Old May 31, 2012, 05:54 PM
wrath90210 is offline
Find More Posts by wrath90210
wrath90210's Avatar
Joined May 2009
So I tried just soldering the wires directly to the trainer port on the back. I get a green light but no control (even after re-binding) and my transmitter's low voltage alarm goes nuts. Do I need a resistor? When I move the DL antenna with my hand the alarm stops but I still don't have control. I've saved up weeks worth of grass cutting to get my hands on this but gah, I'm so lost.
wrath90210 is offline Find More Posts by wrath90210
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I received a question on replacing a lost SMA dummy plug. Anyone have a source or specs? I found some 50ohm ones, but they were listed for something like 2Ghz...probably not a problem, but just want to ask before relaying any information on. Thanks.
Vantasstic is offline Find More Posts by Vantasstic
Old May 31, 2012, 06:01 PM
wrath90210's Avatar
Joined May 2009
anyone?
Old May 31, 2012, 06:17 PM
wrath90210's Avatar
Joined May 2009
made some progress. Green LED on TX and signal and power on the receiver. I bound it correctly but the link light is still off on the receiver and still no control. Hmm...
Old May 31, 2012, 06:19 PM
traderdmb is offline
Find More Posts by traderdmb
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
anyone?
what type of controller are you using? I am no pro at this stuff but I am pretty sure that you should not remove the antenna on the DL tx while it's on. I would be sure its ok before you do it again.
traderdmb is offline Find More Posts by traderdmb
Old May 31, 2012, 06:23 PM
wrath90210's Avatar
Joined May 2009
The antenna is on the dragonlink. Never removed it. It transmits a signal and the receiver knows it's there. The problem is I can't get control. I had to use a 3s lipo to power my transmitter in order to power DL and the normal Tx. It's a Futaba 6exp. I have the wires directly soldered to the trainer port. V+, ground and PPM. My transmitter is also set directly to PPM.
Old May 31, 2012, 06:29 PM
wrath90210's Avatar
Joined May 2009
HAH I got it! The channles are switched ! DUh!
Old May 31, 2012, 06:32 PM
wrath90210's Avatar
Joined May 2009
This could just be my case. My channels on the receiver are labeled incorrectly. Ch8-Ch1 are opposite Or it could just be something strange with me . Idk Mike just letting you know as I have not read about this problem anywhere else.
Old May 31, 2012, 06:43 PM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
wow you guys are binding, i just got home and saw my tiny little USPS box. YIPPEE
Techmeister is offline Find More Posts by Techmeister
Old May 31, 2012, 06:54 PM
tx399999 is offline
Find More Posts by tx399999
Joined May 2012
Mine showed up. I have already installed the TX and bound the RX. Thanks for a great product.
tx399999 is offline Find More Posts by tx399999
Old May 31, 2012, 07:09 PM
CuznWeakEyes is offline
Find More Posts by CuznWeakEyes
It's all up from here..
CuznWeakEyes's Avatar
Prince Rupert, Canada
Joined Aug 2007
Maybe this is more helpful
[snip]
Any help is appreciated
Any yes the transmiter is ppm out lol
I can only ask if you tried with the included 10K Ω resistor connected between the +ve and signal wires? Seems to be a requirement for many Futaba radios.....See here:
http://www.dragonlinkstore.com/v2/node/10
EDIT: O.K.....I see you got it going. Disregard this message......hehe...
Cuzn
CuznWeakEyes is offline Find More Posts by CuznWeakEyes
Old May 31, 2012, 07:25 PM
Flying Tivo is offline
Find More Posts by Flying Tivo
Joined Feb 2007
As what i understand from V2, it no longer needs the resistor!
Felipe
Flying Tivo is offline Find More Posts by Flying Tivo
Old May 31, 2012, 07:34 PM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
http://www.ebay.com/itm/220956527367...84.m1497.l2649 it should be okay, it's DC to 3ghz. Also you can use it with up to 2W Tx
tushev is offline Find More Posts by tushev
Old May 31, 2012, 09:06 PM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Originally Posted by gundamnitpete View Post
I lost my FPV quad guys
I was WAYYYY high, gettign above the clouds shots for our next video. I just wanted to go up, then come down. Had my buddy dave spotting for full size aircraft (none in the area).
I lost video signal I put the quad in stability mode and lowered the throttle. Eventually i got a little signal, and it looked like the quad was about a half mile away. I tried to put it into a field. Thus far, we haven't found it.
So that's a VC450 frame, copter control board, Gopro, 32Gig SD card, Dragonlink RX,immersion TX, Ibcrazy cloverleaf, nanotech battery, 3S100mah fligtg pack, 4 ESc's, and four motors gone....
Sad day for me me and that quad have been through alopt together. All the team white llama videos were with that quad.
Sorry man, I know the feeling. I lost 2 planes, but I got them both back. I can offer you this help:
Forget about where it SHOULD be.
Look in the places where THERE IS NO WAY IT COULD BE.
You know, over THERE? NO WAY!! It should be over here. Yup, go THERE and look. Look about 500 feet (or even yards) in the WRONG DIRECTION. That's where it probably is. One of my planes that flew away was found almost 1 mile IN THE WRONG DIRECTION. Seriously!
You will find it, and you'll be amazed where it was. Just don't give up!
All the best. Keep us up to date, ok? We're waiting for the good news.
Now GO GET IT!!!
Bob
aka
Chairwolf
Chairwolf is offline Find More Posts by Chairwolf
Old May 31, 2012, 09:42 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Now GO GET IT!!!
Bob
aka
Chairwolf
Good idea. There's also the take another plane to the same spot and loose control of it then watch where it goes...you'll find the first nearby where the second crashes!!!! Hmmm...maybe not such a good recommendation after all!
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 13917 Feb 03, 2016 07:49 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 04:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 04:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 05:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 11:52 PM
