Old Oct 15, 2012, 01:47 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Tx antenna problem (any antenna problem) would result in failsafes, not random rudder glitches.
I assume your saved failsafe position is not set to left rudder.
As you say, sounds like a servo issue.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 15, 2012, 05:21 PM
xscorp is offline
Find More Posts by xscorp
xscorp's Avatar
Valencia - Spain
Joined Sep 2004
Originally Posted by xscorp View Post
Has someone tried this on RL?
Well, so I decided going my way and try it. I have Channel Wizard mounted inside my Futaba 9C using transmitter switches for the additional 4 channels by following CW documentation. The new ppm-out is connected to RL module. Now my F9C is converted to a real 12ch system with RL.
The first tests are showing very good results. Next step is to make some flights in order to verify the new system is reliable and secure.
For my next FPV sailplane this is good news!!
JOse Manuel
xscorp is offline Find More Posts by xscorp
Old Oct 16, 2012, 09:12 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by LittleG View Post
so, are you going to sell it or hang on to it?
All mine get off! :P
heinduplessis is offline Find More Posts by heinduplessis
Old Oct 16, 2012, 01:21 PM
Foam Snow
Joined Aug 2011
I'm puzzled by the last page of the manual:
"Please remove the antenna often unless you have to!!!"
Does this mean one should always remove the antenna if not in use, or the contrary?
Old Oct 16, 2012, 03:23 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
what type of SMA connector is on the Rangelink Rx? I am hoping to build my own dipole and extension but need to know what SMA connector to buy to screw onto the Rx. To diffuse any confusion could someone please post a close-up screen shot of the Rx SMA connector?
caall99 is offline Find More Posts by caall99
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Double post.
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 16, 2012, 03:26 PM
Member #1
Joined Aug 2011
I think Sid means don't remove the antenna unless you really have to cause the connector is fragile and its been known to break from repeated use.
Old Oct 16, 2012, 04:29 PM
Foam Snow
Joined Aug 2011
I've frequently make a mistake trying to label it, so I took a pic It's the screw in type (male) with the little hole in the center (rp?).
Thanks, fair enough!
Old Oct 16, 2012, 04:31 PM
Foam Snow
Joined Aug 2011
Should I just move the rx antenna away from my cameras or the entire receiver? Antenna, one cable. Receiver, 6 million.
In micro mode I get a lot of glitches as-is.
Old Oct 16, 2012, 04:38 PM
npre is offline
Find More Posts by npre
Joined Jan 2011
The connector on the Rx is SMA Female. You will need a SMA Male connector on your antenna. RP-SMA is usually found on Wifi stuff but Foxtech and the like sell stuff with those connectors.
npre is offline Find More Posts by npre
Old Oct 16, 2012, 04:59 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
How exactly is this UHF system better than PCM1024 72mhz? I understand the claims of better range and stability, but no idea the science behind it. Why is the PCM system inferior within 2km for a multirotor?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 16, 2012, 05:08 PM
caall99 is offline
Joined Jun 2011
Thank you! Yup, SMA-male is required to connect to it. As i thought.
Old Oct 16, 2012, 07:05 PM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Back in stock??
Any idea when the Rangelink special deal will be back in stock??
Mykro is offline Find More Posts by Mykro
Old Oct 16, 2012, 07:07 PM
caall99 is offline
Joined Jun 2011
what type of deal is that?
Old Oct 16, 2012, 09:28 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Move things around until you get the results you want.
Sometimes repositioning the antenna is enough. Sometimes it's not.
Always *start* by doing a baseline micro-power range test with just the Tx and Rx powered
by a battery (like 4cell NiMh).
Then start introducing other components and repeat the test. If the range is reduced
then move things around until it isn't. If moving it around doesn't work, then you may
have to eliminate that component. Some cameras, switching regulators, current
sensors, etc are Rf noisy in the 433Mhz band. Some aren't. Some are *very* noisy.
and some only a little. The only person who can make it work optimally on your
plane, is you.
ian
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 51057 Today 12:32 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
New Product ChainLink--The new UHF narrow band long range system BEVRC FPV Talk 878 Jun 08, 2013 06:53 PM
New Product UHF Long range JR / Futaba module Hooks FPV Talk 18 Aug 13, 2012 05:46 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
