Old Jan 30, 2013, 11:21 PM
MayMayDay is offline
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
Originally Posted by billyd60 View Post
MIke I got my (2) 12c rx's and tx back today after the firmware upgrade, Thanks! But you forgot to return my dummy load. Can you send it to me? Thanks
Bill in New Bern, NC
You don't need that no more. Check the manual for range testing.
MayMayDay is offline Find More Posts by MayMayDay
Old Jan 30, 2013, 11:28 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I got my systems back today. Thanks mike!!!!
ashdec87 is offline Find More Posts by ashdec87
Old Jan 30, 2013, 11:31 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by David Rushing View Post
You are running a two cel ? thought it needed 8 volts . My dx6i has four batts at max charge its 5.6volts not enough to power drago link.
yea im using the Turnigy 2s 7.4v lipo for the DX8 which also runs a 7s.
So i taped into the power of that battery. DL requires at least 7-12v from my understanding.
Just spread the 3 wires apart. Put a connector on the red/black for your batt to plug in. and solder the orange to the white one in the trainer jack which is your PPM/Signal.
Plug the trainer jack in. (radio should power up with out turning the radios switch on)
then plug your 2s lipo into the batt connect you made coming from the DL TX
Dragon Link With Spektrum DX7s Flown With Dragon Link (3 min 33 sec)
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jan 30, 2013, 11:49 PM
helichoper is offline
Find More Posts by helichoper
helichoper's Avatar
Australia, SA, Adelaide
Joined Nov 2006
Yep but its nice to screw on to protect the thread and keep rubbish out when not in use.
helichoper is offline Find More Posts by helichoper
Old Jan 30, 2013, 11:51 PM
billyd60 is online now
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Need the dummy load for calibration.
billyd60 is online now Find More Posts by billyd60
Old Jan 30, 2013, 11:58 PM
ParagonUAV
MayMayDay's Avatar
Joined Mar 2012
From the website:
CALIBRATION: It is advised to calibrate your receiver to your Dragon Link Transmitter when the system is new. This procedure must be done for EACH receiver you have, as the calibration information is stored in each receiver. With the antenna mounted on your Dragon Link transmitter ( Not dummy load ), Hold down the binding button while powering the transmitter on for 7 seconds, first the LED will be RED, hold it down a full 7 seconds until it turns GREEN. Release the button as soon as the LED turns GREEN, and if you have done it correctly, the LED will flash alternating RED and GEEN. Now, Jump the signal pins of Pins 5 and 6 of the Reciever with the antenna DISCONNECTED, and power it on. Let the system run like this for a full 10 minutes. Turn the Transmitter off, Then turn the Receiver off. Remove jumper on RX, it is now exactly calibrated to your transmitter. I recommending doing this procedure when the system is new, and once a year. This is NOT needed, and NOT recommended every time you fly.
Old Jan 31, 2013, 01:20 AM
mentony32 is offline
Find More Posts by mentony32
mentony32's Avatar
Australia
Joined Jun 2010
Hi Mike. Any news on my Rx you've had for a few weeks ?
Regards
Tony
mentony32 is offline Find More Posts by mentony32
Old Jan 31, 2013, 04:46 AM
quad007 is offline
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
does anyone have an older version RX for sale? I got my system last March. It wasn't the "really old" dragon link, but it isn't the brand new ones I've seen. I'd rather just buy a RX instead of sending my TX and 2RX in for an upgrade just so i can buy a new V2 RX
i think i have a V1 dragon link, the sides are rounded. I have a 12 channel version C receiver that I need.
quad007 is offline Find More Posts by quad007
Old Jan 31, 2013, 05:37 AM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Regards
Tony
Yes,
It is fixed and on its way back to you.
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Jan 31, 2013, 05:38 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Hi,
There is no more need for dummy loads. See page 700 of this thread of information on the new firmware on your Version 1 system.
Enjoy !!!
Site Sponsor
Old Jan 31, 2013, 05:39 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Yes you can buy an RX of any firmware version you wish, just pay close attention to the date your system shipped to you and order the correct firmware for that date.
Site Sponsor
Old Jan 31, 2013, 05:53 AM
blazesx is offline
Find More Posts by blazesx
Joined Jan 2013
Hi Mike,
I ordered at Jan. 27 a new DragonLink system via your web site. According to web site information, all systems are shipped within 24 hours, but i'm still did not received neither order status update, nor tracking number. Can you please confirm that system has been shipped and provide the tracking number?
My Transaction ID: 92999845D1406011C
Thanks.
blazesx is offline Find More Posts by blazesx
Old Jan 31, 2013, 05:54 AM
JettPilot's Avatar
Miami
Joined Apr 2005
There is no need for dummy load any more, for any system with the new firmware. We found that they are to easy to loose, and that it was kind of a pain in the ass to deal with them, so we changed the firmware so that they are never required anymore.
Site Sponsor
Old Jan 31, 2013, 06:01 AM
JettPilot's Avatar
Miami
Joined Apr 2005
Originally Posted by blazesx View Post
Hi Mike,
Thanks.
Hi,
Yes, it shipped on 28 Jan and your tracking number is RE918046515US
Site Sponsor
Old Jan 31, 2013, 06:04 AM
blazesx is offline
Joined Jan 2013
Thanks Mike )
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14145 Today 04:28 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
