you only have to do it once per Rx.
Regular bind is just for the Rx's sake. Once both Rx are bound to the Tx, they would
actually work at the same time. Only an advanced binding would change the Tx id
and then you have to rebind all Rx.
ian
Old Oct 29, 2012, 09:58 PM
picard10th's Avatar
Joined Jan 2007
Thanks ian I think I got it
When I get the 2nd Rx just do a regular bind so I don't lose the bind with #1 Rx
Old Oct 29, 2012, 11:10 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Just received my Rangelink..
I just received my Rangelink today.. (Thanks Sid... took only 11 days from China)
My question is.. Does the Rangelink Tx/Rx come already flashed with the current firmware?..
If not, what cable is needed to flash with.? USB..? Can someone post a pic of it??
(I'm a Dragonlink V1 Ex-user.... Upgraded to Rangelink)
Michael
Mykro is offline Find More Posts by Mykro
Old Oct 29, 2012, 11:29 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yep.
ian
Old Oct 30, 2012, 04:15 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Michael
Michael,
I'm not Sid, but I bought a second system months ago which already was delivered with the latest firmware. RangeLink is very stable for long now, so chances are very high your system is up to date.
With regard to the programming, you can buy such a cable in Sid's store.
Markus
markus123456 is offline Find More Posts by markus123456
Old Oct 30, 2012, 04:26 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Is this unit pretty much guaranteed to work out to at least 1km no matter how it is setup and what environment you fly in? Motors, escs, cameras, vtxs, etc all in close proximity?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 51719 Today 12:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
