Old Oct 26, 2012, 03:34 AM
sykmethodz is offline
Find More Posts by sykmethodz
Joined May 2012
Hey guys got mine today and it set up super easy. It's working with forcefly and all!
Where the heck can I buy the head tracker cable for the fatshark MIG head tracker? I don't see it on the website and it doesn't come with the head tracker.
sykmethodz is offline Find More Posts by sykmethodz
Old Oct 26, 2012, 03:53 AM
hpcoolahan is offline
Find More Posts by hpcoolahan
Fatshark Repairs AU/NZ
hpcoolahan's Avatar
Australia, NSW, Yamba
Joined Oct 2008
hobbyking have them mate , got mine there.
But there out of stock ATM ,,,,
hpcoolahan is offline Find More Posts by hpcoolahan
Old Oct 26, 2012, 05:23 AM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
Originally Posted by Juninou View Post
Thanks again!!!!
Before I rush to go buy another remote though, theoritally I should be fine with my 2.4ghz futaba+Dlink v2 if my fpv setup is 1.3ghz...?
Thanks!
It will just use a bit more power.
Panzlflyer is offline Find More Posts by Panzlflyer
Old Oct 26, 2012, 06:54 AM
motofox is offline
Find More Posts by motofox
United Kingdom, England, Nottingham
Joined Aug 2012
Hi recieved dlv2 today, i want to install it on a turnigy 9x er9x transmitter, im sure its pretty simple and its already been mentioned before but would somone thats already connected it tell me how ? ive got a data cable from the dl that il assume goes in the radio socket, so if somone could tell me which colour to which pin on the turnigy tx that would be great, also any settings i might need to do on the transmitter.. When i take out the turnigy modual at the back does that deactivate the 2,4ghz or is there somthing else i need to do ?
thanks
motofox is offline Find More Posts by motofox
Old Oct 26, 2012, 07:23 AM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
Check out the write up from Vantasstic on that.
http://www.rcgroups.com/forums/showthread.php?t=1679198
I actually did a variation of it where I gutted the 2.4 module, and using hot glue, attached the pug inside the module so it's all removable. Lots of write ups on that as well. Just google it.
HansAuf is offline Find More Posts by HansAuf
Old Oct 26, 2012, 07:49 AM
glassdogangle is offline
Find More Posts by glassdogangle
Fatalities caused by FPV: Zero
glassdogangle's Avatar
United States, OR, Springfield
Joined Jun 2011
Originally Posted by timbocan View Post
i think i've worked out what i was doing wrong!
i was trying to bind useing micro-power mode , the difference between
slow flashing green & fast flashing green,
so now i have servo movement , but have flashing blue light - not solid.
still some work to do
After you are Calibrated, ID Changed, and Binded, make sure both tx and rx antennas are on, and power tx up without holding the red button down. You should have solid green LED on tx. Now power up rx, and you should have solid red LED and solid blue LED. If blue is flickering or blinking, there is something wrong.
glassdogangle is offline Find More Posts by glassdogangle
Old Oct 26, 2012, 10:19 AM
Joined May 2012
thanks- could somebody link me to the MIG head tracker cable for dragon link. Not the MIG FUTABA trainer cable. I can't find it on hobbyking as recommended:/
Old Oct 26, 2012, 10:33 AM
chris1seto is offline
Find More Posts by chris1seto
Dragon Link/Labs Engineer
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
My MIG came with one, though it was to a 3.5mm jack. I just made an adapter. Tip of the jack is PPM, the largest conductor is gnd and the pinout on the DL is exactly the same as the pinout for the PPM input from theTXmitter.
chris1seto is offline Find More Posts by chris1seto
Old Oct 26, 2012, 10:40 AM
Juninou is offline
Find More Posts by Juninou
United States, TX, Allen
Joined Aug 2012
Thanks!!
Ahh... right!
I am assuming that means it will take a little more power off my 8FG battery, but will not affect the Dlink range... If so, I'll stick to my favorite controller for now...!
Thanks again!
Juninou is offline Find More Posts by Juninou
Old Oct 26, 2012, 10:49 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Thanks!!
Ahh... right!
Thanks again!
depending on how daring you are... you can open your remote and put an off switch on the 2.4ghz... (I did that to my FrSky module so i can remove the Antenna when using DL)
chanyote66 is offline Find More Posts by chanyote66
Old Oct 26, 2012, 11:08 AM
BiZARRE is offline
Find More Posts by BiZARRE
Joined Mar 2008
Have anyone tried an FTDI board to update the DL TX firmware?
Does anyone know what board that would work?
I need to update my firmware, and dont want to wait for the DL FTDI board.
BiZARRE is offline Find More Posts by BiZARRE
Old Oct 26, 2012, 11:12 AM
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
Originally Posted by bizarre View Post
have anyone tried an ftdi board to update the dl tx firmware?
I need to update my firmware, and dont want to wait for the dl ftdi board.
ygpm
Old Oct 26, 2012, 11:55 AM
Japanx is offline
Find More Posts by Japanx
Joined Mar 2012
I'm a DL user for a year now. I'm still amazed like first day. in love of my DL system.
Something new and weird is happening with my new receiver.
Everything works perfectly with the old one just happens when i fit the new hardware Rx.
Suddenly it glitches. no matter at land or air. With Tx at 10cm near or 5kms out. It just glitches. Sometimes testing batteries it just revs the motor for half a second and moves servos. Sometimes does the same being at 5km out 1000mts up. TBH its scary but nothing happens since i just recover the plane and keep flying (first time happened almost did it in my pants) but it keeps me from flying low, realy low. a glitch like that near ground defenitely will end in a fatal crash.
Notice i'm using the first Tx and the newest Rx. hardware. So i cant calibrate, or change id... just rebind.
Any advice?
Thank you!
Japanx.
Japanx is offline Find More Posts by Japanx
Old Oct 26, 2012, 02:04 PM
JaeDubbya is offline
Find More Posts by JaeDubbya
Just put it on the credit card
JaeDubbya's Avatar
United Kingdom, England, Milton Keynes
Joined Jun 2012
Originally Posted by chanyote66 View Post
The version would be related to when you bought it. Im not sure if there is another way to look it up. Mike can probably look at them but he would need the full system. Best bet is to wait for the flashing cables to be released, then you can flash the v2 RX to match the others...
Hopefully Mike or Chris can build a spreadsheet of Dates to firmware versions for reference.
The problem is I think I would have to downgrade the firmware on the V2 RX to make it work with the DL1, which is probably not possible. He can't upgrade the firmware on the DL1, because it does not have any functionality.
I have still not heard back from Mike or Chris.
JaeDubbya is offline Find More Posts by JaeDubbya
Old Oct 26, 2012, 02:10 PM
chanyote66's Avatar
Joined Dec 2011
Mike can upgrade firmware on the V1 but you have to send it to him...
Once the cables are released you will be able to roll back the firmware to an older version that matches the V1
Chris is on more but he works with programming, not shipping since they are in different locations.
Chris
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14035 May 24, 2016 08:18 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
