Old Nov 12, 2012, 06:38 AM
Exyator is offline
Find More Posts by Exyator
Joined Mar 2011
Contest entry
Hi DL users!
I hope this is OK, mike hasn't announced this week's contest but it's already Monday here and I'm anxious to show you my video. So, here it is:
FPV - Elements - Flown with DragonLink! (3 min 4 sec)
Exyator is offline Find More Posts by Exyator
Old Nov 12, 2012, 08:14 AM
naryan is offline
Find More Posts by naryan
Rotor Addict
naryan's Avatar
United States, VA, Leesburg
Joined Dec 2008
Talk about fast shipping! I placed my order on Wednesday and my Dragon Link was delivered on Saturday...
Well it wasn't actually delivered, even though I was home all day I found a "Sorry we missed you" slip in the mail box. Guess the postman/women didn't bother to walk to my front door. Now I have a present waiting for me when the PO opens back up tomorrow.
naryan is offline Find More Posts by naryan
Old Nov 12, 2012, 01:38 PM
Noah58 is offline
Find More Posts by Noah58
New Zealand, Tasman, Kahurangi National Park
Joined Oct 2012
Sorted
Noah58 is offline Find More Posts by Noah58
Old Nov 12, 2012, 02:12 PM
KentF is online now
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
Looking for some experienced DL user thoughts. I've been flying my DL for about a week now and have the RSSI hooked up to my OSD. When I'm out about 1.5 miles, my RSSI is showing around 50%. I know Mike has said not to worry about the RSSI reading but I'm trying to see if other see a similar reading. I just don't know if I have placement problems and I'm doing something to cause interference. I'm running a RMRC 1500mW 1.3 VTx and also not sure if this high power could be partly to blame.
One other piece of info...one time when I was down around 50% I switched to high power mode and it went up to about 85%.
Any thoughts would be welcome.
Kent
KentF is online now Find More Posts by KentF
Old Nov 12, 2012, 02:24 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Kent
I have noticed a big difference in RSSI with my 200mw 1.3VTX and my 1000mw (1200mw) from RMRC. At this power you have to keep quite a bit of distance to prevent problems. I mount my RX antenna and VTX antenna at least 3ft apart when using anything over 500mw on any frequency.
The problem is not with the DL RX but the lack of tolerances with the Video transmitters.
I only have a V1 so I cant test your high/low power situation, but with my 1000mw mounted any closer than 3ft I notice a big difference around 2 miles out. But even with RSSI below 50 I have flown easily to 5 miles...
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Nov 12, 2012, 03:17 PM
Kahnx is online now
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
... scratch that.
was a request for a tracking number for return of repaired/upgraded V1 gear.
Postman just delivered it, so I'm a happy camper again!
Kahnx is online now Find More Posts by Kahnx
Last edited by Kahnx; Nov 12, 2012 at 07:14 PM. Reason: Goods arrived, no need to request tracking number.
Old Nov 12, 2012, 05:15 PM
flavio martins is offline
Find More Posts by flavio martins
Joined Apr 2005
site problem
Hi, i am trying to buy dragon link but there is a message in paypal:
PayPal cannot process this transaction because of a problem with the seller's website. Please contact the seller directly to resolve this problem.
Do you know something about?
Does it work with Futaba 12ZHP?
tks
Do you already have the promo for fpvbrasil?
tks
flavio martins is offline Find More Posts by flavio martins
Old Nov 12, 2012, 05:43 PM
Joined Apr 2005
Please, can you send photo or explain about different antennas?
Old Nov 12, 2012, 06:00 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Does the Dragonlink only accept PPM in from the trainer port? If that is the case, it can only be a 8channel system, right? Or can it send a true 12 channel if you plug it into the module pins?
philthyy is offline Find More Posts by philthyy
Old Nov 12, 2012, 06:32 PM
chanyote66's Avatar
Joined Dec 2011
if your Transmitter can send 12ch ppm, then yes however, Chris mentioned that the timing issue with 12ch being longer than a standard ppm frame can cause lost packets and reduced performance.
I run mine in 10ch mode (TH9x) just to be safe, but I have run 12ch and only noticed random glitches under heavy loading (Moving 4-6 channels at once)
Chris
Old Nov 12, 2012, 07:01 PM
Juanp is offline
Find More Posts by Juanp
Joined Oct 2012
Look at this video, it's great it will show youhow work each antenna, its ranges, setups, polarization and gain patterns
http://vimeo.com/m/8826952
I have seen this video a couple of times
Juanp is offline Find More Posts by Juanp
Old Nov 12, 2012, 08:35 PM
nickwad is offline
Find More Posts by nickwad
Nine inch member
nickwad's Avatar
Thailand, Chon Buri, Bang Lamung
Joined May 2006
Originally Posted by nickwad View Post
I have done as suggested but it is beeping and showing lost signal in MK tools.
I have bound the receiver and checked with a servo, I have changed to multisignal ppm in MK tools.
I connected the white wire to the RX pad on the FC board , the black to ground and the red to 5v. The receiver is powered ok.
The jeti pad are not bridged and I have removed the Spektrum sattelite.
Any ideas what could be wrong please?
I have now tried soldering the signal wire to the PPM pad on the flight control but this has made no diference, the reciever is powered and bound , calibrated etc but the MK is still showing lost signal.
I am using ch 12 on the DL rec, and have changed the rec to multisignal PPM in MK tools.
Please has anyone got any experience of running DL on an MK ?
nickwad is offline Find More Posts by nickwad
Old Nov 12, 2012, 09:12 PM
chanyote66's Avatar
Joined Dec 2011
Originally Posted by Exyator View Post
Hi DL users!
http://www.youtube.com/watch?v=vrVfr27eyKg
Great flight! Iv watched it a few times that place would be great for a flying wing! get nice and low through those trees...
Chris
Old Nov 12, 2012, 09:20 PM
KentF is online now
FunkMaster
KentF's Avatar
Joined Jan 2011
Chris
Thanks Chris...good info. My antennae for rx and vtx are about 2.5 ft apart but the electronics are about 12 inches apart. I'm not sure I can make it more than 5 miles given my battery capacity right now so I'm probably fine but I was more currious than anything.
Appreciate it.
Kent
Old Nov 12, 2012, 09:24 PM
chanyote66's Avatar
Joined Dec 2011
Appreciate it.
Kent
at 2.5 ft you should be good, may want to check your VTX, maybe put a filter on it. my longest flight ever was by mistake... OSD rebooted and thought i was headding home...
The electronics are shielded, my VTX and DL-RX are about an inch apart in my aircraft...
Chris
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14021 Apr 26, 2016 07:25 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
