Old Nov 14, 2012, 05:21 PM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by Noah58 View Post
Hi all.
Can anyone help with the mounting or placing of the DL Rx antenna wire to my quad. Does the main part of the wire need to be fully extended or can it be coiled? Is there any other options for Rx antenna than the one supplied?
Received my DLink yesterday and immediately set about mounting the Tx to JR 8103. Followed the instructions in the DL manual carefully, read and re read and then had my wife double check me. Everything calibrated, ID'd, Bound beautifully without a hitch. Just as the manual said it would. Will set failsafe etc when the quad kit actually turns up and I get it built with Naza with GPS installed. Hope some of you can assist with the antenna problem.Many thanks.
G
The antenna ideally needs to be straight. I mounted mine in a tube, zip tied to the quad frame. The bottom end is okay to just hang down, but I was worried prop wash would swirl it up into the blades so that is also held in a tube.
I have the excess co-ax cable coiled. You can use other antenna, like a "sanders type" .. RMRC have them http://www.readymaderc.com/store/ind...oducts_id=1032 but will reduce range somewhat.
kaz1104 is online now Find More Posts by kaz1104
Old Nov 14, 2012, 07:31 PM
nickwad is offline
Find More Posts by nickwad
Nine inch member
nickwad's Avatar
Thailand, Chon Buri, Bang Lamung
Joined May 2006
Originally Posted by nickwad View Post
I have now found out its not channel 12 as previously suggested but ch 9 .
Its all working now but when switching off the transmitter the MK does not report lost signal as before. but just holds the last signal.
I have now set the DL failsafe to switch to coming home on signal loss.
How can I get the MK to react to signal loss as normal? as if the failsafe gets altered by mistake it seems as if it will fly away if flying in 'free' mode!
Anyone please...........Mike?
nickwad is offline Find More Posts by nickwad
Old Nov 14, 2012, 07:37 PM
crd is offline
crd
Find More Posts by crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Hey Mike, just wondering if you received my emails? I keep getting a vacation reply, I sent you a tx and 2 rx last week and I want to make sure you got them :-)
crd is offline Find More Posts by crd
Old Nov 14, 2012, 08:09 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
You would have to check with the Flight controller configuration. DL does not "shut down" like 2.4ghz systems without failsafes... so you would have to set a control channel to tell your flight controller to do what you want. For Example KK boards have a stabilize channel that can be set to failsafe to "autolevel"
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Nov 14, 2012, 08:56 PM
hawaiitaco is offline
Find More Posts by hawaiitaco
hawaiitaco's Avatar
Joined Dec 2010
Chris
Exactly....usually you assign a channel as a RTH switch on the MK (if you have navi gps)... then if you lose signal the failsafe should trigger RTH...
hawaiitaco is offline Find More Posts by hawaiitaco
Old Nov 14, 2012, 08:57 PM
Noah58 is offline
Find More Posts by Noah58
New Zealand, Tasman, Kahurangi National Park
Joined Oct 2012
Chris
How about with Naza and GPS for RTH. I havent got that far in setup yet, just gathering information.
Geoff
Noah58 is offline Find More Posts by Noah58
Old Nov 15, 2012, 12:04 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
I have a DL on my Naza Quad with GPS and the failsafe works like a dream , you just setup the FC as normal and then set the DL failsafe to put the Naza into its failsafe settings i.e. come home and auto land.
My question on the Mikrokopter is if you set the failsafe on the DL to coming home and set the altitude hold to kick in , If you were for eample flying at 300m altiude and 300m out and had total radio failiure it would return home and continue to hover at 300m until the battery runs out then it would crash?
I cannot work out how to set it so the DL lets the MK go into its failsafe ( alarm sounding , red screen and warning on the telemtry screen , RTH at a predetermined alt , emergency gas landing etc)
PS Noah58 if you have any problems setting up your Naza/GPS with DL feel free to ask. I have got mine working perfectly!
Old Nov 15, 2012, 12:54 AM
SuperFPVflyer is online now
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
Flown with Dragonlink
TBS Discovery - Neighborhood Patrol! (5 min 24 sec)
SuperFPVflyer is online now Find More Posts by SuperFPVflyer
Old Nov 15, 2012, 01:22 AM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
SuperFPVflyer how did you get stable enough video to make that trip around the neighborhood? Do you have your antennas way up high on a mast on the roof of a house or something? Or were you in a car, behind the quad?
philthyy is online now Find More Posts by philthyy
Old Nov 15, 2012, 04:20 AM
juz70 is offline
Find More Posts by juz70
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
Hi
I live in Australia and I sent my DL tx and 5 rx's to Mike 4 weeks ago for a FW upgrade and still have not got them back. Is this normal? For people outside of the states, how long have you had to wait to get your gear back? I am worried that they are lost and I'll never see my DL gear again.
juz70 is offline Find More Posts by juz70
Old Nov 15, 2012, 04:26 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Originally Posted by juz70 View Post
Hi
yeah mate, mine took about 4 weeks to come back, shouldn't be too far away now...
Haych is offline Find More Posts by Haych
Old Nov 15, 2012, 08:15 AM
rotojon is offline
Find More Posts by rotojon
Live To Fly
Joined Jan 2010
Originally Posted by JettPilot View Post
The dummy load is no longer needed or used. Please see the complete Dragon Link instruction manual, it is on the first page of this thread, first post, attached to the bottomo of the first group of pictures.
Mike,
The manual in the first post is the one i am following that says to install dummy load. Can you please just confirm the actual process and I will modify my printed version of the manual.
Thank You so much.
Jon
rotojon is offline Find More Posts by rotojon
Old Nov 15, 2012, 08:28 AM
rotojon is offline
Live To Fly
Joined Jan 2010
Metal will not hurt calibration. Just do not have the TX antenna right next to the RX, this swamps the RX and will mess up your calibration. This is why I suggest about 10 feet distance, with
Transmitter antenna ON the Dragon Link Transmitter,
Receiver antenna REMOVED from the receiver.
Okay... found this in a previous post so I will calibrate with TX antenna ON and RX antenna OFF.
Jon
Old Nov 15, 2012, 08:29 AM
Exyator is offline
Find More Posts by Exyator
Joined Mar 2011
That is an awesome video! Hope he accepts it...
Chris
Thanks, so do I
Exyator is offline Find More Posts by Exyator
Old Nov 15, 2012, 08:53 AM
angry is offline
Find More Posts by angry
Work less, fly more!
Australia, WA, Broome
Joined Aug 2012
Hi
Hello Jus, both my new systems took more than 4 weeks to get to the north west but they did arrive ok
Damien
angry is offline Find More Posts by angry
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14194 Today 08:34 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
