Old Oct 16, 2011, 08:40 PM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Originally Posted by Strudel View Post
Wondering if it would be easier to get this:
http://www.ebay.com/itm/5-055-Antenn...item3a6aca2132
6"?? I think that is a 1/4 wave. Look for a 35cm antenna.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Oct 16, 2011, 09:12 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
I was looking at antennas too and found a few that might work.
This one would be good for flying inside my car during the winter:
http://www.ebay.com/itm/160569841826...ht_3037wt_1289
cactus is offline Find More Posts by cactus
Old Oct 16, 2011, 09:14 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
Or I could use the stock Tx antenna with this:
http://www.ebay.com/itm/370548187247...ht_1224wt_1289
Old Oct 16, 2011, 09:34 PM
Strudel is offline
Find More Posts by Strudel
Joined Jan 2011
Hey Cactus,
This looks good. I might order that then! HMMMMMMMMMMMMMMMM
Strudel is offline Find More Posts by Strudel
Old Oct 16, 2011, 10:04 PM
hpcoolahan is offline
Find More Posts by hpcoolahan
Fatshark Repairs AU/NZ
hpcoolahan's Avatar
Australia, NSW, Yamba
Joined Oct 2008
Hey guys , putting the dragonlink antenna in the tail , it has the rudder and elevator servos about an inch away from the antenna .....is this a bad thing ???
Cheers
Patrick
hpcoolahan is offline Find More Posts by hpcoolahan
Old Oct 16, 2011, 10:06 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Cheers
Patrick
Not at all. Similar setup on mine and I had a 6.5mile flight with great RSSI.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 16, 2011, 10:14 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
is the dl contest still going if so where?
ROCKY2 is offline Find More Posts by ROCKY2
Old Oct 16, 2011, 10:25 PM
hpcoolahan's Avatar
Joined Oct 2008
Thanks Vantasstic .
Planning to use metal gears on the tail surfaces and thought the metal ones might stuff around with the signal.
So this but with the antenna inside the tail itself should be ok ??
Cheers
Patrick
Old Oct 16, 2011, 10:36 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Alright. After completely swapping out my DL setup (new rx, new tx), I've determined my turnstyle UHF antenna is giving me fits. 17% rssi at 2 miles if I hold my tx one way. rotate 45 to the right or left, it changes as much as 50%. Think I'm gonna go back to the old school dipole.
Kmart is offline Find More Posts by Kmart
Old Oct 16, 2011, 11:25 PM
Mer78 is offline
Find More Posts by Mer78
Joined Nov 2010
Anyone hook up DSX9 in another way other then the link provided? Pic will be much welcome. Im getting flaming hot trying all ways of doing it still cant get it up n running. All seems ok abt the tx lighting. But the motor keep beeping, servo not moving. Thanks alot guys.
Mer78 is offline Find More Posts by Mer78
Old Oct 17, 2011, 04:28 AM
mentony32 is offline
Find More Posts by mentony32
mentony32's Avatar
Australia
Joined Jun 2010
I have flown out 15km with almost that exact arrangement and my RSSI was still at ~30% with the Tx antenna 3 feet off the ground. Should work well but as usual, test carefully, every RF environment is unique.
Thanks Vantasstic .
Cheers
Patrick
mentony32 is offline Find More Posts by mentony32
Old Oct 17, 2011, 04:47 AM
mentony32's Avatar
Australia
Joined Jun 2010
@roypwee,
I'm using a Futaba 10CHP with the DL Tx connected via a stripped out module, no problem whatsoever.
Originally Posted by roypwee View Post
Anyone has had issued with their Futaba 10CAP with the DL? Like interference etc?
Coz I am having very odd beeping from my 10CAP and servos are jittery with the TSLRS. which is hooked up behind my 10CAP.
Planning to get a brand new shiny DL, as long as it does not give me such issues and most importantly reduced failsafe.
Cheers.
Old Oct 17, 2011, 07:32 AM
frank_slade is offline
Find More Posts by frank_slade
Joined Oct 2011
Graupner 40 MHz SSM E8
Originally Posted by frank_slade View Post
Hi,
does anyone know how to connect my old Graupner RC system to a dragonlink?
It is a 40 MHz SSM E8 System. It has neither a trainer port nor a HF module.
As you can see here:
I know it is a very sentimental thing to keep this old thing running but it would be so cool to make a modern very long range system out of it. I can not throw it a away
Is there no one who can help me with my RC? Or is it already solved somewhere else? Search didn't help me so far.
frank_slade is offline Find More Posts by frank_slade
Old Oct 17, 2011, 07:51 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Mate, your gonna need an Osciliscope to find the ppm stream among the RF module.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Oct 17, 2011, 08:21 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks Vantasstic .
Cheers
Patrick
That should be fine...how mine is installed.
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14062 Jun 23, 2016 02:23 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
