Old Oct 26, 2012, 02:22 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Thanks for answering my messages Mike.
I also received the receivers today, it arrived faster than I have anticipated.
Really appreciate the help. I've been a dragonlink user since the V1 and and since moved over to the V2 and never had a problem.
blueprint is offline Find More Posts by blueprint
Old Oct 26, 2012, 03:18 PM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Never had any issues with D1 and the v2 works great, simple to setup. Just turn the plane on and fly...
cody069 is offline Find More Posts by cody069
Old Oct 26, 2012, 03:25 PM
Juninou is offline
Find More Posts by Juninou
United States, TX, Allen
Joined Aug 2012
Originally Posted by chanyote66 View Post
depending on how daring you are... you can open your remote and put an off switch on the 2.4ghz... (I did that to my FrSky module so i can remove the Antenna when using DL)
Thanks! But no, I am not daring quite yet, I do love this remote
Thanks again for all the good advices!
Juninou is offline Find More Posts by Juninou
Old Oct 26, 2012, 05:48 PM
hpcoolahan is offline
Find More Posts by hpcoolahan
Fatshark Repairs AU/NZ
hpcoolahan's Avatar
Australia, NSW, Yamba
Joined Oct 2008
Originally Posted by sykmethodz View Post
thanks- could somebody link me to the MIG head tracker cable for dragon link. Not the MIG FUTABA trainer cable. I can't find it on hobbyking as recommended:/
http://www.hobbyking.com/hobbyking/s...dproduct=20650
if you meant the HT to DRAGONLINK HT port , i dont think dragonlink has released them yet , someone else will pipe in im sure.
hpcoolahan is offline Find More Posts by hpcoolahan
Old Oct 26, 2012, 05:51 PM
emadine is offline
Find More Posts by emadine
Joined Sep 2011
[QUOTE=Juninou[/QUOTE]
The futaba 8fg buildin 2.4g tx can be switch off when boot-up. And the ppm will still work for DL.
Cheers
Thomas.
emadine is offline Find More Posts by emadine
Old Oct 26, 2012, 06:04 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Cheers
Thomas.
Good to know! Thanks for the input!
chanyote66 is offline Find More Posts by chanyote66
Old Oct 26, 2012, 06:40 PM
Juninou is offline
Joined Aug 2012
Cheers
Thomas.
Awesome!!! So... Would you by any chance know how to do that?
Thanks again for the tip!!!
Old Oct 26, 2012, 06:46 PM
Moose2 is offline
Find More Posts by Moose2
Moose2's Avatar
Joined Aug 2008
When you power up with the throttle above idle you Will get a prompt asking if you want to transmit or not. Just select no. Can also be done in the menu. Don't have mine in front one so may be off a little.
Moose2 is offline Find More Posts by Moose2
Old Oct 26, 2012, 07:09 PM
emadine is offline
Joined Sep 2011
touch and hold the RTN button when power up ur tx and the power mode will display. Select RF off and the 2.4 is disable n the ppm is still output from trainer port.
Old Oct 26, 2012, 08:27 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
stuck with RSSi DragonLink V2 + Dragon OSD ??
I measure voltage for new 12Ch. receiver and it's 2.8V for maximum 100% rssi and 0.8V for my Dragon TX turned OFF ,but my DOSD does not show anything ,just 0%.
I setup in menu DOSD max/min RSSi values and still got 0% RSSi while I have all controls working through PPM Ch12 with DOSD ,but no RSSi ??
ANY IDEA ???
marcin.gala is offline Find More Posts by marcin.gala
Old Oct 26, 2012, 08:36 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
ANY IDEA ???
For the DOSD you need to go into the menu and set the G.P. mode to either 1 or 2. It defaults to 0 (no RSSI). The other settings show RSSI in either dBi or %.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 26, 2012, 08:49 PM
Joined Jun 2010
Thing is use DOSD with DL RX ,but that was 9ch OLD one and now swap for new 12CH new V2.
Still got same settings in DOSD,just no rssi reading shows 0% in top left corner.
Old receiver I power up through PPM channel positive/negative/singnal and rssi on 9Ch V1 was just two pins positive and negative =here I got wire to DOSD on positive pin.That's it.
New 12Ch DL RX V2 got RSSi but reading are on signal pin ,not positive "voltage" ,so even
when I connect to signal pin still got 0% RSSi "having control" ,but I don't use ground as it's already there on PPM which powering new receiver 12Ch V2 ,just to avoid groundloops for RSSi I got only one wire "was positive pin on 9Ch"...ufff...think it can easy to understand ;-)
Old Oct 26, 2012, 09:52 PM
Juninou is offline
Joined Aug 2012
Emadine, Moose,
Thanks so much!!!! I am going to try that tonight...!
Thanks again!
Jun
Old Oct 26, 2012, 10:45 PM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
Originally Posted by Japanx View Post
I'm a DL user for a year now. I'm still amazed like first day. in love of my DL system.
Something new and weird is happening with my new receiver.
Everything works perfectly with the old one just happens when i fit the new hardware Rx.
Suddenly it glitches. no matter at land or air. With Tx at 10cm near or 5kms out. It just glitches. Sometimes testing batteries it just revs the motor for half a second and moves servos. Sometimes does the same being at 5km out 1000mts up. TBH its scary but nothing happens since i just recover the plane and keep flying (first time happened almost did it in my pants) but it keeps me from flying low, realy low. a glitch like that near ground defenitely will end in a fatal crash.
Notice i'm using the first Tx and the newest Rx. hardware. So i cant calibrate, or change id... just rebind.
Any advice?
Thank you!
Japanx.
I'm having the exact same issue. Old V1 TX with the newest RX with old firmware on it. Mine worked perfect for a few days then it started getting random failsafes at very close distances. I sent the RX back to Mike and I'm not sure what he did but he sent me the same RX back and it worked great for a few weeks. Now its back to the same way. FS FS FS
I tried to send Mike a PM but his box is full. So now I'm stuck. I'm willing to bet he says the fix for it is to send the old TX and RXs back to get the firmware upgraded. I hate to change anything with my old system because I've had zero issues with it other than the new RX.
Is anyone out there successfully running a V1 TX and the newest RXs with old firmware on them?
cabster101 is offline Find More Posts by cabster101
Old Oct 26, 2012, 10:51 PM
helichoper is offline
Find More Posts by helichoper
helichoper's Avatar
Australia, SA, Adelaide
Joined Nov 2006
Yep i have a V1 TX not upgraded and run 2x new RXs with the 3 leds with old firmware - had about 30 flights with no problems at all.
helichoper is offline Find More Posts by helichoper
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14194 Yesterday 08:34 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
