Old Oct 28, 2012, 05:25 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Mike & Chris,
Sorry for returning with more bad news, but my random short range failsafes have started up again. Several times I thought I solved my problem, but today once again today I crashed after a random failsafe. The most frustrating part is this happened after 10 flawless flights in a row at much longer range (no changes to the quad). In fact earlier during the flight I reached 1000' at less than 20' with no glitches in video or controls... 100% RSSI the whole time... It has even landed and took off at 1500' range with no problems. Then I come back close range, and randomly, at short range, my RSSI drops to 0%, DL failsafes for several seconds, and it crashes. Fortunately this happened at just 20' altitude and it only broke a plastic arm (as I mentioned before, 2 prior failsafes cost me a VTx and camera).
For sanity, I've had a few local expert FPV quad guys look in to this (all of whom successfully operate similar quads). They all scratched their heads along with me. At this point I have tried: moving parts around for separation, installing EMI filters on all my 5V & 12V lines (tuned to 433), adding a fatty LC filter on my flight pack volt sensor line, shielding my camera, VTx, and BEC with aluminum tape, swapping in high quality shielded power cables (no ground loops for sure... shields only connected near the lipo), and I even installing RG316 for my video line... overkill really.
So I think it's time I take you up on your offer of sending me a replacement system as we discussed before. I will send you both PM's in a moment.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Oct 28, 2012, 05:32 PM
FPVdude is offline
Find More Posts by FPVdude
Joined Aug 2011
Mike is having trouble with his PMs... I sent my TX in to the address he provided, and ordered an RX too. But he only sent back the RX... which I have absolutely no use for without the TX.
FPVdude is offline Find More Posts by FPVdude
Old Oct 28, 2012, 05:52 PM
Bohh33 is offline
Find More Posts by Bohh33
Thermal seeker
Bohh33's Avatar
Brunswick, Ohio
Joined Jul 2005
Is it possible to extend the coaxial cable to put the antenna into a position further than what the default antenna coax will allow?
I'm thinking something with SMA connectors on both ends? Or would this somehow decrease performance?
Thanks!
Bohh33 is offline Find More Posts by Bohh33
Old Oct 28, 2012, 05:55 PM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Originally Posted by egaus View Post
Status light is yellow, not blue.
I changed Id, re-bind, still get solid blue link LED and solid red power LED, no status led. Servo works. I'm hearing that my RX should have all 3 LEDs lit if bound correct, is this correct? If so, what else can I try?
e
sounds like its all good and ready to go. Mine has same light display as you're describing. solid blue light is good.
Haych is offline Find More Posts by Haych
Old Oct 28, 2012, 06:18 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
So it sounds like having only 2 LEDs lit (link and power) on RX is good? Anyone disagree with this?
What does the status LED report?
e
egaus is offline Find More Posts by egaus
Old Oct 28, 2012, 06:28 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Yeah his PM box is full. Mike offered me a replacement system about a month ago. I was patient and humble enough to hold off until I made sure it wasn't a problem with my installation. It appears that decision may be turning around to bite me in the ***. I hope not, and they send me a replacement ASAP. I already scheduled with my out of town buddies to do some FPV this weekend. After today's incident, I refuse to fly it again until I replace my DL... and I simply can't afford to buy another system to tide me over in situations like this, LOL!
Kev
ps: One of my buddies said he went with EZUHF for the good service... c'mon Mike & Chris... please prove him wrong.
Old Oct 28, 2012, 07:12 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Kev
What type of quad is this? What Control board are u using?
blueprint is offline Find More Posts by blueprint
Old Oct 28, 2012, 07:55 PM
Bohh33 is offline
Thermal seeker
Bohh33's Avatar
Brunswick, Ohio
Joined Jul 2005
Thanks!
My research makes it sound like I can do this. But, it kind of sounds like I should make a whole new antenna so there is only 1 SMA connector between the feed line and the RX.
My question is could I make a "extender" feedline that has a mating SMA for the RX and then another mating SMA at the end of the extender and attach my real antenna to that? I understand coaxial is shielded so that it's length doesn't effect anything, but do the number of connectors do anything?
Thanks!
Old Oct 28, 2012, 09:09 PM
FPVdude is offline
Joined Aug 2011
Yes, please don't make me buy an EZuhf...
Old Oct 28, 2012, 09:39 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Leaning towards EzUHF. It might be more expensive, but you get what you pay for.
I don't want to spend my hard earned money on something that will just give me heart ache and grief.
Sorry, DL. I think you just lost a potential customer.
I'm just glad I subscribed and read through all of these issues about the DL before actually ordering one.
LittleG is offline Find More Posts by LittleG
Old Oct 28, 2012, 09:43 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I don't want to spend my hard earned money on something that will just give me heart ache and grief...
Feel free to buy whatever system you like that provides the features you want. There's lots of good systems out there. All with some pros and cons I'm sure. Get what makes you happy and have fun flying.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 28, 2012, 10:53 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
It's my same old 450, KK2, GOSD2 (closd), HK Blue Series 20 (simonk), NTM 28-26-1200, 1045sf, Turnigy 40V BEC (aka 'interference free'), SecurityCam2000 600TVL WDR camera, HS-65HB for tilt, 3s750 for video & BEC, and 3s2200 for the packs. Nothing special, other than random failsafes.
Here's a video that summarizes how today went... happy... happy... bang this sucks!!!:
FPV quad - more failsafe drama (4 min 32 sec)
(FF to 3:55 to see the crash, watch the rest to see how random it was. I apologize for the skip right before the crash... my DVR happened to drop some frames. FWIW, what appears to be a problem with my GPS is normal... known issue with my OSD firmware.)
I'm relatively new at this, but I've already learned some things about FPV in this crash course I was blessed with. My expert FPV friends have coached me along the way, seen my efforts to fix the problem, admire my understanding of everything that's going on, are jealous of my level of craftsmanship, and agree there appears to be nothing left I can do but try a replacement DL. My choice of parts may be frugal, but I'm not just blindly slapping parts together and hoping they'll fly. Although, I'm sure many people have done that with their DL and never seen a failsafe. It's frustrating!
Kev
Old Oct 28, 2012, 10:54 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Im still planning on getting it and the DOSD... Did anyone look over the MS word doc i edited with what i think is the correct binding/calibration sequence etc?
cheers
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Oct 28, 2012, 11:07 PM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
Saw filter mod
Hi,
Just a heads up for anyone thinking of doing the saw filter mod. I bought 2 of the filters over a year ago and have been putting it off. Today waiting for the hurricane I decided to do it to one of my 1.2 Vrx's. After removing the old Saw filter and replaceing it I had to resolder a connection as it was much worse than the unmodified one. After resoldering it I was amazed at the difference. It was very noticeable. With a dummy load on the Vtx I moved the Vrx's to a point where the unmodified one on my monitor produced no signal at all. The modified one had just a small amount of snow....a big difference.
Good soldering techniques and some extra rosin flux (Radio Shack) makes it an easy job.
Tom
Cape Cod
tom3holer is offline Find More Posts by tom3holer
Old Oct 28, 2012, 11:19 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Has anyone ever found a SAW Filter upgrade tutorial online?
iskess is offline Find More Posts by iskess
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14200 Today 08:33 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
