Old Feb 01, 2013, 08:49 AM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Originally Posted by kaz1104 View Post
You are assuming that control is regained. If there is a major failure and failsafe kicks in, and there is hover throttle set in failsafe, the quad will continue slowly climb or descend and drift, and drift, and come down as the battery discharges, but with enough throttle for those razor sharp spinning blades to slice and dice their way through whatever is in their path.
I prefer the drop like a stone thanks.
Perhaps a full house naza is the exception where it will either failsafe to rth or hover on the spot until battery flattens.
Why gaurantee a devastating crash? Set the throttle stick low enough so it doesnt stay airborne, but high enough to minimize damage.
The MK has rth capability so I don't have that worry. But in a "catestrophic" failure inside the copter it doesn't matter what your settings are in truth. It's going to do what it's going to do.
billyd60 is offline Find More Posts by billyd60
Old Feb 01, 2013, 09:19 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Originally Posted by Vantasstic View Post
Nope, not LED indicators on the V1 Rx's.
Can I bind first, to check function, then Calibrate?
Thanks!
scrtsqrl is offline Find More Posts by scrtsqrl
Old Feb 01, 2013, 10:50 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by marcin.gala View Post
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Feb 01, 2013, 11:08 AM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Originally Posted by scrtsqrl View Post
Did you power it off another pack or did you just install it in the plane?
Thanks!
I've tried both. In one case, I had the receiver on the bench, powered by a 4 cell Ni-cd and a single servo connected.
And then installed in the plane, powered by the speed controller BEC.
In both cases, the servo(s) twitch/jitter when the Tx controls are at rest. It's always done this since I got my DragonLink. I get good range tests, so I don't think it's a case of bad signal. Might be too much signal though, when the Tx is close to the Rx. But like I said it could also be that the DL Tx is affecting the PPM stream from the RC Tx. Not sure though.
Do you experience this as well?
twinturbostang is offline Find More Posts by twinturbostang
Old Feb 01, 2013, 11:17 AM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Does your radio have a diagnostics screen that will display the readout of your stick inputs? My servos twitch a little on DL and 2.4 GHz, turns out my aileron stick value jumps around between values -2,-1,0. Not enough to make a difference in flight, though.
viper522 is offline Find More Posts by viper522
Old Feb 01, 2013, 11:42 AM
Joined Mar 2006
I have a Futaba 10C. It does have a servo display mode. I'm not sure that the bar graphs have enough resolution to see it though. The servos don't move much. Just one or two "steps" probably. It just concerns me that there may be something wrong. But Mike said he checked it out during the firmware upgrade and everything was ok. So I don't know. BTW, I have the old 9 channel DL rx.
Old Feb 01, 2013, 01:09 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Thanks!
My aileron and elevator servos jitter. But, I think that's because of the rate gyros/DragonOSD. They work fine in flight.
I have on Rx in my plane. All seems to be working. Hope to fly it sometime soon.
Thanks again!
Old Feb 01, 2013, 01:24 PM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Hey Mike - clean out your inbox... I need to send you some information.. its important.
Blue Chip is offline Find More Posts by Blue Chip
Old Feb 01, 2013, 01:35 PM
Joined Mar 2006
Thanks!
Thanks again!
Try turning off the gyros and see if it still does it.
Old Feb 01, 2013, 01:48 PM
iurisouza is offline
Find More Posts by iurisouza
Brazil, BA, Feira de Santana
Joined Jan 2013
Mike, I forgot to inform you that I'm FPV Brasil member.
But no problem!
I'll buy another RX.
I look forward to flying with DragonLink in the Chapada Diamantina region.
Here in FPV Brasil almost all use the DragonLink and all are extremely satisfied.
Thank you for your attention!
iurisouza is offline Find More Posts by iurisouza
Old Feb 01, 2013, 02:26 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks!
I don't see why not. It seems counter-intuitive to calibrate first then bind, but that's the way Mike says to do it and it's worked for me. Though, in all honesty, my first V2 got bound then calibrated and it's working fine to date.
Vantasstic is online now Find More Posts by Vantasstic
Old Feb 01, 2013, 03:52 PM
sevensixty is offline
Find More Posts by sevensixty
sevensixty's Avatar
Joined Feb 2011
Your website states you ship within 24 hours but 2 days later I have received no update. Your PM box is full
Transaction ID: 9LJ03512YR312190H
What's the deal?
sevensixty is offline Find More Posts by sevensixty
Old Feb 01, 2013, 04:19 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
have you checked your paypal for tracking number?
Old Feb 01, 2013, 05:35 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Thanks!
Sure, it does not matter if you do something first, or even bind 1000 time and then calibrate, just as long as you bind again after you calibrate. This assures that the last bind is the best one
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Feb 01, 2013, 05:36 PM
JettPilot's Avatar
Miami
Joined Apr 2005
But no problem!
Hi,
I remember you, and yes I included your free receiver Whenever I do rememeber someone that qualifies for friend rewards, I ship the extra receiver even if they forget to claim it.
Site Sponsor
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14077 Today 01:03 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
