Old Jul 03, 2012, 09:23 AM
narcas is offline
Find More Posts by narcas
Lame-As The real alternative!
narcas's Avatar
Bulli, Australia
Joined Nov 2006
Originally Posted by G-Forced View Post
Thanks very much for all three of your answers. I do like the idea of adding the DL to an already Hi end radio but Im not sure my budget allows this at the moment. Not with whats on my bench
The (x is just so dam cheap to be honest, I cant imagine its any good ? But Im listening to you guys and it might be an option....
Hey Bing, any radio that you have with a plug in module RF unit will be the easiest to convert. I have a JR 3810 and it was genuinly a 5 minute job to fit the DL. By using the module pins you don't need a secondary power source for the DL either like you do using the trainer port. And it's not a permanent conversion. I can whack the 36MHz module back in whenever I want. Easy
narcas is offline Find More Posts by narcas
Old Jul 03, 2012, 09:46 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Wow...is this the Dragon Link thread or the 'I love my 9X thread'? Course...gotta say, I have a Multiplex Royal Evo 9 Tx...and prefer my 9X over it. I only wish my 9X had two 3-way switchs vs just one.
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 03, 2012, 09:51 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Just do a Rotary to 3 way switch mod. I changed 2 of them to 3 way switches for FY-31AP usage. Takes about an hour.
hendrnk is online now Find More Posts by hendrnk
Old Jul 03, 2012, 10:19 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Oh really...Hmmmm...sounds inticing. So you just dropped a 3-way in place of the rotary, attached wires, and done?
Old Jul 03, 2012, 10:23 AM
Benpaarl is offline
Find More Posts by Benpaarl
South Africa, WC, Paarl
Joined Jan 2012
Hi Mike
Sorry to repost, but you missed mine when answering.
"I have received my 2 new receivers today. The one worked perfectly, binded and calibrated immediately, the other one binded and then died. There are no leds and no movement at all. Is there anything I can do bearing in mind that I am far from you
Ben"
I also sent you an e-mail
Ben
Benpaarl is offline Find More Posts by Benpaarl
Old Jul 03, 2012, 10:49 AM
fpvguy is offline
Find More Posts by fpvguy
Joined Mar 2010
hey, i was going to get a dragon link v2 for my turnigy 9x radio. how does it install? will it work if i already have a frsky module in it? is it just plug and play?
fpvguy is offline Find More Posts by fpvguy
Old Jul 03, 2012, 11:12 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Check my blog for DL and 9X connection info...easy peasy. You'll need to pop out your Frsky module to connect the DL .
Old Jul 03, 2012, 12:02 PM
bilingue is offline
Find More Posts by bilingue
Joined Oct 2011
Hi i recive the DL at home 2 weeks ago, and i have Futaba T7C but i cant see where are the manual for intall the DL, do you know a web or something i can see to install mine? thnx
bilingue is offline Find More Posts by bilingue
Old Jul 03, 2012, 12:27 PM
Shoeless801 is offline
Find More Posts by Shoeless801
Mayday! Mayday! Mayday!
United States, UT, Ogden
Joined Jun 2012
Im at a total loss here... I am a beginer in fpv. Is there anyone that has a wiring diagram of how to wire up the dragon link v2 with eagle tree osd pro. I have serched to no avail.
Looking for basicly fpv for dummies guide... I got it hooked up to my tx but when it comes to my plane im at a loss.
Shoeless801 is offline Find More Posts by Shoeless801
Old Jul 03, 2012, 12:51 PM
Rexnoobs247 is offline
Find More Posts by Rexnoobs247
FPV FTW!!
United States, MI, Grand Rapids
Joined Oct 2011
You hook it up just like any other receiver you would use. ESC into the throttle channel on the DL, or preferably power it with an external BEC. Use the PPM out channel (it used to be channel 12) to go to your Eagle Tree OSD and there is also an RSSI pin out that will go to your ETOSD (you will probably only hook up signal with this one, no ground). Hope that helps
Rexnoobs247 is offline Find More Posts by Rexnoobs247
Old Jul 03, 2012, 01:09 PM
Joined Jun 2012
was looking for a diagram of some sorts.. even a rough sketch.
Old Jul 03, 2012, 01:48 PM
FPV FTW!!
Joined Oct 2011
I don't have one on hand at the moment, I'm not at home. I'm sure someone on here will be able to deliver a picture or a diagram soon. If not, I'll try to do it when I get home.
Old Jul 03, 2012, 02:13 PM
MikeyFPV is offline
Find More Posts by MikeyFPV
Joined Apr 2012
Originally Posted by D-OCHO View Post
What do you need more than this. (<== Link)
Plus a few questions on this forum about specifics.
Like don't calibrate with servo's attached. (I wonder why people would do it anyway)
Haha, sorry guys, have been so hooked to this forum, I completely forgot to look on the DL website!! Haha, can you imagine that...
Thanks!!
MikeyFPV is offline Find More Posts by MikeyFPV
Old Jul 03, 2012, 03:39 PM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Just add another switch Van.. 2 X 2.5k resistors and one 3 posistion switch and about 10mins work
cody069 is offline Find More Posts by cody069
Old Jul 03, 2012, 03:42 PM
GertB is offline
Find More Posts by GertB
Zwolle, the Netherlands
Joined Aug 2005
Perhaps Mike or someone else can help me out?
I just received my DL. When I connect the tx to my Futaba trainer port and turn it on, the led on the DL tx does not light up at all. I checked the voltage coming out of the trainer port cable that is fed into the DL tx, it is 7.6 volts. Trainer cable is connected to the "radio" plug in the DL tx.
Am I missing something? Is there a hidden on/off switch on de DL tx that I am not aware of?
I fear there might be something wrong with it, because when I plug the cable into the DL tx the pcb board seems to move inside the case.
GertB is offline Find More Posts by GertB
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14068 Yesterday 08:21 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
