Old Oct 20, 2012, 02:24 PM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
Chris1seto,
Thank you for the info. I understan what you said but I need to know the channel numbering and also is there not a dedicated PPM out pins for the DOSD?
tom3holer is offline Find More Posts by tom3holer
Old Oct 20, 2012, 02:42 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by tom3holer View Post
Chris1seto,
There has never been a dedicated PPM pin in any of the DL receivers. The first ones used channel 9 for PPM, the latest use channel 12 for PPM. You could disable the PPM and use that channel as a normal channel by installing a jumper on the appropriate pins on the Rx and then bind. I don't recall what the pins were though. The majority of folks were wanting the PPM enabled that Mike started sending them out defaulted with PPM enable. Perhaps Mike or Chris can enlighten us on how to enable/disable the PPM output.
Here's a picture of the pin configuration for the 9 channel Rx: http://www.rcgroups.com/forums/showp...&postcount=366
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 20, 2012, 02:49 PM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
Van,
I can't tell you how many times you have come to the rescue.
That link to the 9ch pin configuration is exactly what I have been searching for to no avail.
Thank you very much,
Tom
Old Oct 20, 2012, 02:51 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Van,
Tom
No problem Tom. I'll just invoice you the bill for PayPal payment...I mean...technical service isn't free here...is it?
Old Oct 20, 2012, 04:06 PM
chris1seto is offline
Find More Posts by chris1seto
Dragon Link/Labs Engineer
chris1seto's Avatar
Chesterfield, MO
Joined Nov 2010
I forget what the pins are for the 9chan, but for the 12 chan, short 11 and 12 together on startup. Lights flash together meaning "PPM now enabled" and apart for "ppm now disabled"
chris1seto is offline Find More Posts by chris1seto
Old Oct 20, 2012, 04:46 PM
Kahuna717 is offline
Find More Posts by Kahuna717
FPV-ophile
Kahuna717's Avatar
United States, TN, Greeneville
Joined Oct 2010
Hey guys,
It seems like i saw somewhere a while back that Mike sold cables from the fatshark round esky type head tracker plug to the dragonlink head tracker input?
Im really needing one of these cables because it seems like the pinout for the esky type connectors are different with each pinout i look at! Im trying to find out which pins are ground and ppm out from the MIG head tracker?
Thanks!
*edit: to see what i mean searching this in google shows various DIFFERENT pinouts for the connectors..im just trying to find ppm out:
https://www.google.com/search?q=esky...w=1600&bih=796
ALSO do i need to update my v2 firmware to use the head tracker or has that function always been available with all firmware? Sorry im new to head tracking i just bought a skywalker
Kahuna717 is offline Find More Posts by Kahuna717
Old Oct 20, 2012, 05:16 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Please answer my PM. I can not use ch9 for pan control. How can I transfer the PPM output to ch12?
This is very important for me. Because I am keen on Pan/tilt and need PPM for DOSD?
This is becoming a very serious customer complaints !! One of the choosing reason DL was head tracker option.
Regards
Firat
Firatp is offline Find More Posts by Firatp
Old Oct 20, 2012, 05:28 PM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
I just got my V1 DL back from Mike. Trying to calibrate it and having problems. I have read all the issues here with V2 and some may be the same with V1. I did the binding. Then it says to calibrate "Power on the Tx with a reg antenna attached while holding down the binding button for 7 seconds until the light turns green. Release the button as soon as it turns green, and if you have done it correctly the led will flash alternating red and green"
Every time I do it I just get the flashing green indicating the its in the binding mode.
Is there something I am doing wrong here.
Tom
Old Oct 20, 2012, 06:06 PM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
No it isn't
I owe you a LOT.
But, I rather owe you, than beat you out of it.
Flybynight2 is offline Find More Posts by Flybynight2
Old Oct 20, 2012, 06:47 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Tom
I don't think the flashing green is bind mode anymore...I think it was a flashing yellow/orange for bind now. I haven't played with the new firmware on my upgraded V1 yet so I'm right behind you in setting it up.
Old Oct 20, 2012, 09:32 PM
okiedrone is offline
Find More Posts by okiedrone
Joined Sep 2012
Help binding
Help!
I have version 2 can't get rec to bind only light I get on rec. is power no link or status
the only time they are on is when I have jumper on 5 and 6
okiedrone is offline Find More Posts by okiedrone
Old Oct 20, 2012, 09:33 PM
Cape Cod
tom3holer's Avatar
Joined Sep 2010
Van,
I don't see any yellow just red or green. The flashing green for binding seemed to work fine. Its the calibration that Mike said I needed to do that doesn't seem to work. I am surprised that the manual/web page is not current after all the confusion.
Tom
Old Oct 20, 2012, 11:58 PM
Captain3D is offline
Find More Posts by Captain3D
Captain3D's Avatar
United States, CA, Brisbane
Joined Jan 2012
Flat on all sides withe the high low power switch and just a few months old
Phil
Originally Posted by W5LIT View Post
Phil,
From what you have written it sounds like you have a Version 1 unit. Is your transmitter unit totally flat on all sides or is one side rounded? Also do have a high-low power switch or not? The version 1 units have a rounded side and don't have the high-low switch AND no calibration mode.
My Version 1 unit worked great for over a year and when I moved it from one plane to the next it started flunking all range tests. I've sent the unit in last week for update/upgrade and can hardly wait to get it back! Since my unit has been working so well out of the box I really paid no attention to further developments regarding the V2 units. A friend at the flying club purchased a DL based on my having one that works great and he got the V2 unit. Not knowing the differences, when my V1 was not working we tried binding his TX to my receiver etc but were perplexed that it would not bind. Its a good idea to follow this thread since there seems to be no other communication.
Captain3D is offline Find More Posts by Captain3D
Old Oct 21, 2012, 12:16 AM
Captain3D's Avatar
Joined Jan 2012
Sounds like my experience. To get red/green flashing for calibration I had let go of the bind button while the led was still red. Also I never see an orange led.
Did your Tx come with the dummy load? Can you get it into micro power mode?
Agreed that it is very confusing for the manual to be out of sync with the hardware.
Cheers ... Phil
Van,
Tom
Old Oct 21, 2012, 12:47 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Cheers ... Phil
I have a V1 upgraded to V2 FW but I think mine behaves the same as you're describing as far as the lights go. Mine does not have micro power mode.
After 3 seconds, release button & I have flashing green (bind mode)
After about 7-8 secs led goes red, release & its flashing red/green (calibrate mode)
More than 10 secs and led goes out - no light (change ID mode)
They have been changing the led sequence so often for a patch there that I think even the DL guys have gotten lost... Hopefully this obsession with change will subside and we can all catch up.
Haych is offline Find More Posts by Haych
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14076 Jul 18, 2016 08:25 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
