Old Oct 25, 2012, 06:12 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
And just to clarify. When you got the plane back, you simply re-powered the Tx and the the plane
and then pulled the plug on the Tx to test the failsafe functionality very first thing? You definitely did not
re-set the failsafe positions first?
The problem with "the Rx crashed" idea is that a truly crashed, non-functional Rx won't keep
sending the same PWM frames to the servos and ESC. It'll send nothing, and most
ESCs will shut down. You might test to see what happens if you pull the ESC throttle wire
off the Rx while the motor is running. Does it keep running, or shut down?
The only state I know of where the Rx can keep sending the same thing, is if you do not set
the failsafe positions after a re-bind. Maybe it crashed to that state even with
failsafe positions set, but seems unlikely.
BTW, may want to do a micro power range test and make sure your Tx antenna connector
is not damaged (as has happened to a bunch of us), cutting the range severely.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 25, 2012, 07:14 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
thecrawfords67 Just to clairfy you don't use any osd/AP right?
picard10th is offline Find More Posts by picard10th
Old Oct 25, 2012, 07:41 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Or even a stabilizer. Direct connect between ESC throttle channel and Rx?
ian
Old Oct 25, 2012, 09:17 PM
wmartin is offline
Find More Posts by wmartin
United States, CO
Joined Sep 2011
Originally Posted by allfiredup View Post
I get very occasional Failsafe glitches showing on my DOSD with the RL rx and DX8. Its just a half second flash of failsafe and happens maybe once every other flight. I never remove my Tx antenna and my reciever antenna connection is taped on so I can't imagine thats come loose.
Is it possible this is just some missed data in the PPM stream? Does anyone else get this?
I've experienced the same thing on more than one occasion, even while flying within LOS. Just as you described, it was a momentary glitch, just long enough for my OSD to announce failsafe engaged and then immediately disengaged. Initially, I wasn't sure what caused it -- Rx antenna orientation, RF interference on the plane, noisy environment, or possibly a loose Tx antenna connector. Now that I've installed the same RL system in a replacement plane, I've noticed it happen a couple of times while working on the bench with a very simple setup, consisting of only RL Rx, speed controller, servos, motor. I rarely remove my Tx antenna, but it seems prudent to check the connector. BTW, I'm flying Turnigy 9x with er9x firmware, ETOSD, and RL.
wmartin is offline Find More Posts by wmartin
Old Oct 26, 2012, 12:03 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
With regard to the DX8, it uses an audio style 1/8" plug on the trainer port. Those are
notoriously glitchy if the plug moves even the slightest bit. I used to use one for my mechanical
head tracker's signals, and it was horrible. It looks like the Turnigy 9x uses the same
type of plug, thus probably has the same type of problem.
ian
Old Oct 26, 2012, 12:11 AM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
Would be great to hear from Sid regarding this inconsistent behavior. About to get mine in the mail... And I am a little worried.
caall99 is offline Find More Posts by caall99
Old Oct 26, 2012, 12:13 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Which inconsistent behavior are you referring to?
Using audio plugs for the ppm signal is consistently a bad idea..
The other issue with the weird non-failsafe behavior, is the first we've ever heard of such a
problem. A datapoint of one doesn't make a trend.
ian
Old Oct 26, 2012, 12:17 AM
caall99 is offline
Joined Jun 2011
Sorry should have been more clear. was referring to the glitching failsafe even after Sid improved the sma connector situation. Is it still a trend that the connection is intermittent?
Old Oct 26, 2012, 12:51 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That's a different problem. So far only one person has reported an issue
with the newer SMA female connector on the Tx. The root cause of that issue is
actually the design of the stock antenna, which is missing part of the male SMA connector
(as is the case on several other brands of antenna) which allows the male connector to
screw down so far that the center pin puts extra stress on the inner female receptacle.
Here's what a normal Male/Female SMA pair looks like
(ignore the thing on the right).
And here's a diagram of the same
Notice there's a cylinder inside the male connector surrounding the center pin (on the left),
that inserts into the white space on the female side (on the right). Those two things
mating together are what normally limit how far you can screw them together. The
center pin does not reach the bottom of the hole (female receptacle) and the only
contact is made on the sides of the pin.
The RL stock antenna, and the very popular long range Nagoya NA-771 antenna
are both completely missing the cylinder on the male side. Instead all they have is
the outer threads and a very long center pin, so the only thing that stops
it from screwing down to the bottom of the threads is the center pin when it reaches the
bottom of the female receptacle. That puts tremendous stress on something that
isn't meant to carry any load at all.
[edit]
Here's a diagram showing the non-standard connector.
[edit]One last diagram, showing how they mate, and why the non-standard setup causes
problems. Again, there are several popular antennas that work this way so it's
not an RL specific problem.
What I'm going to do, is add a hard rubber or plastic spacer around the outside of the female
threads sitting on top of the lock nut which simply limits how far the antenna can be screwed down.
ian
Old Oct 26, 2012, 08:38 AM
wmartin is offline
United States, CO
Joined Sep 2011
ian
Good point regarding the audio style adapter. In my case, I've actually hardwired the RL plug into the RF module (I should have mentioned that previously). My RL Tx has the original SMA adapter, so I'm thinking that's a good place for me to start.
Old Oct 26, 2012, 08:45 AM
wmartin is offline
United States, CO
Joined Sep 2011
As Ian indicated, it seems all reported SMA connector issues involve the original style connector (minus one exception). I wasn't very clear in my post, but my RL Tx also has the original style SMA connector.
Old Oct 26, 2012, 09:38 AM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Originally Posted by thecrawfords67 View Post
Very strange no one else has had this problem....Sid any comment ?
Hello,if you had try rebind, the FS will reset to zero,that means all outs 0v (do NOT output pulse). So before fly you need to check the fs setting.
Sid
sid.huang is offline Find More Posts by sid.huang
Old Oct 26, 2012, 10:00 AM
Chinglish-funny
Joined Mar 2011
allfiredup / wmartin
here shows some reason will cause this(glitch):
1.weak ppm stream (with old tx).
2.fpv gear(Camera Noise,boost dc-dc etc).
3.very nosiy environment(to check this maybe you need a spectrum analysis).
Just try advance binding, maybe it will help to avoid the rf noise.
4.fault tx/rx antenna or fault tx/rx module.
Sid
Old Oct 26, 2012, 11:25 AM
thecrawfords67 is offline
Find More Posts by thecrawfords67
Joined Apr 2008
When I got the plane back I simply changed the flight pack and tested the controls. Then I unplugged the Rangelink from the Dx8 and saw this activated the failsafe perfectly. I had set the failsafe a week earlier with 0% throttle, and it has never been rebound. When I first got it I performed an advanced bind as per the manual.
I have an OSD but no RTH, so the ESC is connected straight into the Rx. I do use a trainer port for the PPM signal, but it is totally solid and never gets touched in flight. Besides I tried it with another transmitter anyway.
thecrawfords67 is offline Find More Posts by thecrawfords67
Old Oct 26, 2012, 12:51 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For whatever it's worth, I wouldn't expect switching transmitters (especially to a different brand)
on the fly would work, as any change in the PPM frame length can really confuse the Rx.
Generally any time the Tx is moved from one Tx to another, the Rx should be rebound.
ian
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 53366 Today 01:19 AM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
