United States, NC, Goldsboro
Joined Mar 2012
http://www.dragonlinkstore.com/v2/node/10 You dont need the resistor with V2 |
status LED
Hi all ; i'm after a bit of info,
i have got my DL connected to TX and have the solid green light. powered up DL-RX with the jumper on 5&6 signal pins, and get the three lights lite, so all good so far so here is where i'm getting stuck; with the callibration of 15 to 20 minutes it said to leave sit for that long, then power them both off. Do i take the jumper off the RX before or after powering off. Then when it mentions a green light on TX and blue light on RX , does that mean that only the blue light should be on, or all three lights. Thanks in advance , i'm slowly working it all out , HaHa - so much to learn. |
Thanks for reply, so the jumper is only needed for the callibration,
the binding & ID change are all done with out the jumper after inital callibration. if i understand correctly. the RX should only have sold blue light, what about the power light . the red one ? that stays on too - (yes-no) |
So if i get only red light on RX after callibration ; then i'm best to try again.
replace the jumper - place TX in cal mode - power on RX and let sit a bit longer this time , and see how it goes. i'll try the 20min instead of 15min. so the only indication that i have got it right. is that after the set time, i power down both TX & RX then remove jumper . power them up again and hope for a solid blue and red light on RX. Thanks for the help ALL. |
United States, OR, Portland
Joined Aug 2012
Thanks again!!!!
Before I rush to go buy another remote though, theoritally I should be fine with my 2.4ghz futaba+Dlink v2 if my fpv setup is 1.3ghz...? Thanks! Quote:
| Thread Tools | |
| New Product Long Range UHF RC system now avail on STOCK | thomasscherrer | Video Piloting (FPV/RPV) | 11703 | Today 05:41 AM |
| New Product ChainLink UHF Long Range System | siim227 | Video Piloting (FPV/RPV) | 2827 | May 09, 2013 04:13 AM |
| Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! | JettPilot | Video Piloting (FPV/RPV) | 58 | Sep 10, 2011 09:15 AM |
| Yippee! Win a FREE Dragon Link UHF RC System - Video Contest | JettPilot | Video Piloting (FPV/RPV) | 63 | Aug 02, 2011 10:52 PM |
| Wanted Scherrer UHF long Range or Dragon Link | patrick21x | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Jan 08, 2011 10:55 PM |
