Old Oct 21, 2012, 06:54 AM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
NEW FIRMWARE
Hi Everynoe,
The new firmware that started shipping on 10 October seems to be the perfect version Now that people have started hooking it up to different kinds of RC Transmitters, and using it, we have not seen any issues with it. No problems, no bugs, its just the most stable, best working version we have ever put out. Chris did the impossible and got my " Dream List " of features and the way the Dragon Link system should work !!!
All Version 2 owners can update thier firmware at home, cables will be for sale soon on the website !!! Also, complete instructions are available for Dragon Link are available for download at:
Chris has done a great job on the manual and continues to update it as people ask questions and we see where people need help on installation.
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Oct 21, 2012, 07:03 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Originally Posted by tom3holer View Post
I just got my V1 DL back from Mike. Trying to calibrate it and having problems. I have read all the issues here with V2 and some may be the same with V1. I did the binding. Then it says to calibrate "Power on the Tx with a reg antenna attached while holding down the binding button for 7 seconds until the light turns green. Release the button as soon as it turns green, and if you have done it correctly the led will flash alternating red and green"
Every time I do it I just get the flashing green indicating the its in the binding mode.
Is there something I am doing wrong here.
Tom
Hi Tom,
Since your version is a version 1 system, the LED indications are a little different, you will not see the same LED indications as is in the manual for the version 2 system. When you hold down the power button during power up, you will get this:
3 - 8 Seconds: RED LED - Release button and it will flash RED, this is Micro Power mode for range testing.
8 - 13 Seconds: GREEN LED - Release button and it will flash GREEN, this is Binding Mode.
13 - 18 Seconds: RED LED - Release button and it will alternate between RED and GREEN - This is calibration mode.
18 + Seconds: LED Goes OUT: Release button, and the ID is now changed.
This is basiclly the same firmware as the Version 2 system, and is compatible with all version 2 equipment. Resistance to interference, range and functionality will be basically the same as version 2.
Site Sponsor
Old Oct 21, 2012, 07:10 AM
junioro16v is offline
Find More Posts by junioro16v
junioro16v's Avatar
Brazil, PR, Curitiba
Joined Mar 2009
Originally Posted by JettPilot View Post
NEW FIRMWARE
Mike, please, take a time and read the PM's.
My tx is totally fault.
junioro16v is offline Find More Posts by junioro16v
Old Oct 21, 2012, 07:16 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Originally Posted by Firatp View Post
Please answer my PM. I can not use ch9 for pan control. How can I transfer the PPM output to ch12?
This is very important for me. Because I am keen on Pan/tilt and need PPM for DOSD?
This is becoming a very serious customer complaints !! One of the choosing reason DL was head tracker option.
Regards
Firat
Hi Firat,
The channel the PPM is on is detrmined by the firmware, on your version it appears to be on channel 9. In the latest firmware, we put the PPM output back on channel 12, so your best option is to get the firmware cables when they are avaialable and update your firmware to the latest version. This is a nice update, and well worth doing.
Site Sponsor
Old Oct 21, 2012, 07:19 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Ola Junioro,
If your TX is bad, we will get a new replacement to you. Dragon LInk is fully guaranteed and no one gets stuck with a bad unit Although I suspect that a firmware update might fix your issue, I will get to your PM and we will get this figured out...
Site Sponsor
Old Oct 21, 2012, 07:22 AM
junioro16v's Avatar
Joined Mar 2009
Ola Junioro,
Ok. The problem is with the update. Take your time, read all the PMīs and let me know about. I already talked with Chris.
Old Oct 21, 2012, 07:28 AM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Can the firmware upgrade tool update v1 DL Tx's and (I think) V3 Rx's?
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Oct 21, 2012, 07:37 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi Firat,
Thanks for replying. I look forward to having Firmware cables soon.
Regards
Firat
Firatp is offline Find More Posts by Firatp
Old Oct 21, 2012, 08:31 AM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
CJ
V1 Tx is not user upgrade able. It has to be sent to Mike.
Tracks is offline Find More Posts by Tracks
Old Oct 21, 2012, 09:07 AM
Joined Jun 2007
Sent away again? I think ill pass. The last time it was gone for 6 months. I'd owned it a year. Had it waiting for 6 months for an airframe, sent off for the update. 6 months later it returns after the release of the V2. No chance I can open her up myself and update it?
CJ
Old Oct 21, 2012, 10:03 AM
Sil is online now
Sil
Find More Posts by Sil
Sil
Joined Jul 2012
Yes, you accidently deactivated it, and you can easily fix it Put a jumper on channels of the RX when you power it up, and it will activate it again. Check the manual for which channels you need to jump, it changed with firmware versions.
Hi Mike,
I get Back the PPM signal. By jumping channel 11&12 I got it on channel 12
But originally I had it on channel 9. I am fine with this, butjust curiosity, How could I get the PPM on Channel 9 again??
Sil is online now Find More Posts by Sil
Old Oct 21, 2012, 10:25 AM
wister is offline
Find More Posts by wister
wister's Avatar
United States, MO, St. Louis
Joined Nov 2006
Hi,
I haver a weird problem. I have 1 tx, and 2, rx's so far. when I try to use all 12 ch's I get a problem where 1 of the 12ch's doesn't work. On 1 rx it is ch1 and on 2nd rx, it is ch2.
Now, If I change my radio to 10ch's all 10, ch's work including ch1 and 2 on both rx's.
what I thought it was related to was, The radio I am using is a 9x with 3rd party firmware, it has settings for the pluse width and frame length, this is what I thought may be causing the problem, but I have changed both a little and problems just got worse.
there are some other settings I am not sure about, like Filter ADC, proto encoding, Silver A/B/C and TRAC09, shift select (pos or neg)
also, this guy has seen a similar problem where ch2 doesn't work while using 12ch's, but his starts to work when he press's around on the board.
http://www.rcgroups.com/forums/showp...ostcount=13457
Any ideas, or if anyone knows what settings I need to change to be able to use 12ch's, if it is a setting?
thanks,
John
wister is offline Find More Posts by wister
Old Oct 21, 2012, 10:30 AM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
Mike, Question about range
Hi,
Just calibrated my V1 system with the Tx antenna connected as required in the process. Now I notice that with the dummy load on the Tx and no antenna on the Rx but only inches away I cannot get consistent signal to make it work. I have to put the Tx antenna on then it works fine. Is this normal? I thought before the upgrade with the two on the bench the Rx worked fine with no antenna and Tx on a dumy load, and no I am not in micropower mode.
Tom
tom3holer is offline Find More Posts by tom3holer
Old Oct 21, 2012, 10:31 AM
naturecannon is offline
Find More Posts by naturecannon
United States, OR, Oregon City
Joined Jul 2012
NEW FIRMWARE
Perfect. Jumped on the forum to look into the update cable progress and there it was, my question answered
Haven't been online to stay updated lately. If I recall correctly..... is there another piece of hardware we need to go along with the cable for FW updates or will that be included in a package deal...... or no longer needed?
If needed, could someone please link me to the board that is needed to go along with the cable?
naturecannon is offline Find More Posts by naturecannon
Old Oct 21, 2012, 10:33 AM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
CJ
same....
mine since 2010
any thoughts for v1 owners..
barok is offline Find More Posts by barok
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14193 Yesterday 01:47 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
