Old Jan 31, 2013, 04:32 PM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by Ascended View Post
Don't you guys use failsafes?
Failsafe on a multicopter is a tricky one ... 2 options.
1. Kill power and crash quickly
2. Not kill power, assuming a regain of control.
I tend to go with the first option. The latter one means that in the event of not regaining control, the multicopter will not only fly away, but will also come down somewhere like an out of control power saw.
kaz1104 is online now Find More Posts by kaz1104
Old Jan 31, 2013, 04:50 PM
SuperFPVflyer is offline
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
Flown with DragonLink
Pecan Patch FPV Recon Live Video Feed (7 min 46 sec)
SuperFPVflyer is offline Find More Posts by SuperFPVflyer
Old Jan 31, 2013, 05:10 PM
JohnVH is online now
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Not true if you have a KK2 board, auto level will hover it until you get control.
JohnVH is online now Find More Posts by JohnVH
Old Jan 31, 2013, 05:15 PM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
So will the naza if its set up right.
metalbender4by is offline Find More Posts by metalbender4by
Old Jan 31, 2013, 07:34 PM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
Originally Posted by FLYING_FORTRESS View Post
also i dont get how my 2.4ghz radio doesn't loose signal in an area croweded with 2.4ghz wifi and a cellphone antenna 300 feet away from me using signals close to 2.4ghz and having 1000 to 3000 foot range opn quad naza. yet my dl locks out at 5 feet. Yet when i do a dragonlink range check with no receiver antenna on my zephyr and a gopro next to it like littery next to it i walk 300 feet and its still works. I do have carbon fibre props on my quad but they can not be the problem as i have sayed i flew out nearly 1000 feet on 2.4ghz radio. I also hear that people with no naza but other fc don't tend to have this problem. I dont thing is so much of a range problem but something within the code of the dl reciever and dl transmiter. because i havent heard of people with dlv2 having this problem with naza. and something same goes for v1 i jjst don't understand
The Naza and the GoPro both emit a lot of rf noise, sometimes its an issue sometimes not thats the nature of radio signals.
The Naza Gps is also sometimes messed up by the Go Pro, mine it des not, my buddies it does.
Same goes for Dragonlink. You have to experiment.
Panzlflyer is offline Find More Posts by Panzlflyer
Old Jan 31, 2013, 09:45 PM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
If you don't have rth, the best thing is option 1, but I would add to keep slightly less power than a hover on the throttle, so it lands relatively softly.
billyd60 is offline Find More Posts by billyd60
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Mike,
I got my gear back today. Thanks!
Hopefully it gets back into my plane/quad over the weekend.
Thanks again!
JBB
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jan 31, 2013, 11:14 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Remind me: When powered does the DL V1 Rx have any LEDs illuminate?
Thanks!
Old Jan 31, 2013, 11:15 PM
Dreamer
Joined Aug 2004
You are assuming that control is regained. If there is a major failure and failsafe kicks in, and there is hover throttle set in failsafe, the quad will continue slowly climb or descend and drift, and drift, and come down as the battery discharges, but with enough throttle for those razor sharp spinning blades to slice and dice their way through whatever is in their path.
I prefer the drop like a stone thanks.
Perhaps a full house naza is the exception where it will either failsafe to rth or hover on the spot until battery flattens.
Old Jan 31, 2013, 11:25 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Received my upgraded DL today. Thanks Mike!
Question though... I still get twitching in the servos even after the upgrade. When I turn everything on and controls are at rest, the servos jitter/twitch slightly, as if I was back on FM 72 MHz. If I move the Tx away from the plane, that helps some. Or if I use the dummy load on the Tx, it's eliminated completely.
Haven't done a flight test yet so I don't know if it will do it in flight. But I'm assuming that the DL Tx just has so much power that it causes this when nearby to the plane. Although there's also a slight chance that the DL Tx is somehow affecting the PPM stream from my RC Tx. Not sure about that though.
Has anyone else experienced this?
BTW, I did the 15 minute calibration. Everything is binded properly. And solid green light on DL Tx. Oh and I also tested this with just the DL rx and a single servo attached. Same thing. So it's not something else in my setup.
twinturbostang is offline Find More Posts by twinturbostang
Old Jan 31, 2013, 11:59 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Did you power it off another pack or did you just install it in the plane?
Thanks!
Old Feb 01, 2013, 04:42 AM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Originally Posted by marcin.gala View Post
Dragonlink receiver submittion
My first fly with dragon link V1.
http://www.youtube.com/watch?v=zhjekVlg07Q
marcin.gala is offline Find More Posts by marcin.gala
Old Feb 01, 2013, 06:40 AM
plesk is offline
Find More Posts by plesk
plesk's Avatar
Malaysia
Joined Apr 2006
Originally Posted by JettPilot View Post
Yes, Check your email ! Everything has been shipping within 24 hours and I entered all the tracking numbers into the system this morning
Mike,
I'm not getting any email form you.
The PayPal transaction ID : 5F648949R8265462P
Thank you
plesk is offline Find More Posts by plesk
Old Feb 01, 2013, 08:23 AM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks!
Nope, not LED indicators on the V1 Rx's.
Vantasstic is online now Find More Posts by Vantasstic
Old Feb 01, 2013, 08:39 AM
Buffythesaint is online now
Find More Posts by Buffythesaint
Joined Feb 2005
Originally Posted by chanyote66 View Post
Naza is known to be very picky... But many people fly on here with no problems. The only failsafe I have ever had was when my Antenna went through a prop...
Ill check with FlOhio and see if we can find the noise... We are currently working on a clone of this Tri that will get all shielded servo and ESC wires once I learn to fly the thing
Chris
My Naza Disco has been working well for me, no failsafes at 1km. I have the gopro, 400mw 1280 vtx, TBS Core(unshielded) and DL rx/antenna at the rear. Not a lot of seperation but it seems to work. No idea why but I'm not going to change a thing.
Buffythesaint is online now Find More Posts by Buffythesaint
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14062 Jun 23, 2016 02:23 AM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
